First post, by theelf
HI! greetings
I get random hangs in MK2, if i use roland + SB. The game works ok, but at any time crash. Maybe in the intro, or second fight, or in selection screen.... totally random
I have a SB Awe64 and a Roland SC-88
If i use SB or AWE32, no hangs, everything works perfect
Any ideas guys?
Reply 1 of 3, by NightSprinter
Well, the usual goes, but what are the specs of your computer? I can say from experience, however, that the "Roland" option actually is one of the few instances where you need a Roland CM-32L or CM-64. Most of the time for the older games, the "Roland" option is for the MT-32 (and not all MT-32 games would work with a Sound Canvas, due to patch programming). Some, however as mentioned, used the two CM modules which had extra sound effects.
Back on topic, can you post the specs of the machine you're running it on as well as your config.sys and autoexec.bat files? I'm not AS knowledgeable or experienced as some in here, but for helping someone enjoy such a great arcade port I wanna do what I can.
Reply 2 of 3, by NeoVamp
I have a SB Awe32 and MT-32 and it also crashes here, works for a little bit but then BAM!
Pentium 1 - 233MHZ MMX / 96MB / Soundblaster AWE32 / MT-32 / SC-55 / SB-55
Diamond Stealth 64 / Diamond Monster 3D (4MB) / Dos 7.1 / 120GB IDE HDD
Reply 3 of 3, by NightSprinter
Guys, again I need stufd like your system specs, DOS/Windows versions, config.sys, and autoexec.bat files to figure anything out. Many of the more experienced people in this forum will tell you the same.
