EF2000 for DOS with 3DFX patch
Reply 80 of 97, by janskjaer
As predicted, I installed EF2K and TACTCOM under DOS 6.22 of my Retro Rig. I then booted onto my Win95 partition to install the Graphics+ patch.
So I copied the tactpat.exe to the EF2000 directory (I can access my DOS partition) and ran the patch. Same error message:
"please copy to the tactcom directory".
Does the tactpat.exe have to be in a specific directory before being run?
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
Reply 81 of 97, by kekko
I had the same problem. try running this version of the patch
http://www.gamefront.com/files/906943/tacpatg.zip
if the one above fails, try this
http://www.gamefront.com/files/899273/tacpatf.zip
Reply 82 of 97, by janskjaer
kekko wrote:
I had the same problem. try running this version of the patch http://www.gamefront.com/files/906943/tacpatg.zip if the one above […]
Hi, I tried both of these patches from The Patches Scrolls website. No luck. Still the same problem. I really don't get it and this is rather frustrating.
Is someone able to run both versions (3dfx and Verite) of the patch, extract the files, then zip them up and share them?
:64MB EDO
:DOS 6.22/Win95b
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
Reply 84 of 97, by janskjaer
I ran a full install from the EF2000 installation:
What is EF2000 H.D?
I wasn't sure if I could post such a long list of files, so apologies beforehand:
EF 2000 installation:
&NUL
ADLIB.MDI
ADLIBG.MDI
ADRV688.DIG
AILDRVR.LST
CFG
CLUMP_3.TXT
CLUMP_SS.TXT
CONF.EXE
CONFIG.BAT
CONFLICT.CG
DIAGNOST.EXE
DID.DAT
DIG.INI
EF2000.AD
EF2000.BAT
EF2000.CFG
EF2000.OPL
ESFM.MDI
IFF
JAMMER.DIG
MDI.INI
MISSION.CFG
MISSIONS
MPU401.MDI
MT32MPU.MDI
NAVIG.NAV
NULL.MDI
OPL3.MDI
PAS.MDI
PASPLUS.MDI
PCSPKR.MDI
PROAUDIO.DIG
RAP10.DIG
SB16.DIG
SBAWE32.MDI
SBLASTER.DIG
SBLASTER.MDI
SBPRO.DIG
SBPRO1.MDI
SBPRO2.MDI
SETSOUND.EXE
SNDSCAPE.DIG
SNDSCAPE.MDI
SNDSYS.DIG
TANDY.MDI
ULTRA.DIG
ULTRA.MDI
UNIVBE.DRV
UVCONFIG.EXE
VER
_EF2000.EXE
CFG\COL
IFF\256
IFF\256\COLCDSCR.LBM
IFF\256\GAMOPTS.LBM
IFF\256\INORGEOG.LBM
IFF\256\INORJSTR.LBM
IFF\256\INORMAST.LBM
IFF\256\INORPOL.LBM
Show last 2 lines
MISSIONS\COL
I then installed the TACTCOM update:
Here is the list of files after the TACTCOM update:
&NUL
ADLIB.MDI
ADLIBG.MDI
ADRV688.DIG
AILDRVR.LST
CFG
CLUMP_3.TXT
CLUMP_SS.TXT
COMMS.CFG
CONF.EXE
CONFIG.BAT
CONFLICT.CG
DIAGNOST.EXE
DID.DAT
DID1ST.DAT
DOS4GW.EXE
EF2000.AD
EF2000.BAT
EF2000.CFG
EF2000.OPL
ESFM.MDI
IFF
JAMMER.DIG
JOYSTICK
MDI.INI
MISSION.CFG
MISSIONS
MPU401.MDI
MT32MPU.MDI
NAVIG.NAV
NORWBIN.LBM
NULL.MDI
OPL3.MDI
PAS.MDI
PASPLUS.MDI
PCSPKR.MDI
PROAUDIO.DIG
RAP10.DIG
SB16.DIG
SBAWE32.MDI
SBLASTER.DIG
SBLASTER.MDI
SBPRO.DIG
SBPRO1.MDI
SBPRO2.MDI
SETSOUND.EXE
SNDSCAPE.DIG
SNDSCAPE.MDI
SNDSYS.DIG
TANDY.MDI
TFXSAV.99
ULTRA.DIG
ULTRA.MDI
UNIVBE.DRV
UVCONFIG.EXE
VER
_EF2000.EXE
CFG\COL
IFF\256
Show last 19 lines
IFF\256\GAMOPTS.LBM
IFF\256\INORPOL.LBM
JOYSTICK\F16
JOYSTICK\F16-TQS
JOYSTICK\F16-WCS
JOYSTICK\F16\EF2000.B50
