MSYS2/mingw-w64 for Win64 DOSBox
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: MSYS2/mingw-w64 for Win64 DOSBox
Postby fr500 » 2018-7-13 @ 02:17
kjliew wrote:I have made some progress in debugging this and was able to start WIN64 DOSBox with dynarec core into the DOSBox's DOS prompt. However, launching a DOS program still ended up in segmentation fault.
Summarizing the issues so far:
1. In gen_load_param_reg, the encoding of "mov R8, reg&7" and "mov R8, reg&7" are incorrect. From GDB disassembly, they are actually "mov reg, R8" and mov reg, R9".
2. For WIN64 ABI, space is allocated on the call stack as a shadow store for callees to save those registers. There are cases that gen_call_function_setup/raw were thrashing the return address in stack, and this was a major issue for segmentation fault. One of the instruction is the "INT #imme8".
With those issues fixed, WIN64 DOSBox would boot up into the prompt on dynrec core. I believe there are more cases of stack thrashing for decoding other instructions. It is very tedious to track each of them down. Hopefully, this would give some insight to the DOSBox devs who are familiar with dynrec core to deal with issue #2 above once and for all.
Correction:
Actually, not segmentation fault, it was a hung. That's what make it tough to debug. Otherwise, segmentation fault would have landed into GDB and stack trace could be helpful sometimes....
Hey, do you have a diff?
Have you made further progress?
fr500
Postby PgrAm » 2018-11-07 @ 17:17
I believe I have a solution for issue #1, gen_mov_regs will not correctly generate a mov where r8 - r15 are the destination register. instead I made something like this:
Code: Select all
// move a full register from reg_src to reg_dst, where dst is r8-r15 and src is rax-rdi
static void gen_mov_regs_reverse(HostReg reg_dst, HostReg reg_src)
   cache_addb(0x89);               // mov reg_dst,reg_src
   cache_addb(0xc0 + (reg_src << 3) + reg_dst);
// load a host-register as param'th function parameter
static void INLINE gen_load_param_reg(Bitu reg,Bitu param) {
   // move a register into a 64bit param reg, {inputregs}!={outputregs}
   switch (param) {
      case 0:      // mov param1,reg&7
         gen_mov_regs(FC_OP1,reg&7);
         break;
      case 1:      // mov param2,reg&7
         gen_mov_regs(FC_OP2,reg&7);
         break;
#if defined (_MSC_VER)
      case 2:      // mov r8,reg&7
         cache_addb(0x49);
         gen_mov_regs_reverse(0,reg&7);
         break;
      case 3:      // mov r9,reg&7
         cache_addb(0x49);
         gen_mov_regs_reverse(1,reg&7);
         break;
#else
      case 2:      // mov rdx,reg&7
         gen_mov_regs(HOST_EDX,reg&7);
         break;
      case 3:      // mov rcx,reg&7
         gen_mov_regs(HOST_ECX,reg&7);
         break;
#endif
      default:
         E_Exit("R(eg) >4 params unsupported");
         break;
This appears to generate the code correctly but the issue of stack trashing remains. (I'm working with MSVC btw), this gets me to the prompt but the prompt is unresponsive, any attempt to load a program (via autoexec), results in a segfault.
