7-zip benchmarks for over 60 CPUs
Reply 140 of 209, by clueless1
Standard Def Steve wrote:
Here's an old IBM Aptiva I just rescued.
Pentium 100, 64MB EDO, Windows ME
Cool! This system would be able to run the DOS version of the 7-Zip benchmark because it only has 64MB ram. The benchmark in this thread uses a 32MB dictionary size in 7-Zip, which needs 512MB; the DOS version uses a 256KB dictionary size, which only requires 8MB RAM.
Reply 141 of 209, by gdjacobs
P54C! That Aptiva might make a great DOS time machine. What's the onboard sound chipset?
Reply 142 of 209, by Standard Def Steve
It had this "Mwave" combination modem/soundcard, which I immediately replaced with an AWE64.
Reply 144 of 209, by m1919
Here are my benches running 7-zip 9.2 on my current rig with HT disabled and enabled.
Ran these before a post-1607 cumulative update bricked my OS install. Good going, MS. Love how it bricked the fresh 1607 install as well. Running on good old 1511 now.
HT disabled
HT enabled
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 145 of 209, by Carlos S. M.
Holy shit, you got the 1st score with your system
Reply 146 of 209, by Standard Def Steve
These newer Atoms aren't bad all! This Surface 3 doesn't even have a fan, yet it outperforms a 4.26GHz PEE 840, C2D E8600, and even a first-gen i3-370M.
Atom X7-Z8700, 4GB DDR3-1600, Win10
Reply 147 of 209, by clueless1
Added result for Athlon 64 3500+ AM2 Lima core with DDR2-800. No OS on the system so I ran from linux live USB 64-bit.
Reply 148 of 209, by tyuper
Added results from client's daily driver PC (HDD kicked the bucket completely), the Sempron 2300+ on ASRock K7S41GX motherboard.
113.76 KiB
Reply 149 of 209, by Carlos S. M.
Long time i haven't came here, i added results from another custom Pentium III 1 GHz system using a Biostar M6VCG (VIA 694X+686A), aparently it scored poor compared to my Dell Optiplex GX150 (i815E+ICH2) i used for my previouws P3 results, idk if it was the VIA chipset or just the board is not good, i'll try again once i get a better VIA based board.
OS was XP in both machines (my Optiplex GX150 and this current build with the Biostar M6VCG)
Reply 150 of 209, by Carlos S. M.
Added results from an old trash picked Dell Latitude E6410, it has an Intel Core i5 560M and 4 GB RAM
Reply 151 of 209, by Carlos S. M.
Added results from an i7 7500U (Kaby Lake) and an AMD A10-9700 (Bristol RIdge), also added an old Core 2 Duo T5500, aparently, the new Bistol Ridge APU outperformed the FX4300 on this test when the newer i7 7500U outscores anything U and even some desktop i3s
Reply 152 of 209, by Carlos S. M.
Added results from a Celeron 766 on the Dell Optiplex GX150 as well, is the strongest FSB 66 Coppermine Celeron, it loses to my Pentium 3 667 on the same machine
Reply 153 of 209, by ElBrunzy
I was browsing the forum while I was benchmarking three single ppro 200mhz with 256, 512 and 1024kb of l2 when I stumbled on that threat so I decided to add 7zip to my battery of tests. I beleive my number make sense with luckybob dual ppro overdrive running nt. I use win98se and 32bit zip 9.20. You could add those number to the spreadsheet because I wont do it, I'm just too lazy and afraid to break your chart... I left everything on default and just run 2 pass.
256kb
       speed	cpu usage	rating
comp 162KBs 100% 158MIPS
deco 1998KBs 100% 180MIPS
512kb
comp 168KBs 100% 164MIPS
deco 2023KBs 100% 182MIPS
1024kb
comp 170KBs 100% 166MIPS
deco 2029KBs 100% 183MIPS
Reply 154 of 209, by m1919
I've got some plans in the works for my Skulltrail board. Stay tuned for some hilarity coming soonish.
Reply 155 of 209, by swaaye
Yeah, 7-zip is sort of a best case for the Atom because it can use all 4 cores.
Reply 156 of 209, by clueless1
ElBrunzy wrote:
I was browsing the forum while I was benchmarking three single ppro 200mhz with 256, 512 and 1024kb of l2 when I stumbled on tha […]
256kb
512kb
1024kb
It looks like you are reporting the individual MIPS ratings for Compress and Decompress, rather than the overall result. Not sure I can use those in the chart. 🙁
Reply 157 of 209, by ElBrunzy
I left it out because it was just exactly the same, use them or dont, I could not care less. but trust me, the final result are the same, I left one computer run for an hour as I forget it and it was .... the same ! 😵
Reply 158 of 209, by Carlos S. M.
Added results from a VIA C3 1.0 Ghz Nehemiah in an VIA EPIA-M board, will do DOS benchmark later
Reply 159 of 209, by BSA Starfire
Added Pentium III 733MHz, SiS 630 ECS motherboard. It's a lot quicker than the VIA C3 1.2GHz "nehemiah" chip that I just replaced in the system.
