VIDEO Patch for pixel-perfect scaling (SDL1)
Reply 700 of 733, by krcroft
Ant_222,
I was thinking about your pixel-perfect strategy applied to an SDL2 implementation where SDL2 can perform non-uniform, hardware-accelerated scaling.
So instead of DOSBox internally scale=normal3x'ing and aspect=true'ing, we can pass the emulated video driver's raw 320x200 frame as-is to SDL2 and tell it to scale it to 1280x1000 (pixel perfect 4 x 5 scaling, texture or opengl nearest-neighbour), rendered unstretched to the screen's native or current desktop resolution (either fullscreen or a window sized to match).
Given this change in workflow, some of DOSBox's config elements could be simplified too.
This was just a thought exercise for me but am curious what your approach would be in an SDL2 scenario.
Reply 701 of 733, by Ant_222
krcroft wrote on 2020-01-07, 22:38:
What do you mean by non-uniform? In SDL2 you can pass integer scaling factors to SDL_RenderSetScale() and have hardware-accelerated pixel perfect scaling.
Yes—and openglpp does exactly that in the current version of the patch, as does bladesk.
Yes, but we shall have to drop the near-perfect scaling and software surfaces.
For now we have four options:
  1. Hardware-accelerated OpenGL's nearest-neighbor scaling with an output area precisely calculated to pixel-perfect scaling—available in my patch as openglpp.
  2. Software-based scaling for systems without a GPU—available in my patch as surfacepp.
  3. Scaling with SDL2's native SDL_RenderSetScale() function, with integer scaling factors.
  4. Pixel-perfect with a pixel shader.—should be possible in SDL2.
Reply 702 of 733, by krcroft
Thanks ant_222,
Yes, by non-uniform I mean allowing non 1-to-1 scaling of the x and y axis; so SDL2 itself can perform aspect correction instead of DOSBox's software technique of line-doubling.
In your list, could 1 and 2 be collapsed into number 3 in the SDL2-scenario? ie: your pp logic is used to configure SDL2, which then takes care of either hardware or software scaling.
Reply 703 of 733, by Ant_222
krcroft wrote on 2020-01-08, 15:50:
Yes, and my patch already does that.
Certainly!
Reply 704 of 733, by krcroft
Thanks ant_222; sounds like a plan to get pixel-perfect into DOSBox when it moves to the maintained instance of SDL.
I am seeing three upsides and no downsides:
- pixel-perfect scaling
- zero-distortion aspect-correction, and now hardware-accelerated
- fewer lines of code in DOSBox itself (elimination of all software-side code to perform aspect-correction and normal#x scaling by DOSBox)
Edit Another (big) one: hardware-acceleration of pixel-perfect for HW backends other than OpenGL such as Wayland, Vulkan, and OpenGLES 1 and 2 (on the Raspberry Pi series and other ARM SOCs).
Reply 705 of 733, by Delfino Furioso
Ant_222 wrote on 2020-01-08, 14:33:
it has been a while since I've toyed with the pp scaling - long enough for me to forget how it works
so I wanted to test the described behaviour with ECE r4301, using these 3 scenarios:
#1 : dos prompt @640x400
#2 : doom demo @320x200
#3 : quake demo @640x480
this is the relevant content of my config file:
machine=svga_s3
output=openglpp
fullscreen=false
fullborderless=false
fullresolution=desktop
windowresolution=desktop
aspect=true
scaler=none
these are the results when using a display set to a HD (720p) resolution:
640x400 (16:10) => upscaled (1x1) to 640x400 (16:10) => presented as 640x400 (16:10)
320x200 (16:10) => upscaled (3x3) to 960x600 (16:10) => presented as 960x600 (16:10)
640x480 (4:3) => upscaled (1x1) to 640x480 (4:3) => presented as 1280x960 (4:3)
these are the results when using a display set to a FHD (1080p) resolution:
640x400 (16:10) => upscaled (2x2) to 1280x800 (16:10) => presented as 1280x800 (16:10)
320x200 (16:10) => upscaled (4x5) to 1280x1000 (32:25) => presented as 1280x1000 (32:25)
640x480 (4:3) => upscaled (2x2) to 1280x960 (4:3) => presented as 1280x960 (4:3)
