Bought this (Modern) hardware today
Reply 1560 of 2072, by ODwilly
Helped a buddy price out a Ryzen 5 5500 B550 setup for his wife. He is going for a Radeon 6600XT, 16gb of ddr4 3600 and a 1tb ssd
Reply 1561 of 2072, by Brawndo
cyclone3d wrote on 2022-05-04, 18:42:
Got these for an upgrade to my main system. Ryzen 9 5950x - new 64GB DDR4-3600 CL16 ASUS ROG Strix x570-e motherboard with EK mo […]
Ryzen 9 5950x - new
64GB DDR4-3600 CL16
ASUS ROG Strix x570-e motherboard with EK monoblock.
Also ordered 2x more fans to complete the push/pull water cooling setup this system will have.
You're going to love that system. My main desktop I built a year ago is a 5950X on an ASUS Crosshair VIII Dark Hero mobo with an Optimus water block and Swiftech Mcp655 pump, and a slew of Noctua fans on Corsair radiators. It's ridiculous how powerful and fast the system is and it never breaks a sweat no matter how hard I push it.
Reply 1562 of 2072, by TrashPanda
Brawndo wrote on 2022-05-16, 03:42:
Ryzen 9 5950x - new
64GB DDR4-3600 CL16
Sounds like you need to throw more chrome tabs at it 😂
Reply 1563 of 2072, by bjwil1991
Bought 3 external USB optical drives. 1 of which is a Blu-Ray writer and the others are standard DVD-RW drives.
142.38 KiB
50.04 KiB
39.87 KiB
Reply 1564 of 2072, by Intel486dx33
My old WD NAS Drives were getting slow and old so I purchased some NEW Ones before the old ones die.
Also some external USB portable hard drives for backups.
I like to have multiple backups incase some of these old drives die.
These NAS and USB backup drives are inexpensive too.
I have 4tb WD MyCloud NAS drives
And 5tb WD External Portable USB hard drives.
These are large enough for retro software and games.
I Strongly urge you guys to backup your important data.
I use my NAS drives to store all my retro software, games, and music.
Its just easier to install software and games over the network.
Reply 1565 of 2072, by BitWrangler
Got some old/new junk that will be "Modern" purposed more than retro, three 128GB SSDs will speed a few things up, AV500 powerline units to bridge office to the cable mofodem. Couple of 2GB sticks DDR3, which I hope my 775/DDR3 box will like. Gigabyte HD7750 1GB OC, yay, giraffics chore necks one point oh! Vulkan 1.2 it's the minimum minimum for minimal minimalism on post windoze se7en carp. Well yah, it's about Vega 7 or 1010-1030ish ballpark still. Also got the weirdest J1900 ITXish board in existence... it's got like a bank of 10 SATA ports, and just in case you were running out of SATA ports, one on the board too, and an mSATA, because obviously you needed one of those instead, but what if you don't just wanna waste all your SATA ports on boot drives? It's got you fam, there's internal USB port for a boot drive. (Rumors say it only boots off mSATA and USB but by the look of this variant, the lone mid PCB SATA one might) it seems like it should be surprisingly grunty for a 10W chip, like fast C2D speed, though it takes twice as many cores to do it. Anyhoo, some purpose will arise for it I'm sure... possibly I'll even plug SATA drives into it. Meant to be not quite ITX, thinking about a Dell case that's unemployed that's not quite ATX, match made in heaven or what?
edit: Oh used SSD pile has Samsung 850 EVO, Samsung/Lenovo PM871, Sandisk X300... if anyone has any particular utils or updates to suggest applying to make them "almost as good as new" then I'd appreciate the tip.
Reply 1566 of 2072, by SteveC
My keyboard has died so ordered one of these, only £31 on Amazon at the moment. I've always been a big fan of Microsoft keyboards and mice, but I hate the fact the wireless ones are paired to the dongle and there's nothing you can do if you break/lose the dongle or want to replace just the keyboard or mouse.
    61.36 KiB
Reply 1567 of 2072, by bjwil1991
Bought a Perixx Periboard-322 keyboard/trackball/backlit combination for my work laptop since the MSTE and the other keyboard I used need repairs.
