First post, by Brickpad
- Member
Pulled out my Chicony CH-486 33/50 L board today to give it a test run. Unfortunately it no longer POSTs. I've tried pulling, reseating, and rearranging the RAM (4MB; Micron 1Mx9 Fast Page). I've swapped out three CPUs (Intel i486SX 25MHz, 33MHz, and DX 50MHz). Nothing. I've added and removed the cache memory, checked the jumper settings, pulled and reseated the video card (Trident TVGA9000B) and moved it to different slots. Still nothing. There's not a single chirp from the PC speaker, except a random single beep immediately after powering on, which only happened twice. I've pulled everything out - RAM, CPU, and video card and still not a sound from the PC speaker. I swapped those out as well just in case. I've also added and removed and external battery. Still no luck
At this point I don't know what else to do. It was working just fine when I stored it away in an anti-static bag in a box just a month ago, so I don't know what could have possibly happened in-between then? I'd hate to scrap this as these 50MHz FSB boards are hard to find. Any other possible ideas?
This is the board here:
