First post, by Marquzz
After scouring the Internet for a couple of days, I just have to ask here. Do any of you have, or know a place where I can download different bios versions for Asus K7M?
I recently flashed the bios to try something and in my rush I missed backing up the one I had. I did not take note of which version it was either. I've found a beta bios (1013) and versions 1007 and 1009, but I wish to try other versions as I'm not happy with these.
I would be forever greatful
Reply 1 of 11, by swaaye
Rank Moderator
Moderator
http://web.archive.org/web/20050214165907/htt … snet.co.za/k7m/
here is a download location for the last release.
http://dlsvr01.asus.com/pub/ASUS/beta/mb/bios/km132.zip
Possible source for the AMI 8.27.13 flash utility
http://zakrzewski.tk/bios.html
Reply 2 of 11, by mockingbird
Here are a few, but I think that for anything earlier than 1006, you'll need a dump off of a chip.
km1006.zip
133.43 KiB
37 downloads
km1209.zip
145.15 KiB
40 downloads
km1008.zip
146.89 KiB
38 downloads
Reply 4 of 11, by Marquzz
mockingbird wrote:
Here are a few, but I think that for anything earlier than 1006, you'll need a dump off of a chip. […]
km1006.zip
km1209.zip
km1008.zip
1008 version was probably the one I had before, I'm back with my old benchmark scores and stability, thank you again 😀
Reply 6 of 11, by Marquzz
swaaye wrote:
What problems did you have with the other versions you've run? Do you know which chipset revision you have?
I have board rev 1.04. I've yet to lift the HS on the NB, so I don't know exactly what chipset revision it is, but it's a newer one since it has super bypass.
The problem I had was that one version, 1007, gave me one less MHz in FSB overclock (from 107 down to 106). The other two, 132 beta (latest) and 1009 gave me less 3DMark99 score, down från ~8100 to ~7700. Don't ask me why, have not seen such difference in any board ever just from changing bios version. 1008 is clearly the winner with stability at 107 MHz and higher score in 3DMark.
Reply 7 of 11, by elianda
Are you aware of the Irongates "Super Bypass" mode for memory access? (chipset revision C5 or newer)
Most BIOSes activate it when TRCD <3 and TRC <8.
Safe Default timings are: TCL 3, TRP 3, TRCD 3, TRC 8, TRAS 7, PH 32, IC 8 cycles.
Also: http://www.heise.de/ct/hotline/Speicher-Timin … rds-307644.html (may req. translate)
Youtube Channel
Reply 8 of 11, by Marquzz
elianda wrote:
Are you aware of the Irongates "Super Bypass" mode for memory access? (chipset revision C5 or newer) Most BIOSes activate it whe […]
I'm not sure what you want to say? You mean that the instability could be caused by super bypass? I have RAMs capable of 170+ MHz in CL2 installed now. I could also enable and disable super bypass, so it's not something I cannot control. What I've read, you should have super bypass enabled for the extra performance.
Reply 9 of 11, by elianda
I wanted to say that for super bypass to work you need to set memory timing values within certain limits.
I also wanted to quote that the irongate could have stability problems with RAMs.
Youtube Channel
Reply 11 of 11, by havli
It is possible RAM timings can decrease board stability, I guess it depends on the PCB layout. Luckily my MS-6195 can run CL2-2-2-2 (with Super Bypass enabled) just fine.... well, or at least it is stable enough for 2 hour long SuperPI run. 😀
http://hwbot.org/submission/3088193_havli_sup … 3min_2sec_338ms
