7-zip benchmarks for over 60 CPUs
Reply 100 of 209, by BSA Starfire
results added for VIA C3 1.2 GHz "nehemiah" on SIS 630 motherboard.
Reply 101 of 209, by luckybob
playing around on my file server:
Just goes to show you, 2 processors are better than one! Also done on the newer pci-e chipset.
Reply 102 of 209, by BSA Starfire
Results added for Celeron coppermine 600 on SIS 630 motherboard.
Reply 103 of 209, by tyuper
Looks like upgrading from my old OCed Q6600 to i5-6600 (again 6600? aargh 😵 ) in 7zip brings ~2x more performance.
102.36 KiB
Reply 104 of 209, by BSA Starfire
added results for my new Pentium II 350 MHz Toshiba Equium 7100s.
Reply 105 of 209, by SiliconClassics
Added results for my Core 2 Extreme QX6800 system (2.93GHz stock, OC'ed to 3.3GHz). WinXP, 4GB ECC RAM, Intel D975XBX2 motherboard.
183.46 KiB
Silicon Classics on: YouTube | Twitter | Google+
Reply 106 of 209, by Carlos S. M.
Added results for an Opteron 1216 overclocked at 2.88 GHz
Reply 107 of 209, by clueless1
Thanks for adding your results. 😀
Reply 108 of 209, by Carlos S. M.
np, i probably won't stop untill i run out of CPUs/PCs xD
Reply 109 of 209, by clueless1
Just added an i5-6400. Sadly, it is slightly slower than the i5-4460 even though it's got 100Mhz on the 4460.
Reply 110 of 209, by BSA Starfire
Just added a Cyrix 6x86 MII PR333 (75MHz x 3.5) @ 262 MHz.
Reply 111 of 209, by clueless1
First Cyrix on the list, nice! Looks like it's right on par with the K6-II 233 overall. The Cyrix has higher memory bandwidth, the K6-II slightly more processing power.
Reply 112 of 209, by BSA Starfire
Added my other Cyrix MII 333, this one is on a ALi Aladdin 5 motherboard(83 MHz x 3.0) for 250 MHz, it's quite a bit slower than the other machine on the SiS 5591/5595 despite slower bus speed of 75 MHz. SiS chipsets do really like the Cyrix, Linear burst mode is enabled(I've edited my spreadsheet entry now it's enabled, the CMOS battery was flat so BIOS defaults had been loaded, sorted that out now with a new CR2032!), I don't think the ALi has that option.
Reply 113 of 209, by shamino
Added Athlon64 X2 4200+, it was running v9.20 x64 version on XP64.
Does the disk performance matter for this benchmark? This system is running from an SSD, not sure if that should be noted. Seems like it ranks higher than I would expect so I'm wondering if that's why.
First time I've edited one of these things. I checked the revision history and it's highlighting as if I edited a couple cells below the row I added. I didn't touch them so I don't know why it says that but I compared with the previous version to make sure the values didn't change.
Reply 114 of 209, by clueless1
Everything looks good shamino. The SSD shouldn't effect the score unless you're in a very low-RAM system (even then, the ssd should let you run the benchmark on a low ram system with comparable results). There's lots I don't understand about what Sheets shows in the revisions. But when I first made this sheet, I set up the cpu usage column as a formula that would auto-fill when you put in the rating and rating per usage. But it wasn't set up very clearly, so people just typed the percentage in. If you check those two below your entry, they are using the formula, whereas the surrounding entries are typed in. That might have something to do with the revision weirdness.
Thanks for the entry 😀
Reply 115 of 209, by shamino
Ran a few tests on my Phenom2 machine. It's triple booting right now so I tried 3 OSes:
Phenom2 X2 555 (2x 3.2GHz) (WinXP64)
7.7 KiB
Phenom2 OC and unlocked to 3 cores (3x3.6GHz) (WinXP64, 4 execution threads used):
7.66 KiB
Both of these above scores were posted to the spreadsheet.
The following are for curiosity, I did not post them but feel free to add them if you don't think it's just clutter:
Same clocking, this time in WinXP32:
7.37 KiB
...the XP32 title bar is a different color. Huh.
Same clocking, Linux Mint 17.2 x64:
7z -mmt=4 b
7-Zip [64] 9.20 Copyright (c) 1999-2010 Igor Pavlov 2010-11-18
p7zip Version 9.20 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,3 CPUs)
RAM size: 5966 MB, # CPU hardware threads: 3
RAM usage: 850 MB, # Benchmark threads: 4
Dict Compressing | Decompressing
Speed Usage R/U Rating | Speed Usage R/U Rating
KB/s % MIPS MIPS | KB/s % MIPS MIPS
22: 9263 270 3341 9011 | 107838 283 3438 9729
23: 9396 283 3382 9573 | 106917 284 3439 9784
24: 9527 292 3514 10244 | 106773 288 3433 9906
25: 9384 289 3710 10714 | 103443 282 3445 9727
Avr: 283 3487 9886 285 3439 9786
Tot: 284 3463 9836
I think the score is supposed to be an average of Compressing MIPS and Decompressing MIPS on line 25 (32MB), so that score is 10220.
So with the same system and CPU clocking, WinXP32 scored 9467, WinXP64 scored 10087, and Mint x64 scored 10220. There is some variance of course, with these being the best of a few runs each. I don't think the difference between linux and XP64 is repeatable/significant, but the slight gap between 32bit and 64bit was definitely there.
One thing about the "Number of CPU threads" setting:
7zip doesn't allow using 3 CPU threads so with my 3-core system I set it to 4. I also tried using 6. I found that using an excessive number of threads increases the score a bit further by a few hundred points (I didn't post pics of those). Since everyone up to now has been using a number of threads that matches the number of CPU cores, to be as consistent as possible with that my triple core score used 4 threads, not 6.
Reply 116 of 209, by Anonymous Freak
I wish I still had a Pentium Extreme Edition-capable motherboard... I remember upgrading from that ridiculous CPU ("Presler XE", dual-core Pentium 4 with Hyperthreading) to a Pentium Dual-Core (Conroe/Allendale) and almost everything I did was noticeably faster. I had the PEE 965 (my favorite acronym for it,) usually overclocked to 4 GHz - a $999, 130W CPU. I "upgraded" to a Pentium Dual-Core E2180 at 2 GHz, an $84, 65W CPU. (I was actually turning my former gaming rig in to a server, at the same time I dropped the PCIe GPU in favor of onboard graphics; I had gotten a new Core 2 Extreme gaming rig.) "Max benchmark" power on the new config was lower than idle power was on the old - and for almost everything CPU-related, it benchmarked faster.
Sadly, I ended up frying that motherboard, and my only S775 board is Core 2+ only.
Reply 117 of 209, by Carlos S. M.
luckybob wrote:
playing around on my file server: http://i.imgur.com/0Pe6wStm.jpg […]
i just noticed now, why used 32 bit 7zip under Windows Server 2008 R2 which is x64? I'm pretty sure 7zip x64 will give a better score on x64 Systems
Reply 118 of 209, by luckybob
@carlos S. M.
Interesting. I could have sworn i was using x64. Next time im inside my server, i will have a look to be sure.
Reply 119 of 209, by agent_x007
I already tested and OC'ed both PXE* 965/840 versions 😀
Also : Almost all Core 2 MB's should support "PEE 965" (since it has 1066MHz FSB).
*My fav. acronym for them 😉
