First post, by ltcolonel97062
I am a user of SierraHelp.com sierra game installers. Every game I install using their installers, crashes, after the game is installed. I am using Windows XP Pro I would post the pictures that come up, when I try to load the games, but this site doesn't allow the size they are. Any help would be appreciated.
Reply 1 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Moved to Dosbox forums. Please post Dosbox questions in the Dosbox subforums.
As for screenshots, please resize the image or load it to imgur or something like that. Most likely crop the screenshot to only show the relevant window instead of your whole desktop.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 11, by ltcolonel97062
I am not sure where the "Dosbox subforums" are on here. Also not sure on how to "resize" pictures. I am NOT computer savy as some of you are on here, and that is why I am seeking help.
Reply 3 of 11, by Dominus
DOSBox Moderator
I moved the topic, but take a look at the forum but next time take a leider ok at the forums here. And unlesss you learn how to crop pictures or you transcribe the error message no one can help you
Reply 4 of 11, by ltcolonel97062
Ok, hopefully these pictures give some idea on what is going wrong and why the games crash on me. These pictures should be in order.
    518.2 KiB
    306.46 KiB
    11.67 KiB
Reply 5 of 11, by Dominus
DOSBox Moderator
No, sorry these don't help at all. When you run dosbox on its own what happens?
Reply 6 of 11, by ltcolonel97062
All the games play just fine. No crashing at all. But the point is, for me to be able to use the shortcuts, that either Sierrahelp's site creates or that I do, and that's when the crashing occurs.
Reply 7 of 11, by Dominus
DOSBox Moderator
Then please write down what you have set in the shortcut
Reply 9 of 11, by Dominus
DOSBox Moderator
Yes.
If Dosbox works directly then it is likely something with your shortcut.
Reply 11 of 11, by Dominus
DOSBox Moderator
