List of motherboards with SB-link (PC/PCI) header
Reply 101 of 108, by Dant
There appears to be solder pads for SB-Link on the Intel D850EMV2. Its the right configuration of pins and given its proximity to the ICH2, I'm inclined to think its PC/PCI.
468.99 KiB
1.3 MiB
Reply 103 of 108, by greasemonkey90s
ShovelKnight wrote on 2020-04-05, 14:42:
According to the manual, AOpen AP5TC is a rare Socket 7 motherboard (i430TX) with an SB-Link header.
I must be special then. Came up on that board in a motherboard lot. Yes your right it indeed does have sb-link. Almost feels kinda useless when it has isa slots already. Either way its a interesting board i hope can work with a 266 Tillamook.
Reply 105 of 108, by Joseph_Joestar
I have recently acquired a new retro rig with the Abit ZM6 motherboard and can confirm that it has a working SB-Link header. This motherboard is based on the Intel 440ZX chipset (socket 370).
Just tested it with my Yamaha YMF724 and SB-Link worked perfectly.
PC#1: Pentium MMX 166 / Soyo SY-5BT / S3 VirgeDX / Voodoo1 / OPTi 82C930 / AWE64
PC#2: Celeron 466 / Abit ZM6 / Voodoo3 / AWE64 / YMF744 / SC-155
PC#3: AthlonXP 1700+ / Abit KT7A / GeForce4 / SBLive / ALS100
PC#4: Athlon64 3700+ / DFI LanParty / 9600GT / X-Fi Titanium
Reply 107 of 108, by Joseph_Joestar
Velociraptor wrote on 2020-06-27, 17:31:
What does the SB-Link do for us?
Connecting a PCI sound card to the motherboard using SB-Link improves its compatibility with DOS games.
Broadly speaking, PCI sound cards use either SB-Link, DDMA or a TSR program to function under DOS. In terms of compatibility, SB-Link tends to give the best results followed closely by DDMA. Compatibility using a TSR program can be hit or miss, varying largely between games.
