First post, by pelonariz
Hi!!!
I'm having problems with a game: "Simulador Profesional de Fútbol". It runs fine but the issue that is annoying me is that the colors are not showing correctly. I think it's something related to the dosbox's VGA emulation because if I run the game with JPC (another emulator), the game shows fine. I attach some screencaps...
I'm using Dosbox Daun SVN. But I think it's not important 'cause I remember to have the same problems with previous versions. I've tried the VGA and SVGA modes and nothing changed.
Is it possible to run this game well on dosbox?? maybe using a SVN build or installing a VGA driver??
Thank you in advance. Regards!!