Currently working on new DOS game, Chuck Jones: Space Cop of the Future : https://chuckjonesdevblog.wordpress.com
WARNING: contains rocket powered El Caminos
User avatar
PgrAm
Postby PgrAm » 2018-11-07 @ 21:22
more progress, prompt is responding after I fixed gen_call_function_setup to allocate windows' required shadow space. Here's my solution:
Code: Select all
// generate a call to a function with paramcount parameters
// note: the parameters are loaded in the architecture specific way
// using the gen_load_param_ functions below
static Bit64u INLINE gen_call_function_setup(void * func,Bitu paramcount,bool fastcall=false) {
   // align the stack
   cache_addb(0x48);
   cache_addw(0xc48b);      // mov rax,rsp
   cache_addb(0x48);
   cache_addw(0xec83);      // sub rsp,0x08
   cache_addb(0x08);      // 0x08==return address pushed onto stack by call
   cache_addb(0x48);
   cache_addw(0xe483);      // and esp,0xfffffffffffffff0
   cache_addb(0xf0);
   cache_addb(0x48);
   cache_addw(0xc483);      // add rsp,0x08
   cache_addb(0x08);
   // stack is 16 byte aligned now
   cache_addb(0x50);      // push rax (==old rsp)
   cache_addb(0x48);
   cache_addw(0xec83);      // sub rsp,0x20
   cache_addb(0x20);   // allocate windows shadow space
#endif
   // returned address relates to where the address is stored in gen_call_function_raw
   Bit64u proc_addr=(Bit64u)cache.pos-4;
   // Do the actual call to the procedure
   cache_addb(0x48);
   cache_addb(0xb8);      // mov reg,imm64
   cache_addq((Bit64u)func);
   cache_addw(0xd0ff);
   cache_addb(0x48);
   cache_addw(0xc483);      // add rsp,0x20
#endif
   // restore stack
   cache_addb(0x5c);      // pop rsp
   return proc_addr;
Needs more work though, it immediately segfaults when I try to run a real program, there may be more going on
User avatar
PgrAm
Postby kjliew » 2018-11-08 @ 21:18
@PgrAm @fr500
Attached the patch for my earlier debugging of dynrec CPU core on WIN64 ABI. I am on MSYS2/mingw-x86_64.
This patch fixes the segmentation faults so far, but the core is still broken. Segmentation faults are good for debugging because gdb stack trace can tell some clues on them. After the patch, DOSBox will just hang, some time the console will spit out lots of illegal read/write memory location, but no more faults. This makes debugging very difficult. I am not sure other than arguments passing during function invocation, what else WIN64 ABI would make a difference.
Update: Remove partial fix. See subsequent post for the fix which actually works.
kjliew
Postby PgrAm » 2018-11-08 @ 23:46
Thanks @kjliew!
I've gotten a bit further with fixing some issues, (eg. gen_load_param_mem generated incorrect prefixes), Now I'm able to run some simple programs. Succeeded with a program that sets the screen to mode 13h then exits.
Now I will proceed with making some simple assembly language programs as test cases for further debugging to isolate problem areas. More complex programs appear to get stuck in some kind of infinite loop and some of my watcom applications detected a stack overflow.
Here is my diff (I changed _MSC_VER to _WIN64 so hopefully it'll work with mingw64)
risc_x64.diff
(4.74 KiB) Downloaded 10 times
User avatar
PgrAm
Postby kjliew » 2018-11-09 @ 02:10
@PgrAm
Thanks, PgrAm!
I got it working finally!!! Each of us having missed 1 part of the fix. By merging our debugging results, we made it! My fix which yours was missing is coded in GCC way though. You need to adapt it for VS, should not be too difficult.
I got PCPBENCH.EXE a DOS4GW running nicely. Will check out more games.
win64_dynrec-2.diff
WIN64 working core_dynrec
(6.69 KiB) Downloaded 10 times
kjliew
Postby PgrAm » 2018-11-09 @ 04:11
@kjliew, Awesome!
I applied your changes and came up with a diff that should work with both compilers, I can confirm these changes work in my debug build, however they segfault in release mode. What optimization switches are you compiling with?
I'm also having trouble with adlib detection, seems to work randomly 50% of the time (when using dynrec64).
risc_x64.diff
mostly working win64 dynrec
(8.47 KiB) Downloaded 10 times
User avatar
PgrAm
Postby kjliew » 2018-11-09 @ 05:12
PgrAm wrote:I can confirm these changes work in my debug build, however they segfault in release mode. What optimization switches are you compiling with?
I am getting similar results with different optimization level.
With -O0, so far everything worked. I was also testing for 3Dfx capabilities using Tomb Raider 1 and Blood. They all worked.
With -Og, so far everything worked. It measured ~2x faster than -O0.
With -O1 or -O2, simple DOS .COM work. Most would segmentation fault.
GDB trace showed MOV instruction read from memory address for eg. mov rax, [rsi + rbx * 4], and the address did not look correct. One of the registers is '0' and the memory location is too low for a WIN64 application.
Update: -Og work after fixing the gen_call_function_setup() to make sure stack remain 16-byte aligned. So just ignore the paramcount and always allocate stack space for 4 args.
kjliew
Postby PgrAm » 2018-11-09 @ 06:49
@kjliew
Think I solved the last problem, windows ABI expects the callee to save RSI, but *nix does not. Simply modified gen_run_code to handle this and BAM! my release build works!
