First post, by vladr
Sauro Puccini released a beta version of the MSCDEX replacement for Windows NT, 2k and XP.
To use simply extract the two files in the archive in C:\WINNT\SYSTEM32, in the VDMSound installation directory or in your game's directory and, instead of running MSCDEXNT.EXE, from now on run SAPUCDEX.EXE.
If running in VDMSound using LaunchPad, disable "Low-level CD-ROM support" (which uses the Windows emulation for now, so it's no good) and go to Advanced, DOS Environment, AUTOEXEC, and add the line:
SAPUCDEX
If using plain VDMSound, edit AUTOEXEC.VDMS in the VDMSound directory and replace MSCDEXNT with SAPUCDEX.
If not using VDMSound, edit AUTOEXEC.NT in the Windows directory and replace MSCDEXNT with SAPUCDEX.
SAPUCDEX should generate a log file in C:\VCDEX.LOG, so if you have problems with SAPUCDEX then zip and send the file to me at ntvdm@hotmail.com and I'll gladly forward it to Sauro.
You can also discuss SAPUCDEX online in the VDMSound development forum !
Cheers,
V.
Reply 1 of 3, by vladr
A newer version (1.0.0.2) was released (attached).
It has better logging (no more 0x1234), and also accomodates the author's preference regarding the verbosity of the credits. 😉
V.
    sapucdex.v1.0.0.2.zip
    5.24 KiB
    854 downloads
Reply 3 of 3, by Stiletto
To quote Vlad on October 28th:
Originally posted by vladr SaPu released a new version: >Hi, >I just finished the new version, and it's now FULLY compatible […]
>Hi,
>with the DOS mscdex.exe.
>p.s.: I hope this time to receive some better feedbacks than the
>last ones from the vogons thread...
Please give this one a try. For feedback, post here:
showthread.php?s=&threadid=503
    sapucdex.v1.0.0.3.zip
    7.73 KiB
    762 downloads
do the Fandango!" - Queen
Stiletto