JOYSTICK\F16\EF2000.BAK
JOYSTICK\F16\EF2000.M50
JOYSTICK\F16-TQS\EFA_TQS.B50
JOYSTICK\F16-TQS\EFA_TQS.BKP
JOYSTICK\F16-TQS\EFA_TQS.M50
JOYSTICK\F16-WCS\EFA_WCS.B50
JOYSTICK\F16-WCS\EFA_WCS.BAK
JOYSTICK\F16-WCS\EFA_WCS.M50
MISSIONS\COL
Here are the file differences before and after update:
COMMS.CFG
DIG.INI
DID1ST.DAT
DOS4GW.EXE
JOYSTICK
NORWBIN.LBM
TFXSAV.99
JOYSTICK\F16
JOYSTICK\F16-TQS
JOYSTICK\F16-WCS
:64MB EDO
:DOS 6.22/Win95b
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
Reply 86 of 97, by janskjaer
I've given you the list! It's in my previous post, in the first codeblock. That list of files came from using the DIR command.
:64MB EDO
:DOS 6.22/Win95b
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
Reply 88 of 97, by Gamecollector
Hmm... By the way, DosBox set the file creation dates (the result of the copy command etc) as the current date, not the original date. Duke Nukem 3d: Plutonium Pack is the known victim of this error. Maybe the tactcom patch is the same?
Reply 89 of 97, by Gamecollector
Files in the "EF 2000 2.0 DOS" directory (attached),
    list.txt
    4.99 KiB
    406 downloads
    dir /s
Reply 90 of 97, by janskjaer
I've included a DIR list of both my installation of EF2000 and then another following the TACTCOM update.
Unfortunately, it won't show you what you are looking for.
Surprisingly, a fresh install from the CD in either real DOS or Windows 95, installs the game files and uses the current date/time as the modified date.
Interestingly, when I look at the Created date of these files in Windows 95, it's reported as "(unknown)".
The TACTCOM update did the same thing.
This is really bizarre. It's the only game I have installed on my system where the files take the current date as the Modified date.
I've attached a DIR of my EF2000 CD also.
    ef2000.txt
    3.65 KiB
    394 downloads
    EF 2000 DIR
    tactcom.txt
    5.12 KiB
    378 downloads
    TACTCOM DIR
    ef2000cd.txt
    3 KiB
    389 downloads
    CD DIR
:64MB EDO
:DOS 6.22/Win95b
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
Reply 92 of 97, by janskjaer
"Patch nicht moglich 'C:\EF2000\_ef2000.exe' Datei ist anders
Erforderliche Grosse".
In other words, this is the German TACTCOM and GFX patch.
If you didn't notice already, I mentioned that I'm using the UK English version of the game.
Also, the 'g' in 'tactpatg' in the URL gave it away! 😉
So, this quest goes on ....
Has anyone else encountered the 'please copy to the tactcom directory' problem when trying to run the Graphics+ patch when applying to the EF2000 UK + TACTCOM installation?
:64MB EDO
:DOS 6.22/Win95b
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
Reply 93 of 97, by Gamecollector
Ok. after I replace my "EF2000: Tactcom" cd - the patch now is installing correctly.
http://img600.imageshack.us/img600/4650/tactcom.jpg
Now there are 2 other troubles with the game.
1) Music and Digital sound diagnostics is failing. "SPAWN ERROR" or no sound at all.
