FitzQuake for DOS [fxMesa]
First post, by Maraakate
After the fun with Q2DOS and using fxMesa to get 3DFX support working I went ahead and ported QDOS and QWDOS (http://dk.toastednet.org/QDOS) to use it as well. I then proceded to port FitzQuake for even more fun 😈
It's been slightly tweaked for BSP2/PSB2 support and fence textures. This means that Rubicon Rumble Pack and other huge mods will play properly.
I'm not bothering to reimplement 8-bit textures as you really need at least a Pentium 3 and Voodoo 3 (really should be using a V5 5500 IMO) for this port if you're planning to play the larger mods.
Binaries: https://bitbucket.org/maraakate/fitzquake-dos … Z_EXE_LATEST.7Z
Source: https://bitbucket.org/maraakate/fitzquake-dos/
I should mention that all of my Quake DOS projects also included the MPXPLAY library for PCI sound card support. This includes Intel HD audio and some other soundcards. Start the game with the -hda parameter to enable it. It's hit or miss if it works, but if it works in MPXPLAY it's very likely it will work in my ports. So if some of you out there are on some crazy fast modern machines with later generation PCI Voodoo cards I'd love to hear if it works for you, and how fast it is.
Wav and OGG music streaming from QDOS are also imported, as well as WATTCP so you can play it online.
I'm not including any screenshots because it looks the same as FitzQuake. However, do be sure that R_skyalpha is off or you will have severe slow downs in maps (on a Voodoo 3 anyways, untested on my Voodoo 5).
Reply 1 of 86, by __ggorts
I've been using fitzquake-dos and it's excellent work. I also noted your recent work on dmesa which is novel and which provides, at the very least, a welcome test environment. I've been running the Rubicon maps, too.
[As an aside, if leilei is still interested in tinygl, then it may be possible to use dmesa under an alternate name space while linking to tinygl, thereby allows one to address specific functions to tinygl and to dmesa for the remainder. However, this is untested, but q1 provides a good test case to measure the performance and whether tinygl is compatible.]
Reply 2 of 86, by Maraakate
I got DMesa 5.1 working which has some bug fixes, and specifically, it supports the gl_extensions properly according to the changelog. I had some problems in SLI so I didn't use it yet, but the last version of glide3x from the development branch on sourceforge appears to fix these issues. Have to do a bit more testing, but after that and sezeros OK we may move to that version.
Reply 3 of 86, by __ggorts
That is all good news and impressive work. It's difficult to implement what you did since there are little to no examples in a context outside glut demos. 😀 I'm glad to hear that there had been further work on the glide3 library, too. I also look forward to seeing how comparable the resulting screen image is between fxmesa and dmesa.
Reply 4 of 86, by Maraakate
It's more like rather annoying. There are very subtle quirks all around between testing these versions.
CVG (Voodoo 2) hard locks on real hardware with the last glide3x version and sezeros for me when I build it. Can you try to build it from QDOS's mesa51 branch or Q2DOS (master branch) for me? Maybe its a GCC 4.84 issue.
Reply 9 of 86, by __ggorts
Here it is. I'll also test the sst1 to verify the build process.
    glide3_cvg_qdos51.7z
    135.88 KiB
    116 downloads
    glide3 libs for cvg (qdos/mesa51)
Reply 10 of 86, by Maraakate
__ggorts wrote:
Roger. 😀
Edit: FX_GLIDE_HW ?= cvg and export USE_X86 ?= 1
Edit2: took 7 seconds to build!
Changnig the export is unnecssary you can do this
make -f Makefile.DJ FX_GLIDE_HW=cvg USE_X86=1 USE_MMX=1 USE_3DNOW=1 USE_SSE=1 USE_SSE2=1
without having to change makefiles
Reply 12 of 86, by Maraakate
Yes your compile works. Can you do a compile with the make flags I just sent you
Also what is your build environment.
Reply 18 of 86, by __ggorts
And the highly optimized cvg glide3 binary:
    glide3_cvg_qdos51_high_opts.7z
    140.09 KiB
    116 downloads
    glide3 libs for cvg (qdos/mesa51) with all optimizations on
Reply 19 of 86, by __ggorts
I don't think the binary built with all the optimizations yet, even though I ran the command line correctly. However, I'll continue to test the compiles until it shows all optimizations in stdout/stderr while building.
