First post, by heretic
heretic
Offline
I noticed that dxdiag shows empty lines for chip type and dac type on my retro pc with voodoo 5 5500 . As i recall it should say something like chip type: vsa 100 and dac: internal. Can anyone confirm if this is correct or wrong? My system specs are: windows 98se, latest 3dfx official driver and directx 8.1.
Here is dxdiag log:
---------------Display Devices---------------Card name: Voodoo5 5500 AGPManufacturer: 3dfx Interactive, Inc.Chip type:DAC type:Device ID: Enum\PCI\VEN_121A&DEV_0009&SUBSYS_0002121A&REV_01\000800Display Memory: 30.5 MBCurrent Mode: 1024 x 768 (32 bit)(optimal refresh rate)Monitor: W2286Monitor Max Res: 1600,1200Driver Name: 3dfx16vs.drvDriver Version: 4.12.01.0666 (English)DDI Version: 7Driver Attributes: Final RetailDriver Date/Size: 11/2/2000 13:16:08, 442728 bytesDriver Signed: NoWHQL Date Stamp: NoneVDD: *vddMini VDD: 3dfxvs.vxdMini VDD Date: , 0 bytesDevice Identifier: {D7B71CFA-4349-11CF-3073-0320A2C2C935}Vendor ID: 0x121ADevice ID: 0x0009SubSys ID: 0x0002121ARevision ID: 0x0001Registry: OKDDraw Status: EnabledD3D Status: EnabledAGP Status: Not AvailableDDraw Test Result:D3D7 Test Result:D3D8 Test Result:
