Bought this (Modern) hardware today
Reply 600 of 2072, by brassicGamer
Wasn't able to repair my 790FX Asus board, so I've been checking a daily eBay search for various CrossFire-compatible chipset-based boards for literally months. After watching board after board sell for £50+ (or faulty ones not worth taking a chance on) I hit the jackpot. It was listed as 'untested' as it apparently came originally as part of a job lot. Luckily for me, it works perfectly!
553.82 KiB
Only set me back £30 (retailed for £250 when new) - the final piece of the puzzle in my AM3 build.
Reply 601 of 2072, by dexvx
I bought an Asus P8P67-Evo (LGA 1155) board that was broken, some pins were messed up in the corner. It was cheap and came with the full retail box/manuals, so I figured why not.
Got it today. Looks like 3-4 pins bent not bad. But the real kicker is that 1 pin is totally broken. So... anyone know where I might pay $$ to repair this? Definitely out of my skill set. I've emailed Asus and hopefully their repairs aren't that expensive. I know Gigabyte charges $40 or so.
Reply 602 of 2072, by Aideka
With some luck, the missing pin might be just a ground spot, and if it is, the board will usually work without one of them.
Reply 603 of 2072, by dexvx
It is a ground spot (unless I'm reading the SandyBridge pin layout wrong), but I would still like Asus to repair it.
Unfortunately, if Asus declines, does anyone know some third party shop that might do it?
Reply 604 of 2072, by kode54
Asus will just as likely bin it and replace it with a whole new board. You wreck those LGA sockets, the whole board is as good as toast. Go ahead and try to scam the RMA system with your secondhand dead board, though.
Yeah, I know someone with experience trying to "repair" broken LGA sockets. Any attempts to repair them resulted in horribly unstable systems. Basically, any bent pin or broken pin, the whole board is basically scrap.
Reply 605 of 2072, by kithylin
This is probably going to open a can of worms.. as viewpoints on this differ from person to person. But personally I, myself, have no qualms or issues what so ever with trying to RMA potentially broken (or even known broken) second-hand hardware to a company. If their RMA policy and untrained support techs allow it through then it's entirely on them and their problem with it. I'm of the opinion myself that the company should know how to detect 2nd hand hardware, or at least have some sort of original documentation, or original registration period requirement, or at least something to prevent it (a lot of companies do). OR at the very least train their support staff better to detect it from the get go and deny RMA's initially for it. And so if they don't do their own due diligence to prevent that sort of thing.. it's entirely their problem if it's allowed through. I don't consider anything about it 'shady', or negative, or anything. If the company allows it then it's a fully legal, legitimate thing that's normal for X, Y, or Z company. If they don't allow it then they don't.
That's just me though.
Reply 606 of 2072, by dexvx
First of all, I'm not some desperate scumbag willing to cause a ruckus to get free RMA's.
Second, I emailed Asus and asked them how much the repair would be flat out. They quoted an absurd $100, but they said it could be cheaper if I bring my board in.
Third, repairing a broken socket is extremely easy, the problem is you need the right equipment (idk what that baking thing is called). It takes a long time, but relatively low man-hours (mostly just letting it bake for solder/desolder).
Forth, repairing bent pins is easy, depending on how the pin is bent. I have repaired two GA-Z97 with maybe a dozen bent pins. All but two of them look perfect. Passes Prime95 torture 24H and 3DMark Vantage loop overnight. The other one looks perfect except for 1 spot. Same deal with stability.
Reply 607 of 2072, by Jade Falcon
Rank BANNED
BANNED
One idea is to take the board to a jeweler and asked them to solder a peace of gold on the remains of the pin.
They may also make a complete mess of the board too. So if it works before hand use it as is.
I know I soldered a sliver of gold onto a broken lga pin before. Not fun but is can be done.
Reply 609 of 2072, by ODwilly
kode54 wrote:
What a marvelous idea. And you can even take them on Judge Judy when it doesn't work!
I just have to say that you seem intent on starting issues with other members in just about every thread iv seen you post in.
Reply 611 of 2072, by Jade Falcon
Rank BANNED
BANNED
Agreed. Just one of the manny passive aggressive trolls on this site... wait was I just passive aggressive there 😕
Anyway i got 4 300gb WB raptor drives today. And a 700w ozc fatal1ty psu, some low rpm scythe fans too.
Reply 612 of 2072, by ODwilly
Lol I am glad to see you still on and contributing Jade! Your posts are valuable and fun to watch enfold. Ya lots of annoying passive aggressive trolls on here lately, but it is always mildly entertaining to watch the drama enfold. In between reading valuable information on relative threads of course haha.
Reply 613 of 2072, by DracoNihil
I don't see how kode54 is a "passive aggressive troll"...
I sense some favouritism\cronyism abound... bleh.
― Κυνικός Δράκων
Reply 614 of 2072, by clueless1
Yes you were. Think about everyone on here who read what you said and wondering if you're insinuating that about them.
I've put my foot in my mouth many a time, but I try to follow Thumper's advice as much as I can.
Reply 615 of 2072, by Aideka
Bought an Asus STRIX GeForce 960 4Gb to replace my GeForce 750Ti. Not too big of an upgrade, but I had the upgrade fever, and while I would have wanted a Radeon RX570, it would take till Vega gen.2 until the price comes down to a sane level 😜 . It helps that I got a good clocker though, i was able to get the memory up to 8GHz, which seems to be the norm, but also got the core up by 120MHz, which seems to be really good with the STRIX model.
Reply 616 of 2072, by dexvx
Cause the a$shat said:
When I literally emailed Asus asking how much repairs are.
So yes, very troll in that context. Also the guy does not know anything about repair sockets or is willfully ignorant. We change IC's on our components at work all the time with a heatgun. Would need something on a slightly larger scale for a CPU socket.
Reply 617 of 2072, by oeuvre
An HP EliteBook 8440p I scored off eBay... won the auction last second. Total price of all the parts was just about $100, including getting a 128GB SSD and genuine HP power adapter. Has 1600x900 + NVS 3100M processor. Runs nicely. http://imgur.com/a/ZoqFJ
    600.7 KiB
Reply 618 of 2072, by havli
K10 is not very modern anymore... still it is nice to have enough cores 😁
2x Opteron 6136 (8C, 2.4 GHz)
2x Opteron 6176 SE (12C, 2.3 GHz)