1.09 MiB
Reply 1568 of 2072, by bjwil1991
Bought an ASUS Prime X470-Pro with a Ryzen 5 2600 and fan, I/O shield, and 16GB DDR4-4400 RAM for $253.96 altogether (secondhand).
The board/CPU and RAM are from shopgoodwill.com and the I/O bracket from eBay.
My main desktop will finally get a major upgrade after 7 years of being on an AM3+ build.
Reply 1569 of 2072, by bestemor
A warm welcome to the X470 club ! 👌
Hope those RAM sticks didnt cost too much though, as you'd be lucky to make them work at even 3400mhz.... 😆
And, as a bonus, you can install Windows 7 on this one, for years of retro goodness !
(I have done it on mine, and plan to keep it there for the next 30+ years...)
PS: ...goodwill are not cheap these days I see, not even a Ryzen 2600X for that kinda money ?
Reply 1570 of 2072, by bjwil1991
Not even.
This board can take the Ryzen 9 5900X easily.
https://www.asus.com/supportonly/PRIME%20X470 … O/HelpDesk_CPU/
Reply 1571 of 2072, by liqmat
bestemor wrote on 2022-06-13, 11:58:
The X570 chipset will also work with Windows 7 (and I'm guessing the very last AMD chipset that will) since you can use AMD's X470 chipset drivers on a X570 board without issue. You still need the hacked USB 3.x drivers and the Microsoft NVMe driver of course. What I found, though, was my slipstreamed Windows 7 install CD did not work on the X570 board like it did on the X470 board (USB keyboard/mouse and NVMe not detected). How I got it all working on the X570 board was using a clone image from my X470 system that was setup in Windows 7 64 already. The X570 system literally booted right up from the cloned X470 system HDD image without issue. The source X470 board was an ASRock Fatal1ty X470 Gaming-ITX/ac and the target X570 board was a Gigabyte X570SI AORUS PRO AX (rev. 1.1). So it even worked across manufacturers which was a nice bonus. Just a FYI for anyone wanting to install Windows 7 on these platforms.
On all of these boards I did have to replace the M.2 WiFi card with something Windows 7 compatible (Intel Dual Band Wireless-AC 8265). Also, the LAN interface on the Gigabyte ITX board has no Windows 7 driver so you are stuck with getting a Windows 7 compatible USB LAN option. Everything else works and has native Windows 7 drivers including the integrated sound. Of course NVidia's 3000 series GPUs will also be the very last of their product line to support Windows 7 as well. So if you want a platform that is still pretty much Windows 7 compatible and new in box this would be a good time to purchase before it all gets retired and the Ebay prices go through the roof on any NIB leftovers.
Good info here.
Reply 1572 of 2072, by bestemor
@liqmat; what CPU did you use on this then ??
And how do you like/experience it vs whatever cpu you had in the X470 board - big/small reall world difference ?
(as I've read all kinds of warnings about going over the 2000 series or a certain AGESA version, and really want as little potential hassle/risk/instability as possible, sacrificing some minor? speed/cpu power in the process)
And, what benefits are there really, in your opinion, of the X570 vs X470, when using Windows 7?
I suppose if you can safely(?) use say a 5800X cpu, you also benefit from faster RAM options, but... if focused on gaming, will you notice it much on the (low core) games that are actually supported on Win7 ? (all the new fancy games require DirX 12 apparantly, limiting them to Win10/11+)
As for LAN , Wifi, and whatnot, I have no real need for that. This will most likely remain an air gapped static gaming PC with no internet.
(no Steam in sight... 😋 )
And yes, funny you should mention it - I am trying to 'stock up' (oh man, those prices....!) on decent Nvidia 3000 GPUs as well, will be a loong time investment - as the last Win7 computer I'll ever build© would surely benefit from some spare parts in the coming decades... 😆
PS: +was quite surprised to see the RTX 3090 Ti getting a Win7 driver this spring....
(while all the other/older cards lost their driver support in September last year)
Reply 1573 of 2072, by liqmat
bestemor wrote on 2022-06-13, 20:08:
@liqmat; what CPU did you use on this then ?? And how do you like/experience it vs whatever cpu you had in the X470 board - big […]
My specs are in this thread over a couple of posts. I had the 5900X on the X470 and moved it over to the the X570 mobo. Kept the same 3200MHz DDR4 RAM I had on the X470 as well. I installed the clone image first on one 1TB partition and then installed Windows 10 on the other 1TB partition. Windows 10, of course, detected Windows 7 with no issues and I now have a smooth running dual boot setup.
