Reply 500 of 733, by Yesterplay80
Nah, it's just the dot, not the two new lines, forget what I said. Just remove it and it will be fine.
-	Pbool->Set_help("Do aspect correction, if your output method doesn't support scaling this can slow things down!.");
+ Pbool->Set_help("Do aspect correction, if your output method doesn't support scaling this can slow things down!");
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 502 of 733, by Yesterplay80
r4147 (and possibly the following revisions) once again breaks compatibility with your patch because of the changes it introduces in sdlmain.cpp.
Reply 504 of 733, by Yesterplay80
Ant_222 wrote:
I will try to merge the changes at this weekend.
Thanks! I tried to mege the changes into my modified patch, too, but I always got a malformed patch in a line I didn't even touch.
Reply 505 of 733, by Ant_222
Does svn merge work for you? I was going to try it.
Reply 506 of 733, by Ant_222
Please, test the attached patch with the latest SVN revision of DOSBox.
    pp14-4157.patch
    80.83 KiB
    93 downloads
Reply 507 of 733, by Yesterplay80
It applied and compiled without errors, looking good here! 😀
Reply 509 of 733, by aaronp
On Linux, if I try this myself either by applying it manually or compiling ECE, dosbox crashes when I use the new outputs. But it seems to work fine if I just use the ECE binary. Is this a problem any of you have run into? I thought maybe it didn't like some of my CFLAGS, but no, it has the same issue with a clean ./configure && make.
Reply 510 of 733, by Ant_222
The ECE binary with the new outputs? Then maybe we should ask YP which version of my patch ECE currently contains...
Not I, but I do not have *nix and am using MinGW-32 with GCC 4.9.3.
Could you perhaps re-try with my version of GCC, or simply with some other version? Also please post a config file with which you have the crashes. EDIT: Try enabling fullscreen mode in the config file.
Reply 511 of 733, by aaronp
I say it "crashes", but if I run it through GDB it is actually closing normally, so there is no stack trace. I'll step through it and see if I can find anything.
[sdl]
fullscreen=true
fulldouble=false
fullresolution=desktop
windowresolution=original
output=surfacepp
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-SVN.map
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=/data/Pictures
memsize=16
[render]
frameskip=0
aspect=true
scaler=none
[cpu]
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
Reply 512 of 733, by Ant_222
I have failed to reproduce the problem with your config and plain SVN DOSBox with my patch alone.
Thank you very much for your help.
Reply 513 of 733, by Yesterplay80
And I failed to reproduce it under my Linux VM and the current ECE binary as well. DOSBox starts just fine, I can enter commands (as you can see), can start a game, close a game and exit DOSBox without errors.
1.1 MiB
I'm using the latest patch, pixel-perfect-alpha14-4157, btw.
Reply 514 of 733, by pantercat
I also have problems with surfacepp. The last version that has worked well for me is ece r4132. I'm running debian testing and these are the versions that I have tested.
output=surfacepp -> dosbox ece r4132 -> ok
-> dosbox ece r4133 to r4140 -> not tested
-> dosbox ece r4141, r4157, r4160, r4162 -> dosbox just closes
output=opengl -> always ok
Reply 516 of 733, by aaronp
There's nothing in the logs. It's weird, and I suspect it may be compiler-specific. With the latest GCC, at some point the application just returns zero, and I haven't been able to figure out where or how (might be my lack of familiarity with c++)
However, compiled with clang, I do get a segfault with the following stacktrace:
#0  0x0000000000000000 in ?? ()
#1 0x00000000004feb5c in GFX_StartUpdate (pixels=@0x351b220: 0x0, pitch=<error reading variable>) at sdlmain.cpp:1437
#2 0x000000000050ad3d in RENDER_StartUpdate () at render.cpp:171
#3 0x00000000004d375f in VGA_VerticalTimer () at vga_draw.cpp:838
#4 0x00000000004ca178 in PIC_RunQueue () at pic.cpp:486
#5 0x000000000040a041 in Normal_Loop () at dosbox.cpp:136
#6 0x000000000040a0b6 in DOSBOX_RunMachine () at dosbox.cpp:320
#7 0x000000000040fe88 in CALLBACK_RunRealInt (intnum=<optimized out>) at callback.cpp:105
#8 0x0000000000492d12 in device_CON::Read (this=0x3574680, data=0x7fffffffc5c7 " ", size=0x7fffffffc596) at ./dev_con.h:64
#9 0x00000000004961f5 in DOS_ReadFile (entry=<optimized out>, data=0x7fffffffc5c7 " ", amount=0x7fffffffc64e, fcb=<optimized out>) at dos_files.cpp:385
#10 0x00000000005f0452 in DOS_Shell::InputCommand (this=0x35185b0, line=0x7fffffffc7e0 "") at shell_misc.cpp:55
#11 0x00000000005e82cc in DOS_Shell::Run (this=0x35185b0) at shell.cpp:343
#12 0x00000000005e8c80 in SHELL_Init () at shell.cpp:750
#13 0x0000000000501d34 in main (argc=<optimized out>, argv=<optimized out>) at sdlmain.cpp:2585
If I step through it with gdb using the clang build, it appears to segfault immediately upon returning from ssImageToScreen.
Hold on! I'm typing this as a go. I did find something that works with GCC 8! There is a missing return statement in ssStartUpdate in sdlmain.cpp. Adding the return there fixes the crash with gcc, but it still crashes with the segfault with clang. Here is an updated patch with the gcc fix.
    pp14-4157.patch
    78.34 KiB
    66 downloads
Reply 517 of 733, by Ant_222
Could that be due to the old K&R style declaration with empty parenthesis instead of (void)?
Thanks! Updated patch uploaded.
Reply 519 of 733, by Ant_222
aaronp wrote:
On second look, the fix seems to be working for clang as well. Sorry, I've got dosbox sources in a couple different places. Must have gotten confused about which one I was looking at.
No problem, and many thanks for debugging. Will you please test the latest patch for r4163 from the title post of the thread?
