First post, by 386SX
I was looking at the cpu support list of the Asrock K7VT6 board and it's written the support of this cpu. I was thinking it was a legend or something but I can imagine that this confirm it somehow existed. Anyone ever seen that cpu?
Bye
Reply 1 of 13, by Cyrix200+
Hm, I don't know about his one, but I have seen a mainboard manual that states support for the Pentium MMX 266 and 300MHz. If only those existed... 😀
1982 to 2001
Reply 2 of 13, by 386SX
Eheh not bad a Pentium MMX 300Mhz. 😁
Reply 3 of 13, by Imperious
I can run those at 100x24 in my Abit board, but it needed modding to do so.
2400mhz/166 is 14.5 multiplier.
Pentium MMX 266 did exist, but for laptops only. Technically a p2 at 300mhz is still a Pentium MMX, just the 2nd revision.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 5 of 13, by hellslinger
P2 was a completely different microarchitecture and used a different socket and chipset, so this probably wasn't the reason. The manufacturer of the board may have anticipated a faster clocked version or over clocking since the P1 predated locked multipliers.
Reply 6 of 13, by mrau
it actually was planned, i remember reading about this once in the distant past; p2 could not be adjusted to mobile needs and so intel planned to continue the mmx portable line till 300 mhz; the codename was tillamook iirc; its my guess the did not deliver the 300mhz version because it was faster than the actual celeron that came afterwards;
Reply 7 of 13, by melbar
The highest official clocked Athlon XP CPU from AMD. Comes only to OEM like with the Hewlit Packard d325.
According to wiki, with ~79.2W the highest TDP for socket 462.
AXDA3200DKV4D
Link:
http://www.cpu-world.com/CPUs/K7/AMD-Athlon%2 … A3200DKV4D.html
    104.31 KiB
Reply 8 of 13, by 386SX
melbar wrote:
The highest official clocked Athlon XP CPU from AMD. Comes only to OEM like with the Hewlit Packard d325. According to wiki, wit […]
AXDA3200DKV4D
Link:
I can imagine is a very rare cpu isn't it?
Reply 9 of 13, by sgraffite
The Pentium MMX 300 does exist. There was someone on here who has a laptop with it.
Reply 11 of 13, by awgamer
They do, and the mmx 266 exists in socket 7 form.
Reply 12 of 13, by kanecvr
There you go: AXDA3200KV4D - http://www.cpu-world.com/CPUs/K7/AMD-Athlon%2 … A3200DKV4D.html
Stumbled upon this one by chance. It's a tiny bit faster then the regular 3200+ (2.2GHz) with 200MHz FSB.
Here's another weird one: AXDA3000DKV4E http://www.cpu-world.com/CPUs/K7/AMD-Athlon%2 … A3000DKV4E.html
This one runs at 2100MHz FSB200. It's the only FSB 200 3000+ I've seen so far, as the other ones I've come across run at 2166 / FSB 166. Oddly enough, this is slightly faster due to the 200Mhz FSB. Got this one out of an OEM rig.
There's also the AXDA2600DKV3C - this one runs at 2133Mhz, FSB133 - almost the same clock as the 3000+, but with half the cache. There's a fsb 333 variant as well, witch runs at 2086Mhz. The 133MHz FSB version is great for KT333 boards - I have one in my voodoo 3 3500 rig.
The other one is a 2400+ AXDA2400DKV3C witch clearly uses the Barton die, but only has 256kb of L2 cache enabled. Some can have the L2 cache unlocked turning it into a 3000+ of sorts.
I also have a AXDA2800DKV4C 2800+ (2133Mhz, FSB 133) in one of my AGP 3.3v rigs.
