7-zip benchmarks for over 60 CPUs
Reply 160 of 209, by Carlos S. M.
Added a Celeron 1300 Tualatin using the new Gigabyte GA-6OXT i got yesterday, also i'll benching a P3-S 1.4 Ghz with it later
Reply 161 of 209, by Carlos S. M.
Added an i7 6700K result from a friend, the CPU was running at stock
Reply 162 of 209, by Carlos S. M.
Added my P3-S 1.4 @ 1.57 using the same Gigabyte GA-6OXT, it scored worse than the other P3-S at 1.57 ghz, but DDR instead of PC133
Reply 164 of 209, by clueless1
Added a Xeon X3230...the server equivalent to the Core 2 Quad Q6700.
48.92 KiB
Reply 165 of 209, by clueless1
Any have access to a Ryzen? 😀 Would love to see how it compares to the other results on this chart.
Reply 166 of 209, by Kamerat
BSA Starfire wrote:
Added Pentium III 733MHz, SiS 630 ECS motherboard. It's a lot quicker than the VIA C3 1.2GHz "nehemiah" chip that I just replaced in the system.
Funny to see that a "Nehemiah" 1,2GHz on the BX chipset outperforms the same CPU on the 630 chipset by 41%.
YouTube channel
Reply 168 of 209, by clueless1
seob wrote:
My results for my Ryzen 7 build.
Nice, 7th place on the chart, between a pair of 6c/12t Xeons that are clocked over 4Ghz.
Reply 169 of 209, by enloop
Hey I have some questions. When these results are taken is background processes being halted/closed while the testing is happening?
And when I'm reading 2x or 4x in front of the model/name is that referring to the number of cpus being used? Just wondering.
Reply 170 of 209, by clueless1
You should not have any other programs running while testing. Ideally, you do a clean boot, let the machine "settle", then run the benchmark a few times in a row to check for consistent results, then report a consistent high result.
Second question: those tests were run on multi-CPU systems.
Reply 171 of 209, by Carlos S. M.
nice score, i planned some sort of Ryzen update myslef. an R7 1700X with +32 GB RAM and a good B350/X370 mohterboard in the future
Reply 172 of 209, by kithylin
Personally I'm waiting for the 6 core versions and see how they're priced to consider it.. but before that I'm most likely investing in a top of the line Vega card before the end of the year. Hopefully we get aftermarket versions with 3rd party waterblocks for em.
Reply 173 of 209, by Carlos S. M.
Added results from an AMD A8-7410 and an i3 540
Reply 174 of 209, by clueless1
I was going to add i5-6200u results the other day but saw that there were already 2 entries for that cpu. But my result was higher than those two, so I might add them Monday with more detail on the laptop they are from.
Reply 175 of 209, by clueless1
106.58 KiB
HP ProBook 470 G3
i5-6200u
8GB DDR4 2133
Faster than two other results for the same cpu on the sheet. Maybe the other two used DDR3?
Reply 176 of 209, by Carlos S. M.
Added results from a Duron 1000 and an Athlon XP 2400+ on an ECS K7S5A motherboard, i couldn't try the Duron with DDR266 and the Athlon XP with DDR200 since the board refuses to POST when the FSB/DRAM ratio is not syncronized
Reply 177 of 209, by Carlos S. M.
Added an i5-7300HQ, i7 4790, AMD FX 770 and an Atom X5 Z8350
Reply 178 of 209, by skv400
This is Korean's website DCInside computer galley's 7zip chart. ( http://gall.dcinside.com/board/view/?id=pride … &s_keyword=7zip )
board users can upload their 7zip benchmark data.
ex:
    1.05 MiB
Youtube Channel : https://www.youtube.com/channel/UCeaVPa3VMe9nUGDtFtVzvDQ
Reply 179 of 209, by Carlos S. M.
Added results from my E8600 overclocked to 4.4 GHz (Crazy overclock 🤣)
I moved the E8600 from the HP DC7800 to a nice Gigabyte GA-P35-DS4 rev 2.1
I managed to outperform a Q6600, Q9300, an i5 6200U, my Phenom X4 9550, multiple later Pentiums and even the crazy overclocked Pentium 965 XE @ 4.87 ghz
