First post, by Achtman
Hello!
I am currently trying to install Command & Conquer: Red Alert
Every time that I mount the drive normally it says insert the disk. Every time I mount the drive with the -t CDrom it says I don't have enough space. Every time I mount the drive with the -freesize it asks me to insert a disk. I tried just mounting the drive with both the -freesize and the -t CDrom commands, but it still asked me for more space.
Is this a game specific problem or can I not combine the two commands?
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It says? What says what?
And no freesize is not compatible with -t cdrom. A CD-Rom CANNOT have free space (meaning disk space to write to).
Did you also mount a folder?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by Achtman
Sorry I didn't clarify my bad 😐
It says= Command and Conquer, it successfully launches but straight to a "insert a disk now" screen when I mount the drive normally without -freesize or -t cdrom
Yes I mounted the folder that contains the launch files, and the folder also contains Dos-box.
Pictures are attached of what happens when I mount the drive.
16 KiB
15.39 KiB
14.96 KiB
8.1 KiB
If I mount the drive normally and launch the game, it asks me to insert a disk
If I mount the drive with the -t cdrom then it clears the screen and tells me I need more memory. It then tells me to press any key and I am given back the prompt.
Thanks for trying to help 😁
PS: The manual has nothing helpful
Reply 3 of 5, by collector
Mount both a "C:" drive and your CD-ROM drive. Al so it is a good idea to not mount the base of your C: drive, instead mount a folder for your C: drive.
Then change to your CD drive and run the installer.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 4 of 5, by Yesterplay80
Achtman, do you use actual CDs or ISO images for the game? If you are using CDs you should mount the drives like this:
mount c  <DRIVE:\SOME_FOLDER_ON_YOUR_HARDDRIVE_THAT_IS_NOT_C:>
imgmount D <YOUR_CDROM_DRIVE_LETTER:> -t cdrom -fs iso
For example, if you have or create a "Games" directory on your hard drive C: and have a CD-Rom drive as D:, this results in
mount c  C:\GAMES
imgmount D D: -t cdrom -fs iso
If you are using ISOs instead of CDs, change the "imgmount" command line to
imgmount D <DRIVE:\PATH_TO_WHERE_THE_ISO_LIES> -t iso -fs iso
So, assuming you have the ISOs stored in C:\ISOS and the ISO file names are CCRACD1.ISO and CCRACD2.ISO, you would use
imgmount D C:\ISOS\CCRACD1.ISO -t iso -fs iso
to mount only disc 1 and
imgmount D C:\ISOS\CCRACD1.ISO C:\ISOS\CCRACD2ISO-t iso -fs iso
to mount both discs, you can switch between the discs with CTRL+F4 in DosBox.
I hope that helps you a bit, for more inof refer to http://www.dosbox.com/wiki/IMGMOUNT
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
