Great PC! But can it run Crysis?
Reply 220 of 241, by CarlHopkinsUK
Did a quick test on the Dell Dimension C521 with Nvidia IGP.... Oh dear 🤣
242.65 KiB
Reply 221 of 241, by CarlHopkinsUK
CarlHopkinsUK wrote:
GTX650 arrived and did a quick test on the same settings as before...
Quite an improvement, well worth the £30! Will be interesting to see what the switch to a X5460 will make...
Installed the X5460 tonight quickly and did another quick run. Up to 57fps from 54fps - so not quite the jump as I got from changing cards unfortunately...
276.47 KiB
Reply 222 of 241, by ynari
Found this thread agan, forgot I'd tested my XP/Windows 8 gaming box back in 2015, new result now it's up to 16GB memory (unusual for a Core2 system) - woo, 1fps increase! Yes, it can run Crysis - just.
553.18 KiB
Gaming PC, revisit
Obviously 'XP settings' would be better, so I decided to ask the question 'Can it run Crysis in stereoscopic 3D using Tridef?'
395.98 KiB
Gaming PC, stereoscopic 3D - 'XP settings'
Getting a bit slow here, dropping below 30.
However, if I leave it on XP settings and drop the stereoscopic 3D, it returns a nicely respectible 48fps average.
Going to try the shader unlock of the 6950 next, and re-run..
Reply 223 of 241, by ynari
Time to bring out the big guns
468.22 KiB
Main system
Yes, it definitely can run Crysis. Better hope so with that spec. Average of 74fps.
Bit useless for me though, as the CRT really is best at 1600x1200. At that resolution you can switch on 16xQ and still get 76fps average.
Reply 224 of 241, by agent_x007
416.42 KiB
Avg. 91,01FPS, Min. 60,81FPS...
When CPU is too slow (61% max. GPU usage 😁), you have to up the resolution.
425.7 KiB
OK, 2560x1600 + 16xQ and GPU still isn't maxed out all the time...
Avg. 84,5FPS (7% perf drop vs. 1080p no AA), Min. 57,48FPS.
Bottom line :
4960X OC + GTX 1080 OC* is OP in Crysis, pls use 4k 😁
Damn... this benchmark doesn't support 4k 🙁
*Adjusted fan curve = OC (because Boost 3.0).
Reply 225 of 241, by Fusion
i7 2600 @ 3.4, 16GB DDR3 1333, ASUS Strix GeForce GTX 970 4GB (+150 core / +450 memory):
878.51 KiB
67.8FPS. Decent I suppose, retail run much, much faster!
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
Reply 228 of 241, by MMX
It seems some tests here was made against the rules.. And i only see third test in the pictures?
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 115.78s, Average FPS: 17.27
Min FPS: 0.92 at frame 201, Max FPS: 28.90 at frame 874
Average Tri/Sec: 16861796, Tri/Frame: 976089
Recorded/Played Tris ratio: 0.94
!TimeDemo Run 1 Finished.
Play Time: 89.17s, Average FPS: 22.43
Min FPS: 0.92 at frame 201, Max FPS: 31.37 at frame 995
Average Tri/Sec: 22224886, Tri/Frame: 990850
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 2 Finished.
Play Time: 87.46s, Average FPS: 22.87
Average Tri/Sec: 22670156, Tri/Frame: 991367
Recorded/Played Tris ratio: 0.92
TimeDemo Play Ended, (3 Runs Performed)
Reply 229 of 241, by matze79
HP z600, Dual Quadcore Xeon, 32Gb DDR3, 512Gbyte SSD, 64Gbyte SSD, GeForce 650Ti 2Gb
Can`t run HD Resolution, only 1280x1024 Screen 😉
236 KiB
Reply 230 of 241, by Munx
A benchmark for an upcoming build log 😀
864.06 KiB
My builds!
The Underdog - The budget K6
Reply 232 of 241, by buckeye
Have not checked but is there a benchmark app for Crysis 2 or 3?
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 233 of 241, by gerry
interesting thread! long too, is there a 32 bit set up that runs crysis adequately, say 1440*900, medium details, 30+fps on average
(I know i ought to just read them all or do my own tests, just wondering if anyone has direct experience of the 'perfectly adequate' 32 bit system for running crysis! 😀 )
Reply 234 of 241, by BitWrangler
Awwww dang, doesn't seem to support PhysX, I had visions of a 2.8Ghz + TbredB boggling minds by sticking a 8400GT PCI in for PhysX support in addition to the prime pixel banger. (Tested that card against a 3Ghz X2 running physX in software and it was 3 or 4 times faster still, even though it's a weak card)
Reply 235 of 241, by DosFreak
I want to say my Radeon HD 4670 (AGP) on my Athlon XP 2800+ played Crysis well enough somewhere around 30fps at 1024-1280x can't remember if med or high details. Hard to remember that far back.
Should probably cleanup this thread and add to first post.
Make your games work offline
Reply 237 of 241, by gerry
just quick follow up, i can play crysis on athlon x2 250 with hd6450 1gb card, that's fairly budget set up circa 2009-11 but the cpu is pretty fast. its at 1600x900 with most details set high, and a couple at medium (like water) and it's very playable. it's the 32 bit version so the Athlon XP2800+ with The HD 4670 example sounds good to me as it's fairly close to top end for 32 bit era, though i don't have a 32bit machine to match that
Reply 239 of 241, by alarchy
Hope the necro is okay. Recently refurbished my 2500k system with a used 980 Ti, and dual boot XP/10 on it.