Code: Select all
static void gen_run_code(void) {
   cache_addb(0x53);               // push rbx
#ifdef _WIN64
   cache_addb(0x57);               // push  rdi
   cache_addb(0x56);               // push rsi
#endif
   cache_addw(0xd0ff+(FC_OP1<<8));      // call
#ifdef _WIN64
   cache_addb(0x5e);               // pop  rsi
   cache_addb(0x5f);               // pop  rdi
#endif
   cache_addb(0x5b);               // pop  rbx
EDIT: you gotta save RDI too
Adlib detection is still spotty though not sure why yet
Final diff attached
risc_x64.diff
Working Windows x64 dynrec core patch
(8.87 KiB) Downloaded 10 times
User avatar
PgrAm
Postby kjliew » 2018-11-09 @ 08:03
@PgrAm
Awesome work! I can confirm now my GCC -O2 optimized works. PCPBENCH showed another 20% improvement from -Og. So that finally concluded the Win64 core_dynrec support that made both Windows and Linux 64-bit support at parity.
I think the adlib detection is normal for very fast dynamic cpu core. I think GODS and DUNE2 would also fail MT32 detection when running dynamic core at max 105%.
@QBix
DOSBox devs, please include this fix into SVN.
kjliew
Postby kjliew » 2018-11-10 @ 01:49
@PgrAm I think you had included a redundant windows shadow space allocation in gen_call_function_setup().
Only the this part is needed:
Code: Select all
@@ -398,6 +411,12 @@ static Bit64u INLINE gen_call_function_s
+#if defined (_WIN64)
+       cache_addb(0x48);
+       cache_addw(0xec83);             // sub rsp,0x20
+       cache_addb(0x20);       // allocate windows shadow space
+#endif
@@ -408,6 +427,12 @@ static Bit64u INLINE gen_call_function_s
        cache_addw(0xd0ff);
+       cache_addb(0x48);
+       cache_addw(0xc483);             // add rsp,0x20
+#endif
        // restore stack
kjliew
Postby PgrAm » 2018-11-10 @ 17:11
@kjliew Nice catch, but its actually just the comment is wrong I think, the second one should say "deallocate" instead of allocate. Now that you mention it though, I realize that I could optimize that a bit and save an instruction, right after the function call by restoring the stack pointer directly(which will deallocate the shadow space too) instead of using pop.
Code: Select all
   //restore our original stack pointer
   cache_addd(0x24648b48); //mov rsp, [rsp+0x20]
   cache_addb(0x20);
#else //system v abi
   // restore stack
#endif
return proc_addr;
EDIT:
Took a look at it again and found I could optimize it even more (saves two additional instructions), here's the whole function:
Code: Select all
   // align the stack
   cache_addb(0x48);
   cache_addb(0x48);
   cache_addb(0x28);// 0x08==return address & shadow space pushed onto stack by call
#else
#endif
   cache_addb(0x48);
   cache_addb(0xf0);
   //save our stack pointer
   cache_addd(0x24448948); //mov  [rsp+0x20], rax (==old rsp)
   cache_addb(0x20);
#else
   cache_addb(0x48);
   cache_addb(0x08);
#endif
   cache_addb(0x48);
   cache_addw(0xd0ff);
   cache_addb(0x20);
#else
   // restore stack
#endif
   return proc_addr;
User avatar
PgrAm
Postby kjliew » 2018-11-10 @ 20:05
@PgrAm To ease upstream acceptance and enhance future patchability, I usually refrain from unnecessarily touching the underlying code and keep the changes simple. Here's my final patch for your reference. It will be up to DOSBox devs to decide how to integrate the changes. Our combined debugging efforts had provided all the answers to this long dragging issue of 64-bit build for Windows. Cheers :happy: !
risc_x64.diff
(6.92 KiB) Downloaded 18 times
kjliew
Postby Qbix » 2018-11-11 @ 09:26
I see that you changed the defines. Although that should be safe given that it is the x64 core, which shouldn't get compiled on win32.
Looking over the patch, it the ADD and friends changes are a bit surprising, we could have made that depend on FC1_OP and such, but given that there only 2 versions, it might be too much to do that.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Qbix » 2018-11-16 @ 15:41
commited these changes, a bit modified as that is how I had those functions in my local tree.
User avatar
Qbix
DOSBox Author
Previous
Return to DOSBox Development
Who is online
