7-zip benchmarks for over 60 CPUs
Reply 200 of 209, by zerker
I realized I never benchmarked my new PC (i5-7600), so I set about doing that now. And decided to do it on my terminal, because why not? Here are the results.
FYI: Debian Stretch and probably any derivative distros now have 16.02 as the packaged version. I had to download the Jesse package to get 9.20, then just extract it and run it manually.
Reply 201 of 209, by Kamerat
Did add a result for my overclocked Lenovo 3000 C100 (Pentium M 745A 1,8GHz @ 2,56GHz) laptop yesterday. Nice usage of your terminal btw, zerker. 😁
YouTube channel
Reply 202 of 209, by Carlos S. M.
Haven't posted here for a long time, but i benched my current laptop which replaced my old i7 5500U, an i7 7700HQ laptop
Reply 203 of 209, by Carlos S. M.
Added results from my new (trashpicked) and overclocked i7 930 rig
Reply 204 of 209, by clueless1
Hi guys, just wanted to reiterate to those who may still be adding results, please only use 7-zip version 9.20. I just tested the latest version (19.0) and its results are significantly higher than the same machine benchmarking on 9.20. My i5-4590 scores 16.3k MIPS on version 9.20 and over 21k MIPS on version 19.0. Plus, version 9.20 runs on Win98 so it leaves the door open for older CPUs on older OSes.
I fixed a deleted field and noticed the chart had been sorted all sorts of ways over the past year. If you do change the sort, please set it back to Column H (Rating MIPS) descending before you leave the page.
I added a result for the i5-4590.
Link is in the first post.
Reply 205 of 209, by BSA Starfire
Added my AMD Opteron 1354(4 cores, 2.2 GHz) & i7 950 to the spreadsheet. Sheet sorted as requested.
Reply 208 of 209, by jazper
i9-9900k
OC 5.0ghz 1-7 core + AVX offset 0
4.9ghz 8 core (AVX offset 0)
Gigabyte Auorus Ultra z390
Reply 209 of 209, by debs3759
i7-6700K @4 GHz on a Maximus VIII Hero. DDR4 @2666
    44.68 KiB
