Yamaha YMF7x4 Guide
Reply 220 of 230, by Prez
Riikcakirds wrote on 2020-12-26, 00:52:
Read through the thread and couldn't find an answer. What is the reason why everyone uses SETUPDS version 3.16 and not the later version 3.17.
Hi ! It seems i don't have it.
Do you have or can make a direct link to download this version please, so i can give a try ?
Best regards
Philippe Dubois
Old computers and videogames freak
President of french association https://mo5.com
Get better, get old ! 😁
Reply 221 of 230, by ruthan
There were some unofficial patches for 3.16 or 3.14, to make it running on more chipsets..There was link to download page, where it was described somewhere in Vogons..
Hmm. links from 1# post are mostly dead, so try to use internet Wayback machine with them 2,3 years ago time period.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 222 of 230, by Riikcakirds
ruthan wrote on 2020-12-26, 16:04:
Ver 3.17 did fix a problem I have with IRQ being set to 127.
This was the update log on what was new/fixed in setupds.
Version 3.17 (11/15/99)
- Fixed the problem that INTA# IRQ was sometime set to 127 when INTA# was shared
with other devices.
Version 3.16 (11/1/99)
- Warm reset will be issued when the AC97 devices go into the power down mode. (For
YMF744, 754 only.)
- Fixed the problems that happened with specific systems using PIIX4 chipset.
Reply 223 of 230, by Prez
Riikcakirds wrote on 2020-12-27, 23:18:
Ver 3.17 did fix a problem I have with IRQ being set to 127. […]
with other devices.
YMF744, 754 only.)
Do you have a link to the 3.17 version please ?
Best regards
Philippe Dubois
Reply 224 of 230, by Riikcakirds
Prez wrote on 2020-12-28, 07:16:
Do you have a link to the 3.17 version please ? […]
with other devices.
YMF744, 754 only.)
Best regards
Philippe Dubois
I will attach it to this post. Can't remember exactly what website I got version 3.17 from now, it was some website with a Drapeau du Pays de Galles on it I downloaded in 2001. I'm trying to find in on archive.org because i'm certain there was also a version 3.18 released in January 2000. I will have a look on my old dos hard drive if I can find it. Can't seem to find any existence of it on the internet now.
(only attaching setupds.exe , all other files the same as 3.16)
setupds 3.17.7z
69.02 KiB
44 downloads
Reply 226 of 230, by vorob
Crackling may be caused by too high maximum volume. Sometimes it's because driver allows to set the volume too high, when it was taken from another card. With VxD drivers you may fix it in registry: HKEY_LOCAL_MACHINE\Software\YAMAHA\Driver\YMF724\VolumeMax, or by YMF7x4Utilities.
Sorry, but I fail to do further steps. What do I need to change in the registry to have a lower max sound or what should I press in this Japanese program? Thanks.
112.6 KiB
Reply 227 of 230, by RayeR
vorob wrote on 2021-04-14, 10:25:
Hi, i've got a laptop with 754. In Audio Mixer i've got a 3D Wide regulator. What is it and why it is turned off by default?
It's some king of DSP effect that should try to enhance stereo effect but I would call it rather sound crippling so it's better to have it disabled, at least for listnening music.
Gigabyte GA-P67-DS3-B3, Core i7-2600K @4,5GHz, 4GB DDR3, 128GB SSD, GTX670(GF7900GT), SB Audigy + YMF724F + DreamBlaster combo
Reply 228 of 230, by cyclone3d
What laptop is it and what driver are you using?
Working on getting a working VXD driver for Sony laptops with the 754 and anything helps.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 229 of 230, by vorob
cyclone3d wrote on 2021-04-14, 16:21:
It’s all here: Toshiba 2805-s402 Ultimate retro gaming laptop
Didn’t it help?
Reply 230 of 230, by cyclone3d
vorob wrote on 2021-04-14, 17:59:
Didn’t it help?
Ah, ok. I still haven't had a chance to try the Toshiba driver.
Yamaha YMF7x4 Guide
