Reply 100 of 733, by James-F
Ant_222 wrote:
Uploading a little modification that implementents, independently of the hard-coded normal scalers, the lossy interpolative scal […]
Uploading a little modification that implementents, independently of the hard-coded normal scalers, the lossy interpolative scaling technique that is in favour with many gamers (see here, here, and here):
  1. upscale the image in a pixel-perfect manner so that its dimensions exceed those of the display,
  2. let the built-in bilinear interpolation downscale it back to the target dimensions and aspect ratio.
To activate it, simply use the overlay output in fullscreen and with scaler=none (see readme.txt).
The source needs some clean-up so I will attach it to the title post later. I still need advice on the preferred interface to these new scaling modes from the config file.
First, thank you for you efforts to improve this aspect of dosbox, one day I will throw my CRT....maybe.
Am I doing something wrong? It looks like billinear interpolation is completely off.
Look at 60/60 and the "Fog of War", they are uneven with this alpha3 built with the "overlay" setting.
640x480 on a 1900x1200 monitor.
Using "output=opengl" with "scaler=normal3x forced" is ever so slightly blurred but it looks even.
*no picture because printscreen doesn't work with opengl.
359.76 KiB
280.99 KiB
Reply 101 of 733, by Ant_222
The first screenshot shows nearest-neighbor interpolation and the second pixel-perfect upscaling by a factor of two.
Looks like you are experienceing the same bevavior as VileRancour does: SDL applies nearest-neighbor interpolation instead of bilinear, while on my and KainXVIII's machines it is bilinear as intended. I will look into problem and solve it even if I must implement quick bilinear interpolation by hand.
Using "output=opengl" with "scaler=normal3x forced" is ever so slightly blurred but it looks even.*no picture because printscreen doesn't work with opengl.
My algorithm, when it finally works, should give the same result. I will show you a screenshot from my home PC when I return home.
Reply 102 of 733, by James-F
BTW, I had to edit the diff files and change the path to "--- src/gui/render.cpp" else it would not patch.
The diff files are already in DOSBOX-SVN directory.
EDIT:
it won't compile at all.
Nuked-OPL patches and compiles flawlessly.
make[3]: Entering directory `/home/TESTER/dosbox/src/gui' g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I/mingw/include/SDL […]
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I/mingw/include/SDL -D_GNU_SOU
RCE=1 -Dmain=SDL_main -g -O2 -mno-ms-bitfields -MT sdlmain.o -MD -MP -MF .deps
/sdlmain.Tpo -c -o sdlmain.o sdlmain.cpp
sdlmain.cpp: In function 'char ssdSetSize(Bitu, Bitu, Bitu, double, double, Bitu
sdlmain.cpp:1025:14: error: 'struct SDL_Block::<anonymous>' has no member named
'type'
sdl.desktop.type=SCREEN_SURFACE_DDRAW;
sdlmain.cpp: At global scope:
sdlmain.cpp:1030:2: error: expected initializer before 'if'
if (SDL_LockSurface(sdl.blit.surface)) {
sdlmain.cpp:1034:9: error: expected constructor, destructor, or type conversion
before '=' token
*pixels=(Bit8u *)sdl.blit.surface->pixels;
sdlmain.cpp:1035:8: error: expected constructor, destructor, or type conversion
before '=' token
*pitch=sdl.blit.surface->pitch;
sdlmain.cpp:1036:2: error: expected unqualified-id before 'return'
return 1;
sdlmain.cpp:1037:1: error: expected declaration before '}' token
make[3]: *** [sdlmain.o] Error 1
make[3]: Leaving directory `/home/TESTER/dosbox/src/gui'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/TESTER/dosbox/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/TESTER/dosbox'
Reply 103 of 733, by Ant_222
I created them from the local directory instead from the project root. I will take it into account when making the next patch.
Glad to know that. Please, let me know if you are going to modify the patch because we must coordinate our efforts.
Reply 104 of 733, by Ant_222
James-F wrote:
EDIT:
That's too bad. Maybe a merge conflict or an end-of-line problem? I will post the whole source files (of alpha 3 at least) a bit later (edit: today).
What does that mean?
Reply 105 of 733, by James-F
All patches on Vogons are made to be patched from within the dosbox directory.
AUDIO - Nuked OPL3 Patch for DOSBox(+Windows build) (SDL1)
It means I patch with the following command: "patch -p0 < patchname.diff" and compile dosbox as usual, and everything compiles without errors.
Note: I am absolutely clueless about programming and code, I just follow this guide:
https://www.dosbox.com/wiki/Building_DOSBox_with_MinGW
Reply 107 of 733, by Ant_222
OK, I will test my own patch on the unmodified SVN revision 3989. I used the same guide.
