Reply 2460 of 2569, by Spesek
Falcosoft wrote on 2026-02-15, 18:32:
Hi,
If I remember correctly Bassmidi already supports setting individual drum key's chorus send level. The problem is not this, but the default state. For many years Bassmidi by default was compatible with the way Creative's SB HW SF2 synths handled chorus on drum channels (that is no restriction after a GS reset). Then suddenly it changed to be compatible with Roland GS hardware (and thus incompatible with SB HW SF2 synths).
You can restore the old behavior by applying new flags (and FSMP applies this flag when the 'No SysEx' reset option is enabled) but for me such changes would be more acceptable if they were intruduced as opt-in instead of opt-out...
Hi,
Bassmidi support pitch, but not chorus. (and the pitch support is also incorrect, but more on that later).
The easiest way to test is with another MIDI by Kr.palto47, this time from touhou 19 (the 88pro version). It sets chorus for snare drum 1 (key 38 i believe), but Bassmidi does not apply any chorus to the note. You can confirm this with SC-VA or spessasynth's latest development branch. This MIDI also alters the pitch of the drums, but it does so via a sysEx command rather than NRPN and Bassmidi doesn't seem to recognize those either.
Another example is This MIDI file, which uses NRPN for chorus. More precisely, it sets the snare 2 drum chorus to 64:
The attachment Screenshot_20260215_194809.png is no longer available
(the software is GS Advanced Editor)
And Bassmidi doesn't apply any chorus to the snare.
What's also interesting is that SC-55 had the behavior matching SB2 synths:
When you choose the SC-55 drum map in GSAE, the drum editor shows that chorus is enabled for all drum instruments by default, which is not the case on any later drum map (88,pro,etc.).
Nuked-SC55 confirms this.
Now regarding the pitch tuning, it is very strange. For the sysEx version of the command, it specifies the amount in semitone steps, while for the NRPN version the amount is in 50 cent steps. I thought this was an SCVA bug, but I sent the a test file to someone who owns a real SC-D70 and the behavior is replicated there (and youtube recordings with an 88pro seem to match it as well). Very strange! And, of course, if you select the sc-55 drum map the pitch in NRPN does use the full semitone steps...
Reply 2461 of 2569, by Falcosoft
Spesek wrote on 2026-02-15, 18:55:
Hi, Bassmidi support pitch, but not chorus. (and the pitch support is also incorrect, but more on that later). The easiest way t […]
Hi,
Hi,
Thanks for the deep analysis! If this is the case then the GS chorus related changes in newer Bassmidi versions are more annoying than I thought 😀
According to this the new behavior of Bassmidi is not compatible with anything while the old one was at least compatible with SB HW SF2 devices and to some degree with SC-55.
Would you be so kind to make a bug report to Ian at un4seen.com?
You can explain the problem much better than me. I will follow your post and provide full support if it's needed.
Thanks in advance!
@Edit:
I have made a bug report to Ian but I have only mentioned the problems I could test. I think you can extend the bug report with the results of your analysis.
https://www.un4seen.com/forum/?topic=20880.ms … 46246#msg146246
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 2462 of 2569, by Spesek
Falcosoft wrote on 2026-02-15, 19:46:
Thanks for the deep analysis! If this is the case then the GS chorus related changes in newer Bassmidi versions are more annoyin […]
Hi,
Hi,
Thanks in advance!
@Edit:
Hi,
I saw the report you made and I think you explained it pretty well. Feel free to use my analysis to explain what's wrong in BM.
If you want to test the drum pitch file for yourself, I used this file:
https://github.com/spessasus/spessasynth_core … ch_nrpn_test.ts
simply run it through tsx and it should produce the output MIDI file which firstly changes drum pitch via sysEx and then via NRPN. It's very easy to hear the difference in SCVA.
PS: In your report you mentioned that SC-55 and SC-88 resets are different. How so? Can you explain please?
