Reply 40 of 46, by KT7AGuy
GuyTechie wrote:
Can you replace the setup EXE with something that can still execute but not do anything? Like notepad.exe
It looks like the disc image is now available on VOGONSDrivers:
http://www.vogonsdrivers.com/getfile.php?file … &menustate=52,0
I don't have any pending Win98SE builds to test this out on. If I get some time to play around, I'll test it out for fun. Of course, you could always try it out too.
Ideally, if this worked, it would make a nice official auto-update utility.
Reply 41 of 46, by dr.zeissler
The Bios has no Option for Deactivating ACPI, but I think I can deactivate it in Win98se
Dos=high does not work. It's alway vmm32.sys activatet. If I add himem.sys to the config.sys
it simply does not change anything.
    4.28 MiB
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 42 of 46, by KT7AGuy
I don't think you can deactivate ACPI in Win98SE once it is already installed. The only way to do it is during installation:
setup.exe /p i
Reply 43 of 46, by dr.zeissler
I changed the config.sys. "Emm386 ram I=b000-b7ff i=e000-efff frame=e000". Now it works with ems.
Reply 45 of 46, by dr.zeissler
x300 shared ati gfx and because of mostly no sound it's only about some demos and pc-beeper stuff.
Reply 46 of 46, by rishooty
Wasn't expecting my old thread to get necro'd, interesting.
mr_bigmouth_502 wrote:
That Geforce is gonna bottleneck your C2Q big time. What games do you plan on playing?
Well, you were entirely correct. I eventually went to a geforce 6800, then a geforce 7800 when I redid it and got the unofficial drivers working.
For those curious, with rlowe's patches and a number of other tweaks, I got the rig working perfectly. Unfortunately, due to quite a number of life events and changes of interests, I decided to part it out and sell it on eBay as I'm currently doing. Compatibility of Win7/10/What games don't have fixes. Had absolutely nothing to do with its effectiveness, I worked beautifully with dos, windows ME(how I solved the problem of this thread, its far easier and has far less patching options while benefiting more from them.), and XP in every game I tested. I just hated the fact that I needed a dedicated desk, and was trying to reduce the physical presence of nostalgia/vintage hardware from my bedroom in general. I'm basically replacing all of said hardware with an extremely small XP/win10 mini itx for emulation and a low maintenance vintage pc gaming os. At the same time I regret nothing, I've learned a lot and I had more fun with the challenge than the actual finished product.
I also agree that the uploaded cd looks like it would be pretty damn useful for future builds if it works.
