Reply 80 of 89, by karakarga
Really good examples. But, using a real old car is something like, you can not drive it at roads. You need to have a special paper first, and it is for a short time only, for filming purposes or transporting etc. It can not give you the real comfort. My mom has a 1965 fastback Mustang, I have bought it a better alternator https://www.ebay.com/itm/173286094641 well, but what about an air condition? Very difficult, I have lately heard some people are successful at fitting, but really difficult. https://www.classicautoair.com/shop/complete- … tioning-system/ I really need to work for it hard, later. Then what, at an emergency, can you simply call Ford from car audio system, no. There are in the end some limits. But, this is a car, not a computer, a computer needs digital highway, not an ordinary road. So, if a computer is slow, you can not change everything.
I have my oldest Compaq ProSignia 486, on board SCSI good, but slow 50 pin. I have Compaq QVision 1280/E with 2 MB ram, no more from Compaq for EISA. At most can be add a Matrox 4MB but very difficult to find. Any 16/9 resolution support is not present in anyway, so no good monitor support. There is an empty 40 pin 512kb ram place for the onboard Cirrus Logic GD5420, I will try to solder a Texas Instruments TMS45165DZ -70 ram at a spare time, maybe I can reach to 1 MB onboard, risky if things go wrong, board may die, here trying to force it is equal to playing Russian roulette, the place may be for an additional 512 kb or replacement place for the 4 piece 44256 chips on board .There is no mainboard documentation, 40 pin ram connections seems OK according to TI TMS45165DZ -70 chip datasheet, for the chip three VSS pins must remain at left side and three VCC pins remain at right, for the bottom picture pin number one orientation of the ram, is at the low right side. Total system ram 128, no more option, no speed increase. Processor, up to Pentium Overdrive 83 MHz, or AMD 5x86-133, or Cyrix 586-120 etc. Those are more than a 1 to 10 thousand times slower than todays processors, a good way to dig with a pin.
I am a good repairer nevertheless, at Pandemic days I have repaired an Intel i815 D815EEA, an AMD A7V, a Slot1 Asus P3V4X, a Matrox G100 by bios rescue, a NEC PCI USB 2.0 card, an Intel 850E 478 pin EMV850E mainboard etc. But, those are only for fun, how long did I use them after repair? Not much. Except Intel 850E chipset one, they can not enter into internet from known browsers, only Firefox continues to support on Windows 7 for 478 pin SSE2 processors.
In conclusion, those 486 to Pentium III mainboards are not possible to go into digital highway, no permission slip for them are possible. 😀 I hope, there won't be a a real bad sun explosion, which can kill from most newer to older, electronics stuff. I don't want to see, only old stuff left remained, but they may die as well. Those old one's are really too far away from handling our todays needs, have a go for a 4K film watch with them, no of course. Besides, I am a Radio, TV & Film studies graduate from year 2000. I don't want to watch anything from Betamax & VHS cassettes on a tube TV.
I want to close the discussion here, I really like old computer stuff as well like the people here at vogons.org, but I like to use new ones better.
New toys always welcome!
    104.61 KiB
Reply 81 of 89, by chrismeyer6
karakarga wrote on 2023-02-26, 18:25:
Really good examples. But, using a real old car is something like, you can not drive it at roads. You need to have a special pap […]
Really good examples. But, using a real old car is something like, you can not drive it at roads. You need to have a special paper first, and it is for a short time only, for filming purposes or transporting etc. It can not give you the real comfort. My mom has a 1965 hatchback Mustang, I have bought it a better alternator https://www.ebay.com/itm/173286094641 well, but what about an air condition? Very difficult, I have lately heard some people are successful at fitting, but really difficult. https://www.classicautoair.com/shop/complete- … tioning-system/ I really need to work for it hard, later. Then what, at an emergency, can you simply call Ford from car audio system, no. There are in the end some limits. But, this is a car, not a computer, a computer needs digital highway, not an ordinary road. So, if a computer is slow, you can not change everything.