Reply 2463 of 2569, by Falcosoft
Spesek wrote on 2026-02-15, 22:32:
Hi, I saw the report you made and I think you explained it pretty well. Feel free to use my analysis to explain what's wrong in […]
Hi,
Thanks in advance!
@Edit:
Hi,
Hi,
1. I think the pitch issue is a separate one and currently I do not think I'm willing to deal with it.
2. SC-88 and later devices recognize special SC-88 mode set messages that also function as a (GS) reset. They can be tested with SC-VA:
F0 41 10 42 12 00 00 7F 00 01 F7
The attachment SC88Reset.jpg is no longer available
SC-88+ specific Midi files use them many times. Bassmidi also recognizes such messages as equivalent to a GS reset.
@Edit:
BTW, your SC-88Pro LCD Bitmap example files also contain such messages instead of classic GS resets:
The attachment SC88Reset2.jpg is no longer available
Website, Youtube
Reply 2464 of 2569, by Falcosoft
Hi,
Ian has responded to my report and regarding Bassmidi's SC-88(+) drum key chorus level emulation I think he is right. It seems even SC-VA resets drum key settings to default after a program change message.
https://www.un4seen.com/forum/?topic=20880.ms … 46255#msg146255
Website, Youtube
Reply 2465 of 2569, by Spesek
Falcosoft wrote on 2026-02-16, 16:36:
Hi, Ian has responded to my report and regarding Bassmidi's SC-88(+) drum key chorus level emulation I think he is right. It see […]
Hi,
Hi,
ndeed it looks like I overlooked that, sorry! GSAE and SC-VA's drum editor both show 64 there, but after listening indeed there's no snare there.
But the chorus issue from the th19 MIDI still applies. I just checked again with SC-VA and the chorus is noticeably applied to the snare 1 drum (and a pitch change). Neither are present in BASSMIDI's rendering.
Reply 2466 of 2569, by ColomboGMGS2
Falcosoft wrote on 2026-02-15, 12:22:
Hi, Unfortunately I cannot help with such issues. You should tell such problems to Ian at https://www.un4seen.com/ (forum sectio […]
ColomboGMGS2 wrote on 2026-02-15, 10:56:
Update: Something fishy is going on with my new "Sub Aqua" preset I designed keeping step with the same named preset found in so […]
Falcosoft wrote on 2026-02-10, 10:00:
Hi, The term 'Midi Panic' was not too helpful since it was so radical that it suggested for me that you noticed something that w […]
Hi,
The term 'Midi Panic' was not too helpful since it was so radical that it suggested for me that you noticed something that was fundamentally broken.
Watching your video made it clear what your problem was. I introduced All Sounds Off instead of All Notes Off in case of Mute/Solo since All Notes Off messages simply cannot mute looped sustained notes.
But to tell you the truth this problem occurs rather rarely since most sustained notes are not looped and have a proper release phase.
I did not think that a little bit more abrupt muting of notes makes someone think of 'Midi Panic' 😀.
So OK, I reverted the change. You can try the new test version. You should simply overwrite the files in FSMP's folder with the new ones:
https://falcosoft.hu/midiplayer_66_test.zip
Update: Something fishy is going on with my new "Sub Aqua" preset I designed keeping step with the same named preset found in some Yamaha PSR.
probably this is just a bassmidi issue...
My tone is designed to go through a delayed filter envelope that goes like this (according to how I hear or at least imagine)
in the initial envelope delay of 0.05 seconds, the tone stays bright during that small time,
Then with a snappy attack (almost sounds like a cut) of 0.001 seconds the tone dips below a low-pass filter of -3100 cents.
When the note is released, then it gradually climbs (or Wahs) back up to the brightness as it quickly fades out.
The overall pattern sounds like an "AMmmmmwuA" rather than an "AWUummmuwuh"
Somehow the snappy attack I mentioned has now become slower.
Even when I remove the attack value entirely, the new bassmidi puts some high attack time value as a placeholder.
So there is a difference between how it sounded before on FSMP 5.8's bassmidi library and the current one.
