7-zip benchmarks for over 60 CPUs
Reply 80 of 209, by Carlos S. M.
Added more CPUs
Pentium 4 2.0A, 2.40 (FSB 533), 2.53. 2.60 (FSB 400), 2.66 and 2.80 (FSB 533) in two plataforms, an old i845PE system with DDR333 (DDR 266 for FSB 400) and a newer i865PE system with dual channel DDR 400 (DDR333 mode for FSB 533 and DDR266 mode for FSB 400). Testing FSB 800 CPUs and Prescotts on the i865PE Platform tomorrow
Pentium D 930, Celeron D 355 (Prescott) and 352 (Celdar Mill), Celeron 420 and Pentium E2140 on a ASUS P5PE-VM with dual channel DDR 320 (i noticed late when i found out i used DDR333 instead of 400 on that system)
Does someone tried 7-zip on a Pentium 4 clcoked higher than 3.4 ghz or a Gallatin based Pentium 4 Extreme Edition? I'll bench my P4 670 when it comes and i have a situable mobo for it
Reply 81 of 209, by kithylin
Carlos S. M. wrote:
Added more CPUs […]
Added more CPUs
You were wanting 7-zip run on a Pentium 4 clocked higher than 3.4 Ghz? Okay! Ask and you shall receive....... 😎 🤣
It's only running with single channel ram at the moment though, I can't find my other stick.
EDIT: Nevermind, went in the other room and it was on the table under some wires (the ram stick.) Here we go P4 in "All it's glory" dual channel mode.
Reply 83 of 209, by kithylin
swaaye wrote:
Looks like memory bandwidth isn't exactly a limiter there. 😉
Nope, it's most likely just the P4 architecture being a steaming pile of poo.
Reply 84 of 209, by Carlos S. M.
Added more CPUs:
Pentium 4 2.6C, 2.8C, 2.8E, 3.0C, 3.0E, 3.2C, 3.2E and 2.8A on the same i865PE plataform as the previous P4s (Gigabyte GA-8IPE1000-E)
Reply 85 of 209, by Carlos S. M.
PhilsComputerLab wrote:
Nine. I have an E300 notebook. Funny that a Pentium D can beat it...
i just noticied the E300 is not only slower than a Pentium D, is also slower than any P4 HT clocked at +2.8 GHz or even my dual P3-S 1.4 GHz Tualatin Server aparently
Edit: Already over 200 CPUs benched
Reply 86 of 209, by Standard Def Steve
Here are a bunch of different CPUs. The DDR-equipped PIII-S @ 1575 just destroys the P4-2400 here. It's also over twice as fast as the Athlon-1333 at compression. I'm guessing 7-Zip makes heavy use of SSE?
Interestingly enough, the 3GHz Opteron 185 is a fair bit faster than the 2.93GHz C2D E7500 at decompression. And the overclocked i7 is high as a kite.
All are running v9.2. Will add more CPUs as I get the chance.
PII-300, 192MB EDO, Win2000
Athlon-1333, 512MB PC-133 CL3, XP-SP3
P4-2400 (400FSB), 1GB DDR266 CL2, XP-SP3
PIII-S @ 1575MHz, 2GB DDR300 CL2, XP-SP3
Atom N470 w/HT (1833MHz), 2GB DDR2-667, Win7-SP1
Mobile C2D T5600 (1833MHz/667FSB), 4GB DDR2-667 dual channel, Win7-SP1
C2D E7500 (2933MHz), 8GB DDR3-1066 dual channel, Win7-SP1
Opteron 185 (3000MHz), 4GB DDR400 CL2 dual-channel, Win7-SP1
i7-4930K @ 4500MHz, 32GB DDR3-2133 quad-channel, Win7-SP1
Reply 87 of 209, by Carlos S. M.
Added my Acer Aspire V3-771G Laptop (i5 3210M) to the sheet
Reply 88 of 209, by Carlos S. M.
Added my Brother's Athlon X2 7750 BE
Reply 90 of 209, by Standard Def Steve
Pentium M @ 2.72, 2GB DDR2-544 dual-channel, Win7 SP1.
Not bad at all for a 1C/1T processor.
Reply 91 of 209, by Carlos S. M.
Added P4 670 on my ASUS P5PE-VM testbed, this time i used the right DDR400 RAM on this system
Reply 92 of 209, by Carlos S. M.
Added 3 Skylake Laptop CPUs: an i7 6700HQ, an i7 6500U and an i5 6200U, aparently the 6700HQ beats my main i5 rig even at 4.8 ghz OC, the i7 6500U beats my i5 3210M laptop and the i5 6200U loses to my 3 1/2 year old i5 3210M laptop
Reply 93 of 209, by clueless1
Thanks, it's great to see some Skylake procs on the list.
Reply 94 of 209, by BSA Starfire
Added results for my AMD FX4300.
259.34 KiB
Reply 95 of 209, by agent_x007
Pentium 4 Extreme Edition 3,2GHz [PGA 478] @ 3,574GHz : 2536MIPS
220.45 KiB
Can someone add my result, thank you.
Reply 96 of 209, by clueless1
I started to add it and the Sheet started having fits. Keeps asking me to reload in an endless loop. Going to leave it alone for a bit and check back in later to see if it's cleared up. In the meantime, if someone else can get in and feels like it, go ahead and finish entering agent_x007's results.
Thx.
edit: Got it. My ISP was having some outages. All good now. 😀
Reply 97 of 209, by Kamerat
Added a dual Xeon server.
Edit: Changed memory from 4x512MB to 2x2GB and used WPCREDIT to tune timings.
69.03 KiB
YouTube channel
Reply 98 of 209, by BSA Starfire
Added Celeron 466 MHz Menocino & K6-2 450 on sis530 motherboard.
Reply 99 of 209, by Carlos S. M.
Added my i7 5500U laptop, for some reason, it outperforms the i7 6500U laptop i benched days ago
