Reply 40 of 46, by feipoa
saturn wrote:
I'm working on getting a pair of Tualatins for the system. But ABit has a funny setup the prevents the SMP pin mod was being stable and the normal pin mod from working in smp and I gave up my self. After talking to the guy in korea the sells pre modded Tualatins He was able to make 2 for my board. It was kind of annoying to get everything worked out, with language barriers and having to send Hi Res photos of various parts of the board and all. ABit did a good job of making changes to the vp6 without changing the Rev# 😒
What did the pin mod guy have to do differently to these particular Tualatin's compared to what he normally does?
Reply 45 of 46, by kanecvr
You could pin-mod the CPUs... by removing some pins you can get the CPUs to work in your board if it allows you to manually set CPU voltage by jumpers or from bios. My MSI 694D PRO2 allows for this so I can run my tualeron @ 1333Mhz - 1.675v or 1GHz @ 1.45v
