First post, by buckeye
I'm wanting to get into testing mobo's (outside of cases) to post but kinda green on the subject. Can't seem to find either non-expensive test benches or some "plug in" buttons for turning on/off/reset/power to mobo.
Rather not venture into tapping screw drivers on the power off/on pins if you know what I mean. Any helpful hints out there?
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 1 of 10, by clueless1
You can pull a power switch from an old case complete with wire and jumper. I keep a spare in my toolbox just for these purposes. And I just use a flat table with an anti-static bag under the motherboard. You can always use a motherboard box to raise it up so when you put cards into the slots, there is overhang clearance.
Reply 2 of 10, by krivulak
I test them on wooden table with overhang on edge, but it is not great because it is not thoroughly grounded. But it works, I guess? Also I don't test motherboards too often, because 90% PCs I have in case and 90% loose mobos are dead. Which reminded me I wanted to fix that 286 board with leaked battery.
Reply 4 of 10, by kixs
I have cut a notebook box to fit CD-ROM and Floppy inside. Motherboard is on top. PSU in on the right side of the box. When I get time I'll try to make whole thing from wood.
Reply 5 of 10, by Tetrium
PhilsComputerLab wrote:
Motherboard box FTW 😀
^^This
And I wouldn't put the mobo on an antistatic bag when powering it up.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 10, by PhilsComputerLab
Yup works great. It's only on newer gear, like P4, that I like the board to be screwed down. Otherwise the cooler will flex the board and the contact between cooler and CPU will actually be reduced and then the chip could throttle.
YouTube, Facebook, Website
Reply 9 of 10, by clueless1
^^This
How come?
Reply 10 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Some people are afraid as they think the electrostatic bag can cause shorts because it is conductive. But not even in the megaohms range any resistance can be measured on such a bag. The typical electrostatic bag is too highly resistive to have an effect.
1+1=10
