Great PC! But can it run Crysis?
Reply 180 of 241, by kaputnik
My XP rig: Xeon X5470, Radeon HD 7850, 2x2 GB Corsair XMS2 PC2-6400 RAM, Socket 771 modded Asus P5B Deluxe.
This beast easily does 4 GHz on standard voltage, but since the cooling solution (CM Evo TX3) really isn't up for it, and the rig is starting to become old, I keep it at stock clock 3.3 GHz nowadays.
Edit: ah, had to crank it up to 4 GHz and do a run. Left everything else in auto (memory speed/timings, etc), couldn't remember what settings I used back in the day. Seems to be a small improvement at least 😀
    249.58 KiB
    251.66 KiB
Reply 181 of 241, by buckeye
PhilsComputerLab wrote:
Very nice, I like the use of that GPU.
Thanks. It's a nice "budget" card for less than 150 bucks. The graphics on this game amazes me of course I'm new to all this so can't imagine what the new games look like on modern hardware.
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 182 of 241, by clueless1
FYI, GOG is having a Spring Sale and Crysis is only $4.99 for a little while.
Reply 183 of 241, by Fusion
I remember first playing Crysis on a P4 @ 2.85Ghz with 2GB DDR RAM, and a Radeon x850XT PE 256MB. Times have changed. 😎
    788.5 KiB
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
Reply 185 of 241, by DosFreak
Not too much different sadly. Cross platform development between PC and console saw to that. 🙁
Make your games work offline
Reply 186 of 241, by gdjacobs
Some smaller titles are quite different, but AAA titles generally don't stray too far from the established path. Too much money tied up in production to take too many risks.
Reply 187 of 241, by andrewreader
Here's my main gaming rig..
14/03/2017 16:12:10 - Vista 64 Beginning Run #1 on Map-island, Demo-benchmark_gpu DX10 1920x1080, AA=No AA, Vsync=Disabled, 32 b […]
DX10 1920x1080, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: VeryHigh
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 21.38s, Average FPS: 93.55
Min FPS: 67.28 at frame 1967, Max FPS: 123.65 at frame 1011
Average Tri/Sec: -28283982, Tri/Frame: -302333
Recorded/Played Tris ratio: -3.03
!TimeDemo Run 1 Finished.
Play Time: 20.12s, Average FPS: 99.43
Average Tri/Sec: -28810208, Tri/Frame: -289762
Recorded/Played Tris ratio: -3.16
!TimeDemo Run 2 Finished.
Play Time: 20.07s, Average FPS: 99.65
Average Tri/Sec: -28601090, Tri/Frame: -287005
Recorded/Played Tris ratio: -3.19
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX10 1920x1080 AA=No AA, 32 bit test, Quality: VeryHigh ~~ Overall Average FPS: 99.54
The WinXP AMD Based Esprimo will follow soon..
Reply 188 of 241, by Munx
team RED time 😎
1.64 MiB
oh my... 😵
My builds!
The Underdog - The budget K6
Reply 189 of 241, by martin939
Ouch, never expected a HD2900XT to be that weak. Maybe choking on 2GB system RAM?
My benchmark doesn't even run on Windows 10.
Reply 190 of 241, by Munx
I ran a 8800gtx is this system previously and 2GB was enough.
I also ran it in dx9 more and the framerate doubled to ~16 fps.
My builds!
Reply 191 of 241, by agent_x007
512MB isn't nearly enough for Very High + FullHD my friend.
GTX 280/GTX 285 can barely do 30FPS Avg. with Very High settings and Full HD.
Reply 192 of 241, by Munx
I guess I'll have to run more tests with textures/resolution set lower. Shame the 1GB versions are hard to come by for a decent price.
My builds!
Reply 193 of 241, by MrEWhite
New rig! 😀
(Didn't have maximum performance on last run, had to redo it.)
806.58 KiB
Reply 195 of 241, by MrEWhite
agent_x007 wrote:
16xQ AA ? ... Anyone ? […]
MrEWhite wrote:
New rig! 😀
16xQ AA ?
Anyone ?
Any card after the 700 series can't do that level of AA fyi
Reply 196 of 241, by agent_x007
MrEWhite wrote:
MrEWhite wrote:
New rig! 😀
16xQ AA ?
Anyone ?
Really ?
All that ROPs and bandwidth... this sucks.
Reply 198 of 241, by Almoststew1990
I had a go at this with my main Windows 10 PC:
4770K slight overclock
8GB DDR3 2133MHz
8GB AMD 390X Stock
Average 88FPS (yay for rounding 😉 ) on the DX10 "very high" settings.
I think I'll try it on my Core 2 Duo / Nvidia 440 Windows 7 PC!
Reply 199 of 241, by Almoststew1990
My Core 2 Duo PC, but at 800*600 as the 440 is surprisingly bad!
Intel C2D E7400 2.8GHz OC 3GHz
3GB DDR2 800MHz
Nvidia 440
