Reply 20 of 192, by BSA Starfire
- Oldbie
wrote:wrote:@Kamerat […]
@Kamerat
I am little wondering about your values 3DBench & DOOM with T-Bird & GeforceFX5500. Should not be the FX5500 as strong as my GF2MX-400 or even little stronger?
When i look at the specs on wiki, the FX5500 has even with 64bit DDR a 20% higher memory bandwidth like a stock GF2MX400. Also the raw power is twice (FX5500 - 1080MOperations/s, GF2MX-400 - 400MOperations/s).
Finally the T-Bird should be little faster than a K6-2...I don't know why I got so bad results. Changing the graphic card to ATI Radeon 9700 Pro improved 3DBench and Doom somewhat, 407.8fps vs. 332.6fps and 84.49fps vs. 80.57fps. Still my Doom result is kind of shitty compared to your K6-2 500 @ 117.81fps.
For a comparison of K7 have a look at entry 632 in phil's spreadsheet, it's my Duron "spitfire" 650MHz, Nvidia RIVA 128.
