Reply 280 of 733, by Ant_222
KainXVIII wrote:
And here is with windowresolution=desktop (maybe it helps)
Thank you. I have narrowed-down the location of the bug to two places. The attached .exe with further logging will show where it is exactly. Please, test again.
    dosbox.exe
    3.52 MiB
    89 downloads
Reply 281 of 733, by KainXVIII
This new version hangs when entered windowed mode in KoX, so results maybe not very accurate, but here is what i managed to capture
    202.22 KiB
Reply 282 of 733, by Ant_222
Should work now. Does it? Please, post the log either way.
    dosbox.exe
    3.52 MiB
    79 downloads
Reply 283 of 733, by KainXVIII
Yep, it works now, thanks! 😀 So, what was wrong?
    85.76 KiB
Reply 284 of 733, by Ant_222
KainXVIII wrote:
Yep, it works now, thanks! :happy: So, what was wrong?
I will soon upload a fixed patch. What I don't understand is why at your side the aspect ratio of the source image is sometimes reported as 1.17 instead of the correct 1.20, whereas at my side it is always 1.20. Can you please upload your full config file so that I may reproduce this latter behaviour?
Reply 285 of 733, by KainXVIII
Here you go
http://rgho.st/8xTNkyR9q
Reply 286 of 733, by Ant_222
KainXVIII wrote:
Here you go
Thank you. I do not observe this with Knights of Xentar. 1.17 may be 7/6, but why... I take this from DOXBox without any calculations.
Reply 287 of 733, by KainXVIII
Ant_222 wrote:
KainXVIII wrote:
Here you go
As i remember you don't have 1080p monitor?
Reply 289 of 733, by KainXVIII
Ant_222 wrote:
No. Mine is a 1050p one.
Maybe this matters if game works fine for you 😀
Reply 290 of 733, by Ant_222
KainXVIII wrote:
Maybe this matters if game works fine for you :happy:
Hardly possible. If you will help me with testing, I will find its cause via logging.
I have just uploaded the 12th alpha of the patch, which would have been impossible without your help. It fixes the crash with Knights of Xentar.
Reply 291 of 733, by Yesterplay80
DOSBox ECE is updated with Alpha 12 of your build.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 292 of 733, by KainXVIII
We will find this bug! 😎
Here is another interesting results (just testing) of game Rusty
Intro fills nearly entire 1080p widescreen monitor with surfacepp output, because of its unusual resolution (640x291?), looks crazy and cool, i wonder what other (japanese?) games use it..
Also ingame fullscreen aspect ratio looks slightly different than in windowed mode (or is it just me?)
90.75 KiB
26.88 KiB
44.03 KiB
85.02 KiB
Reply 294 of 733, by Ant_222
KainXVIII wrote:
We will find this bug! :cool:
OK—await more builds with additional logging.
I think so.
It is different indeed. I will check why this happens.
Edit:The explanation is in the console output. The in-game PAR is 2.40, which requires at least 2x5 upscaling, whereas in windowed mode with
windowresolution=original
my patch may upscale but one dimension, so only 1x2 is possible. In fullscreen, however, the upscaling is ideal. Try setting
or any fixed dimensions that are large enough, e.g.:
windowresolution=1600x1000
Reply 296 of 733, by Ant_222
marooned_on_mars wrote:
Sorry, ATM I don't have the time or the resources (my own PC) to test the patch. Will do so in a month or so.
OK. As I remember, the only conflict was in the makefile for gui\, which I fixed.
Reply 297 of 733, by Ant_222
KainXVIII, please, test KoX with the attached .exe and show me the console output.
    dosbox.exe.zip
    1.13 MiB
    89 downloads
Reply 298 of 733, by KainXVIII
Something new?
Before KoX there were Norton Commander loaded.
    18.82 KiB
Reply 299 of 733, by Ant_222
KainXVIII wrote:
Something new?
Yes, it looks as though DOSBox's VGA emulator gives me this PAR of 1.169, and my patch has nothing to do with it. I will add the same logging to a clean SVN version and check again, ok? If my suspicions be confirmed, I shall ask the core developers.