2) Crash at startup:
C:\EF2000>ef2000.exe
GFX+ 3DFX version 7.13
Found 47,692K bytes of memory
clamp: no file `.\3\paul.3` - Solved. Delete the files clamp*.* in the game dir.
Also found this:
Copy To TACTCOM Directory Error If you receive the following message after choosing either 3Dfx or Rendition Verite, it is p […]
Rendition Verite, it is probable that you have run TACTCOM before
installing the upgrade. To rectify this, simply repeat the Installation
procedure again. Remember! Do not run TACTCOM or set up the Preferences
before you install the upgrade!
Reply 94 of 97, by damocles
I had successfully installed ef2000 + tactcom + 3dfx patch some time ago.
Now t try to remember...
ok, try this:
- Install EF2000, use default directory, don't change path and don't start/config the game.
- copy tactom file into ef2000 directory and start it (after patch, don't start/configure the game)
- copy 3dfx patch into ef2000 directory and start it.
if you use different path, you will have problems.
Reply 95 of 97, by vetz
Had the same issue as janskjaer when I wanted to test out this game after so many years with DosBox.
Whatever I did I got the: "please copy to the TACTCOM directory" error.
Solution:
1. Do a clean install of EF2000. Do not run the game or any config.
2. Get the original german _ef2000.exe file and overwrite the english _ef2000.exe (I've included it as an attachment)
3. Run Kekko's Tactcom patch. Thanks to Kekko for reuploading it: http://www.mediafire.com/?1fmzf411k6ufq15
4. Run german to english 3dfx/rendition patch:
I ran all the files in Windows XP with no problems. Do not run the 3dfx update in Windows 7 64 bit, as you will get an error and you have to start all over. The game will be in english when you are done!
When you run the game you might get a memory error in DosBox, but just set memory to memsize=48 in configuration. Next error that showed up was: clump: no file `.\3\paul.3` but here just delete both clump txt files in the game directory. (thanks gamecollector)
EDIT: ALTERNATIVE BETTER SOLUTION on clump: no file `.\3\paul.3 error
To avoid deleting the files entirely (with unforseen consequences in gameplay), just remove "paul" "paulpaul" and "temp_83" from CLUMP_3.TXT
Next enjoy the game 😀 While you install and get ready I can recommend this excellent video by someone who know how to fly in this game:
http://www.youtube.com/watch?v=FBBuQjmzT2E (Just too bad that the soundtrack that follows the game sucks compared to the one featured in this video. I might need to get hold of Spy Game OST and make an audio CD)
    _EF2000.EXE
    1.44 MiB
    869 downloads
    German _EF2000.EXE
Reply 96 of 97, by tincup
Late to the party but here goes:
I have the Ef-2000 V2 edition with Gfx+. It runs great in W95 on a Rendition Verite or Voodoo 1/2 card. I've up-gunned to a Vodoo2 SLI and have run into difficulties. Most of the time it goes to black screen loading a mission, but every so often the mission loads, but with pronounced color distortion. I seem to recall EF had issues with SLI, but I wonder if the 'fallback' V1 autoexec.bat file envoronmental variables work with V2s in SLI? Or maybe addional variables are needed as it's SLI?
Reply 97 of 97, by vetz
Try the regular batch file of enviromentals. set SST_SLIDETECT = 0 will disable SLI.
Google turned up this:
SET SSTV2_GRXCLK=90
SET SSTV2_FT_CLK_DEL=0x4
SET SSTV2_TF0_CLK_DEL=0x6
SET SSTV2_TF1_CLK_DEL=0x6
SET SSTV2_VIN_CLKDEL=0x1
SET SSTV2_VOUT_CLKDEL=0x0
SET SSTV2_TMUMEM_SIZE=2
SET SST_SLIDETECT=0
SET FX_GLIDE_SWAPINTERVAL=0
SET SSTV2_SCREENREFRESH=60
SET SSTV2_FASTMEM=1
SET SSTV2_FASTPCIRD=1
SET SSTV2_SWAP_EN_WAIT_ON_VSYNC=0
SET FX_GLIDE_NO_SPLASH=1
EF2000.EXE