The current bassmidi version had pretty much turned my sub aqua into nothing more than a "yet another synth bass preset" 🙁
*this same problem is also present in virtualmidisynth 2.12.8 as well.
Test video: https://youtu.be/tTHG1XxfSdg
Hi,
Unfortunately I cannot help with such issues. You should tell such problems to Ian at https://www.un4seen.com/ (forum section).
He is usually very helpful, but of course his and our vision of Bassmidi regarding compatibility sometimes differ and of course usually his version wins.
@Edit:
1. Regarding your ruined tone problem:
In FSMP there is an advanced setting that can only be changed using the registry (HKEY_CURRENT_USER\Software\falcosoft\MidiPlayer) or in the MidiPlayer.ini file. It's called
BassMidiFontInitFlags
. With the help of this flags field you can try/set any present or future values defined by BassMidi. That is:
// BASS_MIDI_FontInit flags
#define BASS_MIDI_FONT_MEM 0x10000
#define BASS_MIDI_FONT_MMAP 0x20000
#define BASS_MIDI_FONT_XGDRUMS 0x40000
#define BASS_MIDI_FONT_NOFX 0x80000
#define BASS_MIDI_FONT_LINATTMOD 0x100000
#define BASS_MIDI_FONT_LINDECVOL 0x200000
#define BASS_MIDI_FONT_NORAMPIN 0x400000
#define BASS_MIDI_FONT_NOSBLIMITS 0x800000
#define BASS_MIDI_FONT_NOLIMITS BASS_MIDI_FONT_NOSBLIMITS
#define BASS_MIDI_FONT_MINFX 0x1000000
#define BASS_MIDI_FONT_SBLIMITS 0x2000000
#define BASS_MIDI_FONT_STEREO 0x4000000
BassMidiFontInitFlags is a bit field which means you can combine all of the above flag values by logical OR operators (which in this case actually equivalent to an arithmetical addition) to get an overall value that you can set.
E.g. to test the BASS_MIDI_FONT_SBLIMITS flag together with the BASS_MIDI_FONT_LINATTMOD flag you can simply add them. That is:
0x100000 + 0x2000000 = 0x2100000 (34603008 in decimal).
I recommend to test the BASS_MIDI_FONT_SBLIMITS flag first since it changed recently (the default was the opposite).
2.
And also, there is this drum-chorus-prohibition facade I read from that discussion on Un4seen. I tried my best to ignore that difference until I played some old karaoke midi files.
In those tracks, every single channel including drums was set at a high chorus level.
I have already built in a workaround to circumvent this 'chorus on drum channels is always disabled in GS mode' limitation into FSMP.
To activate the workaround you should select the 'No SysEx' reset mode option instead of GS and then press the 'Reset' button. Then even in case of GS files you can adjust the Chorus level on drum channels.
Thank you. Should i paste those values into the said .ini file in my directory?
Reply 2467 of 2569, by Falcosoft
ColomboGMGS2 wrote on 2026-02-18, 09:47:
It depends on the 'Main menu -> Storage of Settings -> Store Settings in...' option. If it's 'INI File' then yes, you can find the mentioned 'BassMidiFontInitFlags' key in MidiPlayer.ini file in FSMP's folder.
But If it's 'Store Settings in Registry' then you can find the mentioned 'BassMidiFontInitFlags' key in 'HKEY_CURRENT_USER\Software\falcosoft\MidiPlayer'.
BTW, We have got good news related to the 'disabled chorus effect on drum channels in GS mode' issue. It seems I succeeded in convincing Ian that disabling chorus effect on drum channels in simple GS mode was a bad idea:
So you can try the newest Bassmidi.dll version(s) that Ian posted at the end of the conversation. With these new versions chorus should not be disabled on drums in GS mode so you do not have to always use the 'No SysEx' reset option of FSMP to use chorus effect on drum channels in GS mode.