I have my oldest Compaq ProSignia 486, on board SCSI good, but slow 50 pin. I have Compaq QVision 1280/E with 2 MB ram, no more from Compaq for EISA. At most can be add a Matrox 4MB but very difficult to find. Any 16/9 resolution support is not present in anyway, so no good monitor support. There is an empty 40 pin 512kb ram place for the onboard Cirrus Logic GD5420, I will try to solder a Texas Instruments TMS45165DZ -70 ram at a spare time, maybe I can reach to 1 MB onboard, risky if things go wrong, board may die, here trying to force it is equal to playing Russian roulette, the place may be for an additional 512 kb or replacement place for the 4 piece 44256 chips on board, there is no documentation, ram pins connections seems OK according to TI TMS45165DZ -70 chip datasheet for the 40 pin chip, VSS pins must remain at left side and VCC pins remain at right, for the picture pin number one orientation of the ram is at low right side for the attached picture at the bottom. Total system ram 128, no more option, no speed increase. Processor, up to Pentium Overdrive 83 MHz, or AMD 5x86-133, or Cyrix 586-120 etc. Those are more than a 1 to 10 thousand times slower than todays processors, a good way to dig with a pin.
I am a good repairer nevertheless, at Pandemic days I have repaired an Intel i815 D815EEA, an AMD A7V, a Slot1 Asus P3V4X, a Matrox G100 by bios rescue, a NEC PCI USB 2.0 card, an Intel 850E 478 pin EMV850E mainboard etc. But, those are only for fun, how long did I use them? Not much. Except Intel 850E chipset one, they can not enter into internet from known browsers, only Firefox continues to support on Windows 7 for 478 SSE2 processors.
In conclusion, those 486 to Pentium III mainboards are not possible to go into digital highway, no permission slip for them are possible. 😀 I hope, there won't be a a real bad sun explosion, which can kill from most newer to older, electronics stuff. I don't want to see, only old stuff left remained, but they may die as well. Those old one's are really too far away from handling our todays needs, have a go for a 4K film watch with them, no of course, besides I am a Radio, TV & Film studies graduate from year 2000. I don't want to watch anything from Betamax & VHS on a tube TV.
Three years ago I helped a friend of mine install a AC kit from vintage air on his 67 mustang. It's was a very simple straight forward job took us less than 3 hours start to finish. We finished a full 100% restoration of the car in less than two years just working on it when we had some spare time.
Reply 82 of 89, by CoffeeOne
🤣. A Compaq QVision 1280/E is also VERY hard to find.
Reply 83 of 89, by karakarga
I meant very old cars, 1900 around. Thanks for the info, it looks difficult a bit. I will see....
Yes, I think so, QVision 1280/E is also very expensive, finding a 4 MB Matrox EISA card is almost impossible.
Reply 84 of 89, by chrismeyer6
karakarga wrote on 2023-02-26, 22:51:
Any time. What I liked about the Vintage Air kit is it's completely bolt in and it comes with every bracket and all the hardware. There is no fabricating or custom work needed at all.
Reply 85 of 89, by CoffeeOne
Hello,
Would you be so kind and make a good picture of your QVision 1280/E?
or is the discussion now only about cars? If yes, please feel free to ignore the request.
Reply 86 of 89, by dj_pirtu
Just got my first PODP5V83 after long hunting... And of course it won't do 100MHz as I hoped, posts but crash instantly when booting/after boot.
Now I'm thinking will I take the road to modify the CPU (original heatsink is long gone anyway) or just keep it that way...
By the way, it's missing that fourth capacitor.
Reply 87 of 89, by cloverskull
Wow, this thread has two things that interest me:
The Pentium Overdrive (which I have running at 100mhz seemingly stable but am curious what folks here can squeeze out) and classic Mustangs, of which I have a ‘68 that I’m restoring 😀 The exterior and all mechanical parts are done. Now it’s just the interior left. Woot!
Reply 88 of 89, by dj_pirtu
Got the POD to 4 volts and it's almost stable at 100MHz but in long term testing it will eventually crash.
Bought another one and hoped it would overclock easier but of course with my luck it's the same thing. Won't even boot at 100MHz.
I think I'll just give up with these and use at default clocks...
Reply 89 of 89, by maxtherabbit
Any thoughts on whether this would affect the stability of the BIU and not necessarily the core?
I've got a POD63 where it is particularly sensitive to bus speed and won't run stable at or above 33MHz FSB even with the multiplier forced to 1x
