First post, by DailyFrankPeter
It is sold as Windows only, but seeing that it is DOSBox-based, has anyone managed to get it working on Linux/Ubuntu? I'm having a problem here. The main way it differs from X-Com Apocalypse covered here:
Tips for getting X-Com: Apocalypse working
...is in the lack of the install program on the CD, nor the CD itself. GOG distribution of the game seems to come already 'pre-installed'. I have managed to get the setup.exe running (but this is a sound setup utility only). By using:
> mount d /<GOGgamefolder> -t cdrom
> d:
> setup
Which only seems to prove that CD emulation is important, as it does not run when mounted to C, or when not using the '-t cdrom' argument. Now, running:
> d:
> install
Will not work (obviously) since this executable isn't supplied by GOG. On the other hand going straight to this:
> d:
> xcomapoc
Will throw an error about not being able to create swap file and 'initialize VMM' (but I imagine '-t cdrom' makes it read-only so not surprised here). Also, doing simply this:
> mount c /<GOGgamefolder>
> c:
> xcomapoc
Will make the program run for a second or two, with no video at all showing, then return to DOXBox prompt. I'd appreciate any help!
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Using the same commands as the gog dosbox should be fine making it work on linux (of course paths need to be adjusted).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by DailyFrankPeter
Solved.
I wasn't looking carefully enough! There was a CD image included with the GOG files. The GOG distribution does come preinstalled, but one needs to mount the CD image as well (presumably with every launch):
> mount c /GOGfolder
> mount d /GOGfolder/CD/xcom.cue -t iso
> c:
> xcomapoc
(this is the miminum that works I think, if not, everything can be reinstalled from the CD image which is what I have done)
