First post, by squareguy
I found the perfect ATX case but it doesnt have any CD-ROM cover plates, or whatever you call them.
You can tell by the photos they aren't standard but that they are curved. I wouldnt mind a straight plate but you can see how the thin side isnt deep enough for a standard plate.
If you can help locate something please let me know.
The case has a hinged swing-out motherboard tray that is one-piece steel that includes the PCI/ISA slots and backplate.
3.22 MiB
3.28 MiB
2.58 MiB
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 14, by 133MHz
I've had cases with curved fronts but straight covers so one thing doesn't necessarily imply the other. The most important thing is that they actually fit.
You can always chock it full of drives if you can't find appropriate blanks. 😜
http://133FSB.wordpress.com
Reply 4 of 14, by squareguy
Do you have a link for those?
Windows 98 SE
Reply 5 of 14, by alexanrs
Have you tried looking for other cases with similar covers? I have a case with curved covers and I thought I would never find a replacement for a missing one, but a busted PC at my dad's job, despite looking very different, used the same covers, so I just grabbed those. Remember that its more cost effective to re-use little things like bay covers and buttons, so manufacturers designed several different case models around a smaller set of components.
Reply 7 of 14, by squareguy
@alexanrs
Thanks, I have been looking for about a month with no luck so far 🙁
If I throw the case away today and it ends up in the land fill tomorrow, then two days later I will find the correct cover plates. However, if I keep the case then the correct cover plates atoms will spontaneously fly apart if I get anywhere near them hehe.
@emosun
Thanks for the info, I might make those work if I cannot find anything else.
Windows 98 SE
Reply 8 of 14, by alexanrs
Between me needing a bay cover and stumbling upon that busted case more than a year passed, so it can take a while. You can just make those generic covers work for now and replace them down the road if you eventually find the right ones.
Reply 9 of 14, by squareguy
@alexanrs
I will definitely keep looking. I don't mind hunting down the big items but the small finishing touches aggravate me tremendously for some reason.
Windows 98 SE
Reply 11 of 14, by squareguy
Thank you!!! Alexanrs
Windows 98 SE
Reply 12 of 14, by alexanrs
Here you go!
I found out one of my NOS cases I got last week also uses curved bay covers, but with different dimensions. They have the same shape, though, so you could just hot-glue one of these to the case from the inside as a last resort. The two taller cases use the (same) shallower covers.
2.19 MiB
Bay cover dimensions
644.55 KiB
ATX cases
Reply 13 of 14, by Totempole
I have some universal curved beige cover plates which may be suitable. They also double as 5.25" to 3.5" bay converters. They're ventilated, but they should work quite nicely in your scenario. Will post some pictures in the next couple of days.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
Reply 14 of 14, by squareguy
@alexanrs
Thanks, very nice!
@totempole
Look forward to seeing them
Windows 98 SE