these would be the results (I'm unable to test in 4K) when using a display set to a UHD (2160p) resolution:
640x400 => upscaled (5x5) to 3200x2000 (16:10) => presented as 3200x2000 (16:10)
320x200 => upscaled (8x10) to 2560x2000 (32:25) => presented as 2560x2000 (32:25)
640x480 => upscaled (4x4) to 2560x1920 (4:3) => presented as 2560x1920 (4:3)
am I right in saying that basically openglpp:
- ignores the "aspect" setting
- performs only integer scaling
- avoid using scaling multipliers that would lead to an upscaled resolution bigger than the current display resolution
I also wonder if it would be possible to make it behave like this:
1) get the raw frame from the video driver
2) choose scaling multipliers that would: A) perform integer scaling, B) enable aspect ratio correction, C) upscale to a resolution bigger than the display
3) upscale the frame to a offscreen render target, using the chosen scaling multipliers
4) downscale the resulting frame to the size defined in fullresolution/windowresolution
the new behaviour would be, for both HD and FHD displays :
640x400 (16:10) => upscaled (5x6) to 3200x2400 (4:3) => presented as pillarboxed at desktop resolution (16:9)
320x200 (16:10) => upscaled (5x6) to 1600x1200 (4:3) => presented as pillarboxed at desktop resolution (16:9)
640x480 (4:3) => upscaled (5x5) to 3200x2400 (4:3) => presented as pillarboxed at desktop resolution (16:9)
the new behaviour would be, when using UHD displays :
320x200 (16:10) => upscaled (10x12) to 3200x2400 (4:3) => presented as pillarboxed at desktop resolution (16:9)
Reply 707 of 733, by Ant_222
Delfino Furioso wrote on 2020-01-09, 14:53:
this is the relevant content of my config file: machine=svga_s3 output=openglpp fullscreen=false fullborderless=false fullresolu […]
machine=svga_s3
output=openglpp
fullscreen=false
aspect=true
scaler=none
OK.
No. Which test case made you think so?
That is true, but the apsect-ratio approximation algorithm is a bit more complicated.
I also wonder if it would be possible to make it behave like this: 1) get the raw frame from the video driver 2) choose scaling […]
Yes, but that would not be pixel-perfect. The current patch has a slow implementation of this method via surfacenp and surfacenp-sharpness, but a faster implementation is possible if one lets the hardware perform the final step.
It is easier in your algorithm to set the target aspect ratio at the final step only—no need to fine-tune the integer multipliers.
Reply 708 of 733, by Soothe
Hey folks, I'm running the latest DOSBox ECE and testing DOOM II.
I have a few questions, so there is this "source port" called Crispy Doom that is a fork of the accurate port called Chocolate Doom.
So acording to the https://doomwiki.org/wiki/Aspect_ratio"This meant that the 320x200 display, with a 16:10 logical ratio, was stretched vertically - each pixel was 20% taller than it was wide". Crispy Doom seems to do this type of correction.
But this patch renders it a little different, like a little bit more stretched.
Now I'm curious, which one the "right one"? Or is there no difference?
    74.78 KiB
    Crispy Doom
    322.97 KiB
    DOSBox ECE
Reply 709 of 733, by Ant_222
Soothe wrote on 2020-01-09, 19:05:
So acording to the wiki "This meant that the 320x200 display, with a 16:10 logical ratio, was stretched vertically - each pixel was 20% taller than it was wide". Crispy Doom seems to do this type of correction.
Cryspy Doom is playing a trick on you by forcing the aspect ratio to the required 4:3 by means of nearest-neighbor interpolation. It is not pixel-perfect. My patch, on the other hand, enlarges all pixels in the same scale of 4:5, so it is pixel-perfect but slightly off the right aspect ratio—because the correct pixel proportion is 5:6. With your resolution it is a matter of compromise: either you get pixel-perfect magnification or the exact aspect ratio. If you had a monitor of at least 1600x1200, my patch would give you both pixel-perfect magnification and the exact aspect ratio.