(Even if you do not want to test the new beta versions right now, grab that Bassmidi.dll files since in the end Ian can change his mind 😀 )
Website, Youtube
Reply 2468 of 2569, by ColomboGMGS2
Falcosoft wrote on 2026-02-18, 11:16:
It depends on the 'Main menu -> Storage of Settings -> Store Settings in...' option. If it's 'INI File' then yes, you can find t […]
Thanks for the heads-up. I downloaded the updated bassmidi test versions and had a blast!
btw, something fishy went down with a VST Effect that has an option to sync its LFO to the BPM, here I documented it in a video. more details in the description.
https://youtu.be/027AxawRXl4
(This video was uploaded before me getting to know the good news about chorus, so please disregard any chorus related rambling there.)
Reply 2469 of 2569, by Falcosoft
ColomboGMGS2 wrote on 2026-02-21, 16:45:
Thanks for the heads-up. I downloaded the updated bassmidi test versions and had a blast! […]
Hi,
I have watched the video and read the description.
But ultimately I have a feeling that you misunderstood what was happening and why with your affected effect:
If the effect has an LFO sync option, just sync it to the given fraction of BPM and not precisely the current beat marker.
The most important thing to realize is that it's not true that Midi Player itself makes the effects sync to anything.
It's entirely the effect's business to sync to anything if it wants to. The only thing that newer Midi Player does (actually it's rather the newer versions of Bass_VST ) that older versions did not is sending the correct VstTimeInfo structure, but only when it's asked by the effect!
So it should be set on the VST effect's side to ask for VstTimeInfo or not. And it also depends entirely on the effect how it reacts to the given timing info.
This decision is made on the effect side not on the host side (in this case the host is Midi Player/Bass_VST).
Older versions of Bass_VST always sent fake/invalid timing info to effect plugins for such requests. In the newer versions you can set a callback so the effect plugins can get real timing info from the host's side. But that's all, the host does not make the effect sync to anything.
https://github.com/Falcosoft/BASS_VST/commit/ … 7be34334deb19ac
Website, Youtube
Reply 2470 of 2569, by ColomboGMGS2
Falcosoft wrote on 2026-02-21, 19:23:
Hi, I have watched the video and read the description. But ultimately I have a feeling that you misunderstood what was happening […]
Hi,
So I should change the vst plugin dll. Shame on me for being not that much of a programmer.
Reply 2471 of 2569, by Falcosoft
ColomboGMGS2 wrote on 2026-02-22, 06:09:
Hi,
The only thing that can be done on the Host/Midi Player's side is a compatibility setting not to send real timing info. Actually there is already a compatibility setting for Midi devices namely 'Send Start/Stop/Clock messages'. Such messages are not relevant for effect plugins since they do not get Midi messages at all but the purpose is the same. So sending VST timing info could be linked to the same compatibility setting.
@Edit:
OK, I have modified the title of the compatibility settings to 'Send Start/Stop/Clock info' and now besides the Midi timing related messages it also influences the sending of proper VST timing info. If this option is disabled neither Midi timing nor VST timing info is sent.
Website, Youtube
Reply 2472 of 2569, by emmanu888
Is it normal that FSMP won't start once the Roland Serial MIDI Driver is installed?
It causes Windows 98 to stop responding when you try to reboot the machine, forcing a hard reset.
Reply 2473 of 2569, by Falcosoft
emmanu888 wrote on 2026-02-23, 07:00:
Hi,
All I can say is that FSMP knows nothing special about Roland Serial MIDI Driver. It handles every Midi port the same way.
So I do not think the problem is FSMP specific. It must be driver related.
One specific thing that can cause such a problem is a MIDI feedback loop error.
So make sure that Midi Out is not directly linked to Midi In.
This can happen on Win9x when Midi In is enabled before the driver installation and after the installation the driver changes the port numbers so both the actual Midi In and Midi Out become the same port. So before installing the driver try to disable Midi In in FSMP.
If you do not want to uninstall the driver you can also try to reset FSMP's setting to default since in default state Midi In is not enabled.
