I have a 40GB Hard Drive and well
Reply 20 of 29, by PhilsComputerLab
CompuClassics wrote:
Which Program will I need to save the current BIOS to a different file?
The same you're writing it with. Start the program with the ? flag and it should print out all the options.
YouTube, Facebook, Website
Reply 22 of 29, by PhilsComputerLab
Example 4 will NOT write the BIOS and only read it and save it into the file SAVEBIOS.
You can then try writing back that same BIOS as a test to see if everything is working.
I believe if you run the program without any options, it might interactively walk you through saving the current BIOS, then flashing a new one.
Reply 23 of 29, by alexanrs
I'd use
AWDFLASH NEWBIOS /Py OLDBIOS /Sy /CC
where NEWBIOS is the name of the new bios file, OLDBIOS is the name of the file to create and save a backup to
Reply 24 of 29, by CompuClassics
I actually tried Example 4 and I got this error
System was not new AWARD BIOS Version
Please updata ROM BIOS First
Will I need a old version of the old Flash writing program?
Reply 27 of 29, by JayCeeBee64
Rank Retired
Retired
I have attached two ASUS flash programs that came in my TX97-XE drivers/utils CD. Hopefully they will work.
    aflash_pflash.zip
    60.78 KiB
    63 downloads
Ooohh, the pain......
