Great PC! But can it run Crysis?
Reply 200 of 241, by brassicGamer
Well, I'm finally getting around to participating in the various benchmarking threads. I'm a little underwhelmed by the performance of my 955BE. OCing the GPUs made hardly any difference, but bumping the CPU seems to have had more of an effect. Both runs shown.
Stock:
777.01 KiB
OC:
754.75 KiB
Reply 201 of 241, by cyclone3d
Saving this spot for later.
I am testing on both the SP Demo and the GOG updated full version.
The SP Demo is getting less that 60fps, while the full updated version is getting 80fps on my main rig at 1920x1080 4xAA Very High 64-bit DX10
64-bit also seems a decent amount faster than 32-bit.
So yeah, the SP Demo is complete crap optimization wise.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 202 of 241, by tayyare
I upgraded enough parts in all my modernish PC's during the last year, so I guess a new series of benchmarks are in order.
1. Main Rig: Xeon E5450, 4GB RAM, GTX770 2GB, Windows 7 32bit (was 32.83fps @1920x1050 very high detail and 56.37fps high detail with C2Q Q9550, 4GB RAM, GTX560Ti 1GB, Windows 7 32bit):
640.92 KiB
2. Daughter's PC: Phenom II X6 1090T, 8GB RAM, GTX750 2GB, Windows 10 64bit (was 6.73fps @1920x1050 very high detail and 13.18fps high detail with Phenom II X6 1090T, 8GB RAM, GT710 2GB, Windows 10 64bit):
577.74 KiB
3. My XP Rig: Opteron 180, 4GB RAM, GTX560Ti 1GB, Windows XP SP3 32bit (was 31.34fps @1680x1050 high detail and 35.88fps @1280x1024 high detail with Opteron 180, 4GB RAM, GTS250 1GB, Windows XP SP3 32bit):
327.29 KiB
4. HTPC: C2Q Q9550, 4GB RAM, GT1030 2GB, Windows 7 32bit (no previous test results, was a C2D E8400 with HD 5450, so did not bother at that time to test it):
596.35 KiB
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 203 of 241, by candle_86
tayyare wrote:
I upgraded enough parts in all my modernish PC's during the last year, so I guess a new series of benchmarks are in order. […]
something looks off with your average FPS, it shoudn't be in the 1000's, unless your at 800x600 all low, and then maybe a GTX 1080 could break 1k in Crysis
Reply 204 of 241, by tayyare
Put a period after the first two digits. It's related to our locale settings (number format) in Windows I guess. We use, for example, 1.000,00, not 1,000.00, in where I live. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 205 of 241, by candle_86
Ok that makes more sense 🤣
Reply 206 of 241, by candle_86
My Main rig Ryzen 1600, 16GB DDR4 3200, RX580 8gb 32bit kept crashing, so I did 64bit
898.76 KiB
The i5 Retro Rig, i5 3470, 4gb DDR3 1333, GTX 275
311.29 KiB
Primary XP Gamer x2 4200, 2gb ddr 500, 7900gtx sli
380.66 KiB
Reply 207 of 241, by agent_x007
Pentium 4 3,06GHz @ 3,4GHz (PGA 478), P4i945GC, 2x2GB DDR2 594MHz RAM (CPU-z is wrong DRAM Frequency is 2x FSB speed, not 3:2), "Devil" R9 390X. Windows 7 x86 SP1 (all updates).
Using VSR with Custom Resolutions I did 2560x2048 test with 16xQ MSAA on top.
524.15 KiB
Avg. : 11,65 FPS
Min. : 2,3FPS
Max. : 19,34FPS
Reply 208 of 241, by bakemono
How about Windows 2000? My "low power" desktop with Athlon X2 4850e and Radeon 4550, then my main desktop with Athlon II 260 and Radeon 5670
    642.13 KiB
    422.63 KiB
Reply 210 of 241, by CarlHopkinsUK
Damm I can only just fit everything on the screen at 1280x1024 (yes I only have a 19" monitor).
242.95 KiB
Result from my "main" rig, did better than expected for a C2Q with a frankly rubbish GT710.
However seriously debating changing the GPU out for something older and "downgrading" to WinXP 64 on this, even though there is XP drivers for the GT710 I got issues with XP when I tried a dual boot setup before.
Reply 211 of 241, by candle_86
CarlHopkinsUK wrote:
Damm I can only just fit everything on the screen at 1280x1024 (yes I only have a 19" monitor). […]
I would, I just paid 10 dollars for an 8800GTS 512 which would blow a G710 away.
Reply 213 of 241, by Skyscraper
Here is my main "summer system".
Spec.
i7 3770 (Vanilla "non K" CPU configured to use the maximum 4 extra "turbo bins" allowed for "non K" Ivy Bridge CPUs).
Gigabyte G1 Sniper 2 Z68 motherboard with no working voltage adjustment for Ivy Bridge CPUs, otherwise I would have upgraded to an i7 3770K.
2*4GB DDR3 2133 CL 9-10-10-26 1T.
Asus DCII Geforce GTX 780 ti.
Windows 7 Ultimate with some bloat + MSI Afterburner with OSD and all monitoring modules running.
All power saving options such as all C-states and the like are active.
Windows power scheme is set to "Balanced".
Nvidia driver 391.35.
Result.
1920*1080 - No AA - VeryHigh - DX10 - 32bit.
Avarage 89.385 FPS.
Max 115.17 FPS.
Min 59.96 FPS.
The (non K) i7 3770 is not as fast as the latest generations of i7 CPUs but it holds up pretty well considering it's more than 6 years old.
A faster video card than the 5 year old GTX 780 ti would perhaps add a few FPS but I think this benchmark is mostly CPU limited at 1080p with this system.
I did cut the screenshot a bit as I run a 4k desktop.
462.59 KiB
Reply 214 of 241, by agent_x007
Sure it can with GTX 1080 (not very fast tho) 😁
Low 800x600 DX9
412.81 KiB
Very High 1920x1080 DX10
478.19 KiB
Reply 215 of 241, by Standard Def Steve
That's sad, man. A PIII with a 6800GT runs circles around that machine, at least at 800x600.
787.14 KiB
Reply 217 of 241, by CarlHopkinsUK
Agreed! I have just sourced a GTX650 for £30, and sold the GT710 on for the same - so hopefully the change will be worth it! Il re-bench when it arrives...
Was messing with XP64 today, and as I think someone else mentioned previously im not seeing any benefit over W10.
Reply 218 of 241, by Palladium
This is the oldest platform I can safely test without fear of bad caps:
This system is still unable to play Youtube 720p60 without GPU acceleration, heh. It's also sad a 2017 CPU is barely 2x better than a 2004 microarchitecture in IPC.
Reply 219 of 241, by CarlHopkinsUK
GTX650 arrived and did a quick test on the same settings as before...
256.46 KiB
Quite an improvement, well worth the £30! Will be interesting to see what the switch to a X5460 will make...