Reply 710 of 733, by Delfino Furioso
jmarsh wrote on 2020-01-09, 14:56:
Then it wouldn't be pixel-perfect...
oops that's right
it would become a combo of "pixel perfect upscaling" and "<insert your algorithm here> downscaling"
I guess it should be called openglnp then..
I still see its usefulness, though: performing "pp upscaling + linear downscaling" should in theory give better results than the "linear upscaling" that the standard opengl output implements
Ant_222 wrote on 2020-01-09, 15:07:
using output=opengl & aspect=true, a 16:10 frame would be scaled to a 4:3 frame by stretching the image
using output=openglpp & aspect=true, a 16:10 frame would not result in a 4:3 frame
I guess I'm spoiled by how aspect ratio correction is dealt with in other software such as scummvm (which correct to a 4:3 ratio)
(the same goes for @Soothe with Crispy Doom, it seems)
Reply 711 of 733, by jmarsh
Delfino Furioso wrote on 2020-01-09, 22:33:
Regular DOSBox can already do the same thing using "scaler=normal?x forced" to upscale beyond the output resolution and "output=opengl" for linear downscaling.
Reply 712 of 733, by krcroft
jmarsh wrote on 2020-01-09, 23:24:
The most I can do is normal3x, so with a 320x200 game it becomes 960x600 non-aspect or 960x720 w/ aspect (and that's scaling done in software by DOSBox prior to handoff to SDL, correct?); both are still is smaller than an old school 1024x768 CRT.
I guess the forced means it will do this for SVGA games using modes greater than 320x2##? So a 640x480 game would be cranked up to 1920x1440 (DOSBox-side), and then scaled linearly by SDL (possibly using hardware-accel) to fit the desired output resolution.
Reply 713 of 733, by Soothe
Ant_222 wrote on 2020-01-09, 21:29:
Zoomed to check and you're correct. Thanks for creating this patch, seems like a bunch of software isn't doing aspect correction + pixel perfect correctly.
Reply 714 of 733, by Ant_222
I agree. This algorithm, similar to surfacenp, can be efficiently implemented in a pixel shader.
But you did not specify the exact test case, with the input and output resolutions.
In my opinion, ScummVM, is even worse, because it has a mode called pixel-perfect that in fact uses nearest-neighbor interpolation along the vertical axis. That is misinformation of the users.
Reply 715 of 733, by Ant_222
krcroft wrote on 2020-01-09, 23:59:
forced causes DOSBox to upscale the image even if the result will be larger than the output area. It works for 320x200, too, and may be required for small monitors.
Reply 716 of 733, by Ant_222
Soothe wrote on 2020-01-10, 03:25:
None that I know of. I even have to run ZX Spectrum and SNES emulatros from within DOSBox!
Reply 717 of 733, by Delfino Furioso
that's the way I usually setup dosbox, and I'm under the impression that it would lead to less accurate results because the aspect ratio correction is performed by adding lines instead of making the single pixel taller
this image explain my understanding of the "aspect=true & scaler=normal5x" inner workings
https://i.postimg.cc/s2nXy3ns/aspect-normal5x.png
this image tries to exemplify the new approach I am interested in
https://i.postimg.cc/HxqTsnbD/openglnp.png
am I missing something?
Reply 718 of 733, by Ant_222
Delfino Furioso wrote on 2020-01-10, 12:53:
I fear that is true. The DOSBox built-in aspect-ratio correction doubles certain rows in the original image before futher processing. But does it work that way with hardware outputs—opengl and ddraw?
No—that shows pixel-perfect scaling with aspect ratio correction. My patch already works that way if the output resolution is large enough. Why don't you run a game with surfacenp and a zero surfacenp-sharpness and post a 10x magnified fragment? It would show what you need.
Reply 719 of 733, by Soothe
Ant_222 wrote on 2020-01-10, 12:30:
Wait SNES emulators?
Even stuff like bsnes / higan isn't doing it correctly?
Have you ever tried using something like RetroArch?