You can do this by deleting the following registry key
or by deleting the MidiPlayer.ini file
depending on what option has been selected in the menu to store the settings (the default is the registry).
Website, Youtube
Reply 2474 of 2569, by RetroGC
HI,
I'm going to use this again with some 24tracks mod. Do you remember, please, if the mod2midi included in the latest release available for download is the one updated?
As i can remember we did few try in the past... I've some release archived btw.
Thank you for your help.
Aldo
My Videogames Music Channel
My Videogames Music Channel Thread
Reply 2475 of 2569, by Falcosoft
RetroGC wrote on 2026-02-23, 09:11:
HI, I'm going to use this again with some 24tracks mod. Do you remember, please, if the mod2midi included in the latest release […]
HI,
Aldo
I'm not sure either what is included in the latest release but it seems the latest version of mod2midi can be found here:
Re: Falcosoft Soundfont Midi Player + Munt VSTi + BassMidi VSTi
Website, Youtube
Reply 2476 of 2569, by RetroGC
Hi, sorry for bothering again. When I load the midi I can see 32 channel, but when recording I've just 16 single channel recorded. Maybe that single channel recording is not recording until channel 32? I've tryed line command mod2midi too, both settings: 011 and 010.
Thank you.
Aldo
P.S.: Do you think it could be possible to add a balloon to have volume settings showing value in db too?
Reply 2477 of 2569, by Falcosoft
RetroGC wrote on 2026-02-25, 07:40:
Hi, sorry for bothering again. When I load the midi I can see 32 channel, but when recording I've just 16 single channel recorde […]
Thank you.
Aldo
Hi,
I'm sorry, but I could not reproduce your problem. For me the recording sounds the same as the real-time playback. I do not know how you determined that only 16 channel was recorded but I can give you a hint:
Check that around 1.16 at channel 4 (20) on the 2nd port you can hear the 4 'beating' like synth sound (tap-tap-tap-tap). These sounds are definitely come from the 2nd port (channel 20).
Here is my test video about the playback and recording. Report back if you experience something different:
https://youtu.be/p00Y-E0UIEo
BTW, make sure that 'Main menu -> Compatibility Settings -> Send Port Select Midi Events (F5 xx)' is selected!
Website, Youtube
Reply 2478 of 2569, by RetroGC
I'm talking about recording in wav with single files per track, software produce 16 track... (from ch01 to ch16 )while as you told there's sounds above as the track 20, I've checked.
Aldo
Reply 2479 of 2569, by Falcosoft
RetroGC wrote on 2026-02-25, 13:11:
Aldo
Hi,
It seems you mix up tracks with channels. As the menu option say it's 'Also make per Channel recordings'. But it does not really matter. What matters is the following:
Regardless the count of the tracks the per channel recordings always contain the sounds of the same channel from all ports. That is in case of a 32-channel file (that is really a 2-port Midi file with 2 x 16 channel domains):
on Channel 1 recording you will get Channel 1 sounds + Channel 17 sounds (that is Channel 1 on port 2).
on Channel 2 recording you will get Channel 2 sounds + Channel 18 sounds (that is Channel 2 on port 2).
on Channel 3 recording you will get Channel 3 sounds + Channel 19 sounds (that is Channel 3 on port 2).
on Channel 4 recording you will get Channel 4 sounds + Channel 20 sounds (that is Channel 4 on port 2).
on Channel 16 recording you will get Channel 16 sounds + Channel 32 sounds (that is Channel 16 on port 2).
It cannot work other way since the per channel recording option uses UI automation to switch the solo button and on the UI there are no 16+ channel selection controls.
You should have tried to combine the 16 recordings and then you had got the full sound from all channels 😀
@Edit:
No, it's not possible since decibel precision display would require Midi Player to know how all possible synths that Midi Player can use as output (external Midi Out devices through WinMM, VSTi plugins, Bassmidi etc.) react to volume slider changes exactly.
Website, Youtube
