Half-Life overbright compatibility
Reply 20 of 38, by PhilsComputerLab
And two more...
    2.47 MiB
    gl_overbright 1
    2.38 MiB
    gl_overbright 0
YouTube, Facebook, Website
Reply 22 of 38, by PhilsComputerLab
PhilsComputerLab wrote:
So here are some screenshots with 1.1.1.0 patch.
Also, can someone please tell me what level or area the first photos in this thread are from?
Reply 25 of 38, by Firtasik
Xash3D FWGS 0.19 has been released.
"Two overbright modes are implemented. Toggle with gl_overbright <0/1/2> cvar."
    1.49 MiB
    gl_overbright 2
    1.52 MiB
    gl_overbright 1
    1.38 MiB
    gl_overbright 0
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 27 of 38, by leileilol
xash sucks though. suspicious origins of allegedly "written from scratch" code resembling actual valve (and id) code, and sdk-license violatiions make xash too legally toxic
Messing with HL myself i've only noticed overbrights only seem to be working for Voodoo Graphics. Voodoo2 and later breaks it, likely not implemented for multitextured paths
EDIT: This seems to be the case. Copying 3dfxgl.dll, hexing SGIS_ to ASSS_ in its multitexture extension string (so half-life can't detect it) brings overbrights to Voodoo2, at a performance cost 😀
44.12 KiB
Hexing hw.dll would be more ideal, but that's more encrypted/compressed in later patches (anti-cheat reasons) so you'll have to copy your ICDs over and hex em instead. 😀
Don't forget to hex the ARB_Multitexture stuff too.
(this may also trip VAC in Steam half-life so don't do it there)
long live PCem
Reply 28 of 38, by tgod
Isn't "gl_texsort 1" suppose to be enough to disable multitexturing for overbrights to work on those cards?
http://www.play-half-life.de/H-L_2.html#txsrt
Reply 29 of 38, by swaaye
Maybe XASH3D is questionable but you do get overbrights even on Android devices. I got Half Life, Blueshift, Gunman Chronicles, They Hunger and Darkstar running on my tablet and the touch controls work great. Taking screenshots on it it tricky though.
The two center touch buttons are two I made to take screenshots and open the console. It's tricky to take screenshots on a tablet.... 😀
gl_overbright 2
1
0
0
1
2
Reply 30 of 38, by Firtasik
Sunny day in Black Mesa:
    1.45 MiB
    gl_overbright 0
    1.69 MiB
    gl_overbright 3
Reply 31 of 38, by j^aws
Regarding multi-texturing on Voodoos breaking the overbrighting effect, has anyone tried it on a Banshee? I played Half-Life on one at launch, and seem to recall an excessive glowing affect around vending machines...
Reply 32 of 38, by leileilol
A Banshee doesn't have multi-texturing and likely would have working overbright.
I have an AGP Banshee....somewhere.
gl_texsort isn't on all versions.
long live PCem
Reply 33 of 38, by silikone
Late reply to a PM, that map is just something quick I made to test the lighting. Perhaps I should create a map dedicated to the testing of all kinds of conditions with lighting and textures.
From what I gathered, with overbrightness, textures seem to reach original brightness when exposed to around 75% lightmap intensity levels. I'm sure there's some simple math that describes this process, but it's probably complicated by the way gamma is handled in Half-Life.
There are all sorts of possible combinations with the 'gamma', 'brightness', and 'lightgamma' variables. Half-Life defaults to 2.5 gamma, but the engine appears to natively work with a level of 2.0. I have experimented with these, but how they work exactly is still a mystery to me.
On a side note, Half-Life also seems to support two types of dynamic lights. The first one blends in with the ambient lighting in a pseudo-directional manner. The second one only lights up models, but it is properly directional and locally present. Only up to three of these are active simultaneously
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 34 of 38, by leileilol
What can also help in determining the lightness is loading a Half-Life map in one of those Quake source ports that support HL BSPs (i.e. Darkplaces, Engoo, etc). Quake's overbrights are usually one half of a lightmap's brightness and get clamped to half in GLQuake normally. Quake2's overbrights are only calculated for the software renderer's lightmap build code and are shifted down in GL on that (looking rather dark)
long live PCem
Reply 35 of 38, by silikone
http://puu.sh/vY6tk/74878fe1ac.zip
Here's a small test map. There is a room that has a wall of squares, which are various combinations of light levels and pigments. The light scale doesn't follow a consistent curve, so for reference, 50% (128/255) is on the bottom left.
Speaking of the sun, using the default gamma correction in the editor, assuming the light is supposed to be physically accurate, the ratio between the the brightest white and the darkest non-black is about 1:65536 (2^16), as opposed to 1:255 as seen in Quake 2. Still lower than the real ratio of one to one million between moonlight and sunlight, but close nonetheless. This doesn't really matter much in terms of how bright the levels are and can be, but it does mean that making the levels look good in the latter game relies on good artistry rather than knowledge of physics.
Reply 36 of 38, by auron
And two more...
what renderer did you use for these screenshots? D3D gives me severe Z-fighting issues on a V5 5500, last official drivers and fully patched game. i also got missing decals but could fix them with gl_polyoffset -0.01. thinking of swapping to a TNT2 for this game as the readme mentions D3D as unsupported for 3dfx.
Reply 37 of 38, by auron
had no luck with the tnt2, and a kyro ii also gave me z-fighting, but it turns out overbright works when using opengl on the kyro. finally correct graphics! there's only one level of overbright available with the newest patch, but still pretty good 😀
on a side note, the kyro's filtering can look somewhat like n64 in spots 😀
Reply 38 of 38, by silikone
Using a tool to enable OpenGL extension limiting on the NVIDIA drivers results in a functional gl_overbright in Half-Life Steam on a modern PC. Unfortunately, without multitexture support, detail textures are also disabled.
Wouldn't it be insanely easy to have both by using GL_RGB_SCALE? As a bonus, there would be no banding caused by a two pass blend.
