First post, by Oldbitcollector
I've exhausted my "Google-foo" today trying to get this accomplished.. I apologize if this question is out of line in Marvin.
Does anyone have a registry fix or patch for completely disabling the "Windows Keys" in Windows 98SE?
I'm trying to make my retro box a little more "family friendly" for those in my house that may want to play DOS games.
Thanks!
Reply 1 of 4, by Thandor
Haven't tested it myself but perhaps you can use: http://www.dev-labs.com/kr/keyboard.html
If it doesn't work you can try (if you want at least) to disable the Windows Key on hardware-level. Perhaps you can pop off the Windows Key and remove the 'touch pad' underneath it or use tape to tape-over the traces on the PCB.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 3 of 4, by HighTreason
Make an 'n' shaped piece of card and place it over the key. It should sit in such a way that it prevents the key being easily pressed by accident without first crushing the cardboard.
