Schneider Euro PC
Reply 80 of 207, by Jinxter
A few days ago i learned that the EuroPC support the 16 Color CGA mode called Plantronics mode. I have made a video about it.
Take a look: https://youtu.be/QbRq35s12yg
Enjoy.
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
Reply 81 of 207, by Jinxter
dr.zeissler wrote on 2016-04-25, 18:26:
in 1990 i bought a 8bit joystick-card for two analog joysticks.
the "digital" joystick 9pin is not usable. don't know any working joystick or game for that.
I just made this video about digital joystick on PC.: https://youtu.be/Kk_TplXl5_Q
When i was i Joystick mode, i started think about the EuroPC joystick port. If this pinout i found is correct, an Atari style joystick should work.
1 - Xb / UP
2 - Xa / DOWN
3 - Ya / LEFT
4 - Yb / RIGHT
5 - Middle button / JOY1_Select (to GND)
6 - Left button / JOY2_Select (to GND)
7 - Vcc
8 - GND
9 - Right button / FIRE
Have you found anything about the joystick port, since we last talked about this in 2016?
Reply 83 of 207, by konc
Jinxter wrote on 2021-04-01, 11:24:
I just made this video about digital joystick on PC.: https://youtu.be/Kk_TplXl5_Q […]
1 - Xb / UP
2 - Xa / DOWN
3 - Ya / LEFT
4 - Yb / RIGHT
7 - Vcc
8 - GND
I doubt an 9-pin atari joystick will work. The Schneider's joystick is itself a normal PC 15-pin one which works on other computers, and other 15-pin PC joysticks work on the Schneider (using the Y-cable of course to connect them).
The pinout you have found is correct though, this is taken from the "Techniker-Schulung"-"Technician training":
32.47 KiB
Reply 84 of 207, by dr.zeissler
Keep in mind, that EuroPC1 is different from EuroPC2.
For the EuroPC1 you could get a dual joystick-card with 2 analoge 15 ports.
For the EuroPC2 you could get a y-cable with two 9pin digital ports for hooking up on the joystick-port of the EuroPC2 directly.
Reply 85 of 207, by konc
dr.zeissler wrote on 2021-04-01, 15:28:
The EuroPC part is correct, but I believe their joystick was the exact same common 15-pin PC joystick for both PC and PCII.
So for the PCII they did give the y-cable as you wrote, but it also has two 15-pin connectors for normal PC joysticks (and not two 9-pins)
47.2 KiB
Reply 86 of 207, by Jinxter
konc wrote on 2021-04-01, 16:25:
This was very informative. Thanks. So what about using a mouse on the same port, what kind of mouse? Is it the same as something we know - like the Amiga, or Atari mouse? What about driver?
Reply 88 of 207, by konc
Jinxter wrote on 2021-04-01, 20:58:
Yes, it is something we know but probably not what you'd expect: it uses the BUS mouse interface (derived from Microsoft's InPort).
There is a driver (mouse.sys) included in the "Works" floppies that came with the PC, a simple DEVICE=MOUSE.SYS suffices. I haven't tried other bus mice with this driver as I don't have any, and I also don't know about the opposite (other bus mice with their own driver on that port). In theory they should but who knows... I attached the driver just for it to exist here, it has a MS copyright "Microsoft (R) Mouse Driver Version 6.14".
You can always use a serial mouse of course.
MOUSE.zip
11.47 KiB
75 downloads
Reply 90 of 207, by Jinxter
dr.zeissler wrote on 2021-04-02, 07:57:
I use the serial-port on my t1000 to fire up a mt32. this should be possible on euro-pc too.
Could you elaborate?
Reply 92 of 207, by Jinxter
dr.zeissler wrote on 2021-04-02, 10:51:
I see they are much alike the LPT port audio adapters from Serdashop. And they also needs the games to be patched.
I have tested both the S2P - which gives general midi on the printerport. https://www.youtube.com/watch?v=bI-TJjKvv_Y and the OPL3LPT. : https://www.youtube.com/watch?v=5w0Rywud23Q - Sorry for spamming with links.
I see that there are a few games that is patched for for the, maybe i will try this out on EuroPC.
Reply 94 of 207, by Jinxter
dr.zeissler wrote on 2021-07-24, 09:27:
Wow. You inspired me. You have taken it all the way. Nice touch with rs232 midi. I must try that.
I am making a video soon where I upgrsde the CPU to a Nec v20 and use the xt-ide bios that support 80186 instructions to get the cf three times faster.
Reply 97 of 207, by dr.zeissler
If I have a HD20 from Schneider. Do you see a chance of using it with bigger CF card/Adapter-Solution, so that the ISA-Slot could remein free?
Or is it "hardwired" 8Bit IDE for XT-Drives which means 20-30MB and a real spinning and noisy harddisk?
Reply 98 of 207, by konc
dr.zeissler wrote on 2021-09-14, 12:59:
I strongly doubt it.
It's definitely not IDE, how could it be since it's an XT. The one I've seen had a Seagate ST325-X inside, which is 8-bit IDE or XTA and is the same drive used internally in the EuroPC XT desktop model
Zup wrote on 2016-06-22, 07:06:
Sorry to refloat this.
I'm collecting some information about PCem old computers, and I'm interested about HD20. Can anybody confirm which HDD lies inside that expansion?
I just saw your earlier post in this thread, quoting you to get a notification in case the information is still useful.
Reply 99 of 207, by Jinxter
If the HD20 can use a IDE drive, you could install a XTIDE BIOS (not XTIDE Controller - only BIOS) in the ISA slot. You can also use the TXIDE BIOS on a 8bit ISA network card.
And then use a IDE2CF og IDE2SD card in the HD20
