Reply 20 of 33, by theelf
- Oldbie
wrote:Thanks, the MIDIs look (and sound) very similar. This issue becomes even more interesting 😀
Thanks to you, i hope i can do more to found the problem. If more midi files, or test help in something, i will be happy to help
One thing is sure, that more complex is the music using custom patchs, more fail. For example Final Fight music with munt, sound much more similar to original MT-32 that the ones in Castlevania
Final Fight dont even do custom patchs i think
3 years ago, i remmeber i had a problem with munt, that dont work in my athlon without SSE2, and you helpme a lot 😀 this athlon machine still working with dosbox and scummvm
