First post, by MrEWhite
- Oldbie
Hey, I am having an issue with this IBM PPro PC. Basically, I cannot use a hard drive bigger than around 8.4 GB as it always shows that size when I use a bigger one. Now, in an earlier BIOS update, it says that it removed a limit of 4.2 GB which I found here, http://greyghost.mooo.com/pccbbs/commercial_d … top/lujt40a.txt. It states that, "Greater than 4.2GB IDE hard disk support added". So, is there anyway to remove this 8.4GB limit? I am using the latest BIOS.
