First post, by keropi
Hiya!
can anyone identify this 8088 motherboard? I tried searching for "SUPER 10-B" but I did not find anything useful...
any hints will be appreciated, thanks!
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 2 of 14, by keropi
I am not worried about acid damage , I'll just spend some time and fix it. I am more worried from lack of documentation 😀
Reply 4 of 14, by keropi
Yes I have found the B1 bios site, what would be more interesting is the jumper block setting. I have also found some B1 pics online, main difference is a variable cap on the xtal1 position, B has a fixed one
Reply 6 of 14, by rein_ein
Tried search in TH99 archive without luck,so best i found is topic about bios,the good that it was bumped after seven years,last time in 2015 and there at least 2 owners of this mobo on the forum
http://www.phantom.sannata.ru/forum/index.php … um_view&o=&st=0
Reply 7 of 14, by keropi
@kanecvr
the pictured mobo has full 640kb , maybe the extra sockets where used with lower capacity ram ICs
@rein_ein
thanks for that, checking it but I don't recognize any nicks from here - what am I missing? 😁
as per the Russian thread the mobo might be similar to this: http://www.uncreativelabs.de/th99/m/U-Z/33682.htm
Reply 9 of 14, by keropi
ah, no problem rein_ein - still I got some leads 😀
are they still searching for the BIOS? Or google translate is way off?
Reply 11 of 14, by carlostex
Your board seems to be a revised, more modern version of the one on the link. In fact it seems to accept 44256 RAM chips. Also on your board JP5 is on a different position, and headers are rearranged compared to the older version. For your board, JP3 is for Turbo Switch and LED, JP4 for Reset and JP5 for Power LED and Speaker.
DIP switches you can follow the info on that page. Should be pretty much the same.
Reply 12 of 14, by Imperious
I have the board pictured below, obviously a newer one than Yours based on the F revision.
    649.23 KiB
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 14 of 14, by Imperious
This is all I could find
http://stason.org/TULARC/pc/motherboards/U/UN … -MAINBOARD.html
