Schneider Euro PC
Reply 60 of 207, by dr.zeissler
I bought a Gotek for my EuroPC. I can tell you that it works, but it is slow!
It's perhaps as slow as the loading from a real floppy-disk, but you can't hear the disk-acess.
It's not a thing that I would give away my xt-ide in the single isa-slot.
I currently use CGA instead von MDA because I use a !084 with both C64 and EuroPC connected
and I can switch on the front between both machines... that's nice.
Composit CGA that is used in early agi-games (ll1,pq1,sq1,kq1,etc.) is monochrome on my
1084 but it looks much nicer then the real cga-color-mode for RGB which is truly ugly btw.
https://books.google.de/books?id=lB4PAwAAQBAJ … 20larry&f=false
Reply 61 of 207, by Jinxter
I have not made one yet. I will use a Gotek with speaker.
Could you send the connection diagram for making the vable.? Are you using it internal or external?
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
Reply 62 of 207, by genocho
Jinxter wrote:
I just tried to connect wires from the to pins market in picture to see if there where any composite video there. No luck! […]
Jinxter wrote:
I am trying to connect the PC to a colour monitor. I see the the Video Controll Chip has a PIN called CMPVD. Could this be Composite video output?
Do you know if anybody has tried to use this pin to get Composite video?
I can see these reason for this not to work.
1. I used the wrong PIN on the video chip
2. These pins needs to be turned on in bios/setup or software
3. I need some additional electronics.
I would be fun to be able to use composite video and maybe run 8088mph on it.
Want to point out something:
That pic is not the video chip, that´s the bigjim chip (i/o chip)
The video chip is in the middle of the pcb branded as paradise pvc4.
Reply 63 of 207, by dr.zeissler
No I cannot send you the connection diagram, because I bought it as it is.
The Seller has wired it completly. It works, but it's slow and you can't hear what it is doing.
Reply 64 of 207, by Jinxter
genocho wrote:
Jinxter wrote:
Want to point out something: That pic is not the video chip, that´s the bigjim chip (i/o chip) The video chip is in the middle o […]
Thanks for your input, this means i must try again. It would be greate to get composite video output
Reply 67 of 207, by Jinxter
tereg wrote:
Also - do you use any cga-scart converters (I mean DIY)
I made one from this schema.
26.88 KiB
CGA to SCART
I also have a video showing it: https://www.youtube.com/watch?v=ymulGiO4NrI
Reply 68 of 207, by genocho
tereg wrote:
Hola amigos. I've got composite video from Schneider euro xt (paradise PVC4) due to this card not really copy of CGA it has problems to demonstrate 8088mph, but works
Hola !!!
Do you have the schematics of that composite mod for the euro pc ??? I assume you need an additional circuitry to have the composite color signal right ???
Thanks in advance.
Reply 70 of 207, by tereg
Jinxter wrote:
I made one from this schema. […]
I tried this scheme 3 times, but it doesn't start work on my Schneider xt, dunno why
Reply 71 of 207, by Jinxter
Try adjusting the Volt. I think Scary can tolerate up to 20 volt. On one TV I had to use 9 volt.
Also some TV does not use the Volt to change input. You must chose in RGB input on the TV settings.
Reply 73 of 207, by Jinxter
tereg wrote:
I resolve it in my way
Nice mod.
Does it display 16 colours in e.x. KQ1?
What about 8088MPH?
Reply 74 of 207, by Scali
Also - there is my video how to add composite mode and get csync signal to 2nd pin of cga
https://www.youtube.com/watch?v=p-E7Qh1hnuM&feature=youtu.be
That's a great hack!
I have a Commodore PC20-III with the PVC4 chip and stock composite.
The colours on mine aren't perfect compared to a real CGA card, but they're close enough. The ATi Small Wonder I have is way off in certain video modes.
This is how the Commander Keen composite CGA version looks on mine: https://www.youtube.com/watch?v=-eRvF0aSYlc
Reply 75 of 207, by Jinxter
Are you using FlashFloppy?
What are your settings?
Have you tried setting: track-change = instant* (instead of realtime that is default)?
Reply 76 of 207, by Jinxter
Could you send a picture of the cable - that would tell me alot. I have attached a picture of my cable - which i think is wrong.
    887.62 KiB
    EuroPC Gotek cable - not working
Reply 77 of 207, by Jinxter
See this post on how to connect an Gotek to the EuroPC: SCHNEIDER EURO PC II 26 PIN FLOPPY TO STANDARD 34 PIN IDC
Reply 79 of 207, by genocho
Jinxter wrote on 2018-11-13, 22:41:
Not a gotek, a real and normal floppy drive. The original internal one in the euro pc it´s a sony 26 pin. I made the adaptor cable back in the day.
Guess will work with a gotek, but my purpose when i did it was to use an internal or external normal floppy drive.
Thanks.
