Reply 20 of 53, by vetz
Imperious wrote:
I reckon the Dell U2412M has got to be one of the most Dos compatible monitors around, It does all those weird resolutions like 640x350. It's not perfect for sure and sometimes
it doesn't adjust the resolution properly. In Duke Nukem 2 It was not fitting in the text at the top on occasions, but then at other times it did.
I have similar experiences from my monitor. Only problem is that it's a IPS monitor, which means everything is displayed at 60hz, much DOS stuff is 70hz.
Reply 21 of 53, by s0ren
Does that cause any problems like tearing or out of range errors, or is the "only" problem that the frame rate is lower than intended?
Reply 22 of 53, by vetz
I have not seen out of range errors. Only problem is the frame rate which in theory could cause tearing, but I've not noticed anything.
Reply 23 of 53, by s0ren
Back on topic, 1600*1200 in forced 4:3 does not work like one would hope or expect on the U2412M (unless im doing something very wrong). The picture gets blurry and lacks 1:1 pixel mapping, even though the height is the same as 1920*1200 🙁 I suppose 800x600 will have the same issue.
Substantially reduces the usefulness of this monitor over any standard 16:9 monitor for me.
Reply 24 of 53, by PhilsComputerLab
Rank Hardware Mod
Hardware Mod
1600 x 1200 isn't working for you?
Hmm, on my Samsung VGA works out of the box. DVI requires a bit of mucking around because the resolution isn't supported by default, adding a custom resolution fixes this.
I actually never though about the 800 x 600 resolution and how it looks. For sure something I need to test!
YouTube, Facebook, Website
Reply 26 of 53, by s0ren
Hmm, well, it works, but it doesnt map the pixels 1:1 which is rather disappointing to say the least. Its no sharper than showing a 4:3 resolution on a 16:9 panel. I tried to mess with the DDC/CI interface using C++ and the windows API, in case i could "massage" some properties to give better mapping but i didnt find anything worth while.
Reply 27 of 53, by gdjacobs
oeuvre wrote:
I have come to destroy your corneas. http://i.imgur.com/XhUpTt1.jpg
Hot dog!
Reply 28 of 53, by Imperious
I've only used the Vga input at 1600x1200, and You need to do an auto adjust to line up the pixels properly. I had no complaints about the image quality, it looked very sharp to me.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 29 of 53, by s0ren
I used VGA as well, and also tried auto adjust, but the pixels arent mapped right. You can try draw a 1 pixel black/white zebra stripe pattern in paint to check that there are no grey lines (lines interpolated to half or quater pixels).
Here is a photo of what i mean: http://i.imgur.com/spi12OC.jpg Only every 5th white line is actually white, and the black lines are not completely black.
Reply 30 of 53, by Imperious
Could You please upload that pattern You created in Paint?
I tried creating a single pixel vertical line, then white(blank), then black, and so on.
The result looked exactly like 1:1 pixel mapping to me with a magnifying glass.
I have my video card set to 1600x1200, I did have to hit auto adjust twice though to properly centre the screen.
Reply 31 of 53, by vetz
I'd also like to test that pattern. I can't recall any of the issues you're describing on my Dell monitor.
Reply 32 of 53, by s0ren
Imperious wrote:
Could You please upload that pattern You created in Paint? […]
Weird, this is exactly what i did as well - even tried hitting auto adjust multiple times, tried changing pixel clock, rest monitor settings, etc. If i leave the monitor aspect ratio at 16:10 and let the GPU do the scaling, its perfect of course, but that doesnt help when using an old windows 98 or dos computer.
I uploaded an attachment with the pattern i used.
    743 Bytes
Reply 33 of 53, by Imperious
I've tried that image in VGA 1600x1200, also DVI 1600x1200 and the only time it looks wrong in any way is if I enlarge it.
Reply 34 of 53, by dr_st
Out of curiosity I also tried the forced aspect ratio on a U2412M. 1600x1200 at 4:3 looked just as sharp as 1920x1200 at 16:10. Tried both VGA and DisplayPort inputs...
Reply 36 of 53, by oeuvre
Hey s0ren thanks for the new wallpaper!
    39.85 KiB
Reply 37 of 53, by s0ren
You are welcome.
Tried a colleagues U2412M today with his computer and DVI (different make and different graphics card), and it scales to 4:3 just as bad. His monitor is at least 6 months older than mine, so its not just the most recent batch that cant scale properly.
Reply 38 of 53, by dr_st
Then I guess all of us who cannot see it are just blind. 😜
Does it look sharp at 1920x1200 at 16:10 but blurry at 1600x1200 4:3?
