Yamaha YMF7x4 Guide
Reply 120 of 334, by ruthan
I want to test my second Yamaha 744 with my i865 machine, where other Yamaha 744 worked, i got strange error boot that legacy audio is disable.. I tried to load setup utility, but i get message that there not Yamaha chip card inserted (Cant find Yamaha DS-XG). When started it realmode without driver utility can be executed.. (but i dont know if it is big deal). That second card, worked fine with VIA 880 Ultra (with exactly same driver, i just copied it not change anything in ini or setup utility) only disadvantages was some crackling in some games and worse compatibility - but i though (and thing) that was "just compatibility think", i double checked if its right in slot..
After that i tried my first Yamaha 744, first already worked with this machine, with exactly same settings and its working fine, in exactly same slot.
Conclusions:
- If didnt killed my second Yamaha 744 (in process i assume that i didnt).
a) My second card is half dead, i had 3rd card some same Polish source, which not worked even with Via 880 ultra, i dont have it now at this location, i thought that i could be problem with slot contact, but my testbench sucks - cards is 1-2mm higher than it should be.
b) There is some difference between cards, maybe some firmware etc. I looked at chips there is slight difference in not working has (Yamaha744B-R), working one has (744-V). True is that second card was cheap, it is a bit paranoic, but i would be totrally surprised if someone would try to sell some half that RMA cards, because seller had lots of them.
I looked into datasheet:
only difference i found is this:
YMF744B-V : 0.5mm pin pitch
YMF744B-R : 0.4mm pin pitch
Some pictures..
Working one, its looks more deluxe, has digital output, it was advertised as Aopen one:
348.86 KiB
239.34 KiB
218.17 KiB
NonWorking one - regarding of A logo is Abit or Aopen too:
419.62 KiB
306.12 KiB
Any ideas?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 121 of 334, by j^aws
ruthan wrote:
NonWorking one - regarding of A logo is Abit or Aopen too: […]
Any ideas?
This 744 chip is a different shape than the working one, and looks like a rebranded knockoff/ fake. This chip is smaller and squarer, which resembles a 754, but it is still printed as a 744. It's probably some CMI 87xx knockoff...
Reply 122 of 334, by ruthan
If it is fake, its very good one because with other mainboard is recognized by Yamaha driver and at least partially is working..
Reply 123 of 334, by cyclone3d
Any ideas?
Nope, definitely not a fake. Those cards were made by AOPEN. The layout of their AW744-L card (with the larger chip) is almost exactly the same except for the changes required for the smaller footprint chip. The part number for the one with the smaller chip is AW744-L2.
You can look it up on AOPEN.com and then go to whatever region. Then go to Support and then "Other Useful Links -> Downloads -> Sound Cards, and then the model number.
And if you look at the YMF744B datasheet, it shows BOTH types of chips.
http://pdf.datasheetcatalog.com/datasheet_pdf … d_YMF744B-V.pdf
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 126 of 334, by ruthan
I did some more testing.. even cheaper Yamaha is working with Conroe 865, but i have probably too much PCI cards / MB problem, because once is sound card / nic / working at boot, once not.
Reply 127 of 334, by tpowell.ca
Anyone find a way to enable the digital input mixer setting in DOS ?
I connected my CD-ROM's digital audio out to the card. Sounds perfect in Windows, but it is muted in pure DOS. The SETUPDS utiliy has no setting for DIGITAL IN. 🙁
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 128 of 334, by cyclone3d
Maybe look in the .INI file that SETUPDS uses.
YMF7x4 Guide
Reply 129 of 334, by tpowell.ca
Yup, that was the first place I checked. But it only seems to have analog inputs and outputs.
Reply 130 of 334, by RayeR
You can try my YMF7xx tool to manually change mixer registers if you find which one is CD digital volume (see linux header file to have an idea which registers belongs to mixer).
Re: Pure DOS gaming system with 100% digital audio output
Reply 131 of 334, by tpowell.ca
Wow.
RayeR strikes again. Your SMB tool has been a massive help in obtaining different FSB settings on my 440BX motherboard without touching jumpers.
Have you found out which registers control other things beyond the SPDIF out? <-- nevermind, the header file you spoke of answers those questions.
Ok, so it seems that to enable the SPDIF IN to pipe out through the DAC you need:
reg 08h set to 00h
reg 34h set to 25h
The volume is set by reg 88h (left) and 8Ah (right) with the param being maxed out at 3FFFh I believe.
Cheers and thanks for the great tools!
Reply 132 of 334, by RayeR
You're welcome. Nice to read you figured out the digi CD/spdif inpunt. Register names are not much clear and also it may vary on different soundcards how the chip inputs are routed. But I could change this mixer description. I persnonally don't use digital in/out on YMF as I use it only for DOS and SB Audigy is my primary card. It would be nice ro reveal SBA mixer config so I could route YMF output via SBA without use of a selector switch between soundcards outputs and amplifier...
BTW SMB is still under development but I have some modules messed up due to my various experiement (e.g. ATA TRIM) so I cannot compile a clean release now, but one day it will come 😀
Reply 133 of 334, by tpowell.ca
Also, having been to Prague a few times, I must say that I really miss the good food and especially the fantastic beers you guys brew.
I didn't like Staropramen that much but I was a big fan of Bernard.
Reply 134 of 334, by RayeR
Hehe, I wouldn't call Staropramen a beer 😀 but it's almost everywhere and cheap one, Bernard is OK.
If you will come back try to visit:
http://www.zlycasy.eu
http://www.restauracekulovyblesk.cz
http://www.ubansethu.cz
There you find various local beers and good kitchen for good price 😀
I have never beed in USA yet.
Reply 135 of 334, by gdjacobs
Come to Canada instead! We try to be pleasant to make up for the awful winters.
Reply 136 of 334, by tpowell.ca
Indeed, although I really think that our ridicule of American beers is just nonsense. Our mainstream beers are just as bad, and their microbrews are amazing (as are some of ours).
Reply 137 of 334, by gregholwell
I have found in testing a PCI card (Labway Xwave 5000) which holds the YMF724 chip that the Sondius-XG feature, which is available with the Windows 95/98/98SE/ME .vxd driver but not with the Windows 2000/XP/etc WDM driver, is compatible with the VL70m synthesiser except that the Distortion block (Sysex address 03 00 xx) is not implemented. The latency is sufficiently low that I can play directly from a keyboard, whereas the S-YXG100 softsynth has advertised something like 500ms latency and thus seems useful only as an option to play midifiles. See also https://groups.io/g/YamahaYMF7x4.
Reply 138 of 334, by gregholwell
"VL voices are not GM-compatible, and are useless for anyone who is not a musician."
I disagree. VL-XG voices (Bank MSB 97, Bank LSB 112 to 119) will play as VL70m voices on a Sondius-XG enabled YMF7x4 (and presumably S-YXG100 softsynth) and as Key Scale Panning (Bank MSB 0, Bank LSB 1) voices on any other Yamaha XG-based synth. What's more, the Reverb, Chorus, Variation and multi-part data are mostly the same as for XG (exceptions include assignable controller 2 and amplitude modulation) .
Reply 139 of 334, by Concupiscence
This thread is a heck of a resource, thank you all so much! I do wonder about my prospects for getting my AOpen YM744 working in an EVGA P55 LE with a Core i5 750, but will report back here with results.
