CD Drive repair?
First post, by pewpewpew
Now that we're getting past the point where these are dropping off trees, I'm becoming reluctant to bin the failed units. Perhaps we could have a thread of congealed VOGONS repair wisdom?
I'm afraid I stop at the obvious: Check cables. Check pins. Open & clean out the guck. Eyeball any elcos along the way, and also the switch solder pads for cracks.
Are there other general tasks one can do, before it becomes a model-specific search through the repairfaq & ilk?
(Actually, the repairfaq is dated but full of nicely organized advice, so let's link it now.
http://www.repairfaq.org/REPAIR/F_cdfaq.html
Reply 1 of 1, by bjt
It really depends on what's failed. If plastic gears in the mech have stripped themselves or the laser is burnt out/lens is damaged there's not much you can do without a donor unit. I did fix a NEC drive once where the arm that holds the lens carriage to the rails snapped off. Just superglued it back on and it worked OK after that.