Basically, Windows 7 screams (much like Windows 9x on a fast Pentium III or 4), but tbh if you are on an X470 board already I see absolutely no reason to move to X570. I will say the PCIe 4.0 NVMe speeds are blazing fast on the X570. On my X470 I had the PCIe Gen 3 Plextor M9Pe(G) @ 3200MB/sec large file reads whereas on the X570 coupled with that Samsung 980 Pro I get over double that. The only reason why I upgraded is because the ASRock X470 ITX board had the NVMe on the backside of the mobo (terrible design choice imo) with no way to cool it properly so the NVMe failed within six months due to sketchy thermals. I previously had the ASRock X470 Taichi Ultimate ATX mobo for about two years and that was an excellent board and played very well with Windows 7. One of my favorite X470 boards tbh, but I am on the road quite a bit so I needed the portability of the ITX form factor. I also have read the ASRock X570 boards do not play well with Windows 7. Have not tested this myself, but I am very satisfied with the Gigabyte X570 ITX mobo.
Reply 1574 of 2072, by PcBytes
Although not very new, I've got these two:
file.php?mode=view&id=139835
Galaxy S6 Edge G925F. Also bought an case for it. Total spent for it, $72 (about 340RON total)
file.php?mode=view&id=139834
Galaxy S7 Edge G935F. Free hand-me-down from my dad since I bought him a Galaxy Note 4 N910F. Also came with a pretty sturdy case.
Reply 1575 of 2072, by retrogamerguy1997
Bought this earlier today to upgrade/replace my existing board. It's kinda ugly, but should bring some quality of life improvements to get more out the hardware I'm currently running. I don't plan on really upgrading my main rig much expect maybe also ditching the stock cooler (which if I want to get a better cooler, I need the a larger board anyways). Hard to believe though that the Haswell platform is nearly a decade old. Makes a guy feel kinda old since I actually originally built my rig in 2014-2015 when I was still in high school and was my first taste of actually having modern and new hardware.
https://www.ebay.com/itm/ASUS-Q87M-E-CSM-Desk … 046461#viTabs_0
Reply 1576 of 2072, by bjwil1991
Won a Nintendo 3DS bundle (salmon color):
223.22 KiB
Reply 1577 of 2072, by BetaC
I finally gave in and got myself an Apple Silicon Mac, which, naturally means I needed to play a PC exclusive on it using an ADB keyboard.
1.78 MiB
Reply 1578 of 2072, by schmatzler
I got an EVGA Nforce 790i motherboard with a Core2Quad and Noctua fans for 50 bucks.
Can't wait to test this out with my two GTX 570 and eventually do triple SLI when I find a matching third one.
I have a P5E3 WS that can do dual SLI with hacked drivers, but there are no hacked drivers for Windows XP, which makes me sad.
Reply 1579 of 2072, by BitWrangler
Spotted a i3 8100 combo deal late Sunday, and *poof* suddenly every evening this week fills up with "nonsense" well, not really nonsense, just "not letting me do computer chasing" stuff. It's a decent deal I think, which leaves me thinking I won't be getting it as it might be gone before I get a chance to pounce. So another "one that got away" deal maybe. At present it's the i3, cooler, Asus board and 8GB, also seeing an M2 drive on there, could be getting thrown in too. Does over 6000 assmarks, so twice as fast as anything I've got right now*. Could double that in a year or two whenever I can grab cheap 8G or 9G i7
* yeah I never got on top of that Haswell Xeon deal either, crap just blew up here, deaths in the family, the works.
Edit: Great, this evenings 2 hour event sprawled into 4 hours and now I gotta carry over shit that didn't get done to another evening.
editII: Well that was highly predictable, stuff that should have been one stop and done went into several evenings hunting through different outlets. Meanwhile, other stuff happens, spend most of the weekend playing catchup, then yesterday, Monday, get a chance to see if I can go get it, annnnd it's gone.