Reply 108 of 733, by James-F
Note the patching command I mentioned is not in the guide (although it should be).
Just download anything from the "DOSBox Patches" sub-forum and have a look.
Reply 110 of 733, by James-F
Hi,
Replacing the given files within a fresh SVN will not compile (make) either.
But the SVN without the replacement files compiles successfully.
sdlmain.cpp:1073:14: error: 'struct SDL_Block::<anonymous>' has no member named 'type' sdl.desktop.type=SCREEN_SURFACE_DDRAW; […]
'type'
sdlmain.cpp:1078:2: error: expected initializer before 'if'
sdlmain.cpp:1082:9: error: expected constructor, destructor, or type conversion
before '=' token
sdlmain.cpp:1083:8: error: expected constructor, destructor, or type conversion
before '=' token
sdlmain.cpp:1084:2: error: expected unqualified-id before 'return'
return 1;
sdlmain.cpp:1085:1: error: expected declaration before '}' token
make: *** [all] Error 2
But the good news I have found a way to create a working diff file from the files you posted.
diff -u -r dosbos(original directory) dosbox(altered directory) > pixelperfect.diff
Might as well include -N to treat missing files as empty (not relevant to your patch), and -b to ignore white space changes which I find "-" the entire file for some reason.
Combine all four: -Nurb.
It will include all the code changes in all files, within one diff.
But I have to manually change the path in the resulting diff file after "---" to "--- src/etc..", no big deal.
Reply 111 of 733, by Ant_222
Thank you, James-F. I too found out how to make proper consolidated patches yesterday evening, but while making one based on the alpha 2 generated from my the separate diff files I was surprised that MinGW's patch creates files with unix EOL format regardless of the format of the source and that MingGW's diff cannot handle files with different EOL formats.
I will sort it out and post a working patch this evening. Sorry for the inconvenience.
Reply 112 of 733, by Ant_222
I have just uploaded a fixed alpha 2 patch. Please, test. Apply it thus:
patch -p0 < pixelprefect-alpha2.patch
from the root project directory, i.e. that contains the AUTHORS file.
Reply 113 of 733, by James-F
It will not compile, same problem as my previous post.
Making all in gui make[3]: Entering directory `/home/TESTER/dosbox/src/gui' g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I/ […]
Making all in gui
'type'
before '=' token
before '=' token
return 1;
Reply 114 of 733, by Ant_222
This is strange, for I have tested it with a freshly downloaded revision 3989. Would you please send me the file
src/gui/sdlmain.cpp
after patching? Which revision did you patch? Did you apply the patch from the MSYS console?
Reply 115 of 733, by James-F
SVN 3993 after patching with pixel-perfect alpha2.
Yes MSYS, from Windows 7.
Everything working correctly when applying other patches like Nuked-OPL.
    sdlmain.cpp
    74.06 KiB
    48 downloads
    SVN 3993 patched with pixel-perfect
Reply 116 of 733, by Ant_222
The error was in Direct-Draw-related code, and I building DOSBox without Direct-Draw suppport, this broken code was ignored due to conditional compilation. I have fixed it now but shall test it only some ten hours later. Meanwhile, you can disable Direct-Draw support or try the fixed patch at your own risk. Sorry for the many errors—this is all very new to me.
Reply 117 of 733, by James-F
This time it got much further into compilation but also had an error:
C:\MinGW\msys\1.0\home\TESTER\dosbox\src\gui/render.cpp:427: undefined reference to `GFX_SetSize(unsigned int, unsigned int, un […]
to `GFX_SetSize(unsigned int, unsigned int, unsigned int, double, double, void
(*)(GFX_CallBackFunctions_t), float)'
collect2.exe: error: ld returned 1 exit status
make[3]: *** [dosbox.exe] Error 1
make[3]: Leaving directory `/home/TESTER/dosbox/src'
Reply 118 of 733, by Ant_222
If patch did not return any errors, then it looks like make failed to recompile some files from updated sources. Please, try deleting the binary files by calling
find . -type f -name \*.a -delete -o -name \*.o -delete
from the project directory and making again. If it doesn't work, I shall need the following files:
include/video.h
src/gui/render.cpp
src/gui/sdlmain.cpp
as they appear on your machine after patching.
Reply 119 of 733, by James-F
The compiler shows error in render.cpp.
    video.h
    2.29 KiB
    45 downloads
    sdlmain.cpp
    64.83 KiB
    48 downloads
    render.cpp
    19.72 KiB
    47 downloads
