ASUS 386/33-64K - cache upgrade?
First post, by tikoellner
I have this ASUS 386/33-64K motherboard in pristine condition. The battery was never there, so generally no signs of use whatsoever.
It seems like a decent motherboard with lots of upgrade options.
I am somehow attached to 386 build, even though I am aware of its limitations.
I was wondering if I could upgrade cache from 64k to 128k or even 256k? Cache is not soldered, but socketed. But do you think this this motherboard will handle any such upgrade? And would that make a substantial difference?
The mobo:
Reply 1 of 28, by vetz
I have the same board in my 386 (just called ISA-386). It's a great board!
AFAIK there is no way of upgrading the cache on this board. On a 386 it wouldn't matter much anyway in terms of performance boost. Even on a fast 486 going from 256k to 1024k only gives 1-2% performance increase.
Reply 2 of 28, by tikoellner
Thank you!
I am courious why do you think this board is so good? I find it really neat and good quality overall, but is it about exceptional chipset, performance, reliability, upgrade options, layout, etc?
I surely like the CPU that is not soldered but socketed.
Reply 3 of 28, by vetz
It doesn't have a built-in battery, they came with external ones from the factory, meaning NO battery corrosion! Another thing is stability and build quality. Its performance is quite good and I've had no reliability issues. Upgrade options are a bit limited compared to later boards (for instance you must switch out the clock crystal if you want to upgrade the CPU to 40mhz) and cache is max 64kb on the board itself which is enough for a 386. A neat feature (which you will probably never use) is the RAM expansion card that allows you to install up to 64MB of RAM:
Picture shows the ISA-486C memory card, but it is very similar.
Here is my build with the board: Time for a new 386 build with some nice components
Reply 4 of 28, by tikoellner
Indeed, memory upgrade card seems to be an overkill in this kind of machine, I guess I'll even limit myself to 4mb.
Very cool setup you got there.
I will use my CT1600 as well, accompanied by Music Quest PC MIDI interface.
For graphics - Western Digital WD90C00-JK which I got fully expanded to 1mb RAM. I guess it will do just as good as any other card on a 386. Maybe later I will upgrade to some tseng ET3000AX or similar.
Reply 5 of 28, by Anonymous Coward
How do we know for certain the board can't be upgraded to 256kb cache? It looks very similar to the ISA-386C (which supports 256). Are the jumpers to set the cache size from that board present on the 33-64K?
Reply 6 of 28, by vetz
There are no options for that amount of cache on my ISA-386C. TH99 also states 64kb cache as max. You arent confusing it with the ISA-486C? That board can do 256kb
Reply 7 of 28, by Anonymous Coward
I was pretty sure that there was a member on vogons that upgraded their 386C to 256kb. I want to say that it was Amigaz. The SiS Rabbit chipset does support 256kb.
Reply 8 of 28, by tikoellner
I reviewed the board and I'm almost sure there is np jumper related to cache amount. Do mi guesses would be either:
1. The change is detected automatically by the chipset - possible sis 85c310 controller feature?
2. Cache amount is limited board design, irrespective of chipset potential features.
Reply 10 of 28, by tikoellner
Yep, on the other hand what would be the reason to limit cache size in a high-end motherboard if its chipset fully supports 256K? Also, why would they put cache in sockets and not just solder them? Usually this happens when there are some upgrade options. Just my assumptions.
Reply 11 of 28, by feipoa
I have 256K/32MB working on my SiS Rabbit-based 386 board. Is this an older Rabbit revision?
Reply 12 of 28, by tikoellner
I will check the exact designations when back at home.
BTW - do you think I only need to exchange those 10 dip pieces, ot there are some other parts requiring replacement (like those 64k-p23-3 and 64k-p23-4 dips - I don't know their purpose).
Reply 13 of 28, by Anonymous Coward
SRAM is highly sensitive to electrostatic discharge (easy to fry). They're in sockets so they can be easily replaced.
I'm skeptical of this, since I have the chipset data sheets. Pretty sure a jumper would need to be set, or a bridge soldered.
Reply 14 of 28, by mrau
and whats the speedup from that? i guess it would only help running something big like windows 95 :>
Reply 15 of 28, by tikoellner
I hope with this upgrade I can get 120 FPS playing Alley Cat or Boulder Dash as for now these games seem to skip frames - but this may also be caused by the fact my 386 system lacks numeric co-processor. It's the next thing I BADLY need to get 😉
Reply 16 of 28, by Anonymous Coward
TH99 lists the max RAM on the 386/33-64K as 8MB without the memory expansion board. Can you confirm whether or not it works with 4MB SIMMs? If it only accepts 8MB, then a cache upgrade would be pointless anyway.
Reply 17 of 28, by feipoa
Doesn't matter that much to me. The excitement for me comes from taking the board to the limit.
Reply 19 of 28, by Anonymous Coward
You can swap BIOSes on older boards, but at the very least they will need to be chipset specific. MR-BIOS makes a great replacement, but it's pretty difficult to track them down these days.
