First post, by simbin
I'm trying to keep it retro with a modern look. I'm having trouble finding a black modern (desktop) case for a ASUS VL/I-486SV2G. It's a full AT motherboard.
Most of the cases I see are towers. I like the classic desktop look and I prefer no front USB ports - I realize this is going to be a challenge.
My budget is $100
Another thing that would be cool but seems impossible to find is a Turbo LED for the front.
Does anyone have any suggestions? Thanks
WIP: 486DX2/66, 16MB FastPage RAM, TsengLabs ET4000 VLB
Check out my Retro-Ghetto build (2016 Update) 😀
Commodore 128D, iBook G3 "Clamshell"
3DO M2, Genesis, Saturn, Dreamcast, NES, SNES, N64, GBC
Reply 2 of 14, by simbin
sgraffite wrote:
This is all I found in like 10 minutes of searching:
http://www.ebay.com/itm/New-BLACK-DESKTOP-PC- … MsAAOSw6n5Xq7z0
$150 with shipping YIKES! That case looks like it has paint bubbles too.
I would actually be happy with a black ATX (desktop) case, if my motherboard fits. A few years ago I could actually find them. Now all I see is the ITX form factor, when it comes to desktops - everything else is towers.
Reply 3 of 14, by ODwilly
HEC used to sell one on newegg. Not sure if they do anymore. It goes in and out of stock EDIT: its the 7106bb and $44 in stock on newegg
Reply 4 of 14, by ODwilly
Looks like the haf xb by coolermaster and the cm elite 360 may suit your needs
Reply 5 of 14, by clueless1
I did this not too long ago just to see how it looked. I was lucky to have a black CRT to finish the look. No I/O shield in the back and no integrated power/turbo buttons (or LED). But it was fun to put together for a quick photo. BTW, many older ATX cases have AT mounting holes, but they don't all line up with the motherboard. There was no support in the upper right corner of the motherboard, for example. Just had to be careful with mounting and inserting cards.
214.62 KiB
Reply 6 of 14, by simbin
Thanks, both cases look like they'd work. Do you know if there's anything slimmer height-wise? I really don't need all those extra drive bays. It just needs a spot for one CD-ROM and Floppy and be able to accommodate full-height ISA cards.
Reply 7 of 14, by ODwilly
I edited my hec reply with the model number. Its 1mm thick steel even!
Reply 8 of 14, by simbin
I have some HEC cases and like them a lot. However, the sideways 3.5" bays in the 7106bb makes me mental 🤣
It's like that case can't make up its mind.. desktop.. tower.. desktop.. tower
Thanks for looking. I know a solution like this is hard to find. If you can think of any others - let me know.
I'm also using a vertical (tower) case at the moment but want to transition to a more classic looking, horizontal (desktop) case. Your case looks like the Antec cases I used back in the day 😀
Reply 9 of 14, by ODwilly
I have one and agreed! You could always use a 5.25 in a drive adaptor to fix that. More 3.5s for hard drives that way! Oh and it has the mounting holes for AT
Reply 10 of 14, by simbin
I really like the looks of this one, although I could do without the front panel USB (probably not an option in 2016) and it's missing the 3.5" bay for my USB to Floppy converter.
https://www.amazon.com/gp/product/B00KHO0MRK/
I could probably even remove all that side fan stuff (not going to need it on a 486) and put a nice plexiglass window there instead 😀
Reply 11 of 14, by ODwilly
Oh i like that. Sikverstone makes good quality stuff. And you could take the fans out and use them in another oroject
Reply 12 of 14, by Kreshna Aryaguna Nurzaman
Try HTPC chassis.
Kreshna Aryaguna Nurzaman.
Reply 13 of 14, by candle_86
buy a white/beige AT case, some sand paper, some good cleaner, and a 3-4 spray paint cans, get the good stuff, and to top it off get a nice clear coat spray can.
First disassemble it
Next use a good degreaser or paint thinner on the metal parts, and good hot soapy water on the plastic
Next sand down the metal panted parts and get out any inperfections, you can even use bondo on it if there is a small dent
Next soapy water the metal parts
rinse all parts in hot water
Next paint in a cool dry area without wind if possible
Let dry and reassemble
Now you have a black case in your choose style.
For added you could tape off area's and make a design.
Reply 14 of 14, by simbin
Kreshna Aryaguna Nurzaman wrote:
Try HTPC chassis.
Good idea
candle_86 wrote:
buy a white/beige AT case, some sand paper, some good cleaner, and a 3-4 spray paint cans, get the good stuff, and to top it off […]
Unfortunately, I lack the proper tools, work area and skills necessary for a project like that.
