Reply 20 of 23, by Kodai
I didn't want to suggest any push pin type coolers, as many 478 boards are slightly thicker than most 775 boards. This can render those plastic push pins useless. But some boards will work fine with most 775 coolers. I have (tucked in a closet right now), an old asus p4s800d x running a P4 @ 3.2GHz with an XSPC socket 775 waterblock. Perfect fit and fantastic cooling. But it uses tension screws to mount and I was never able to make push pins work on that thicker board. Did get them to work on a couple of Abit boards though. YMMV.
Reply 21 of 23, by Oldskoolmaniac
Found this digging around on the net
    304.29 KiB
    371.78 KiB
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 22 of 23, by shiva2004
Aideka wrote:
There sure is a way to mount 775 coolers on socket 478, and some coolers work without brackets too https://www.youtube.com/watch?v=iPGPRYylj5o
You know that this video shows absolutely nothing and in fact in the comments the maker admits that it doesn't function well?
Reply 23 of 23, by Jade Falcon
Rank BANNED
BANNED
Where did find those pics? They may be old pics of mine
Edit
No there not mine.
